Tost Rings
This weekend we found a tost ring that was split. It was difficult to
see because the rope was rapped around the split. From the looks of it, it had been split for a long time. I do not know how old the ring is or when it actually failed. Take a few minutes and inspect your rings! I would post a photo, but I am not sure how. Safe Soaring, Scott |
Tost Rings
On Monday, November 10, 2014 3:15:05 PM UTC-7, Scott Calvert wrote:
This weekend we found a tost ring that was split. It was difficult to see because the rope was rapped around the split. From the looks of it, it had been split for a long time. I do not know how old the ring is or when it actually failed. Take a few minutes and inspect your rings! I would post a photo, but I am not sure how. Safe Soaring, Scott Upload the photo to a photo site and then post a link here. |
Tost Rings
I found a split Tost ring last year. The larger of the two was split. The give away was the sound, more tinny higher pitch when you jingle the rings.
It had been in use for a while on pavement, so we could not see a serial number on the ring. No number, it's not a true Tost ring. BT |
Tost Rings
At 03:14 11 November 2014, Bill T wrote:
I found a split Tost ring last year. The larger of the two was split. The give away was the sound, more tinny higher pitch when you jingle the rings. It had been in use for a while on pavement, so we could not see a serial number on the ring. No number, it's not a true Tost ring. BT We operate on grass. |
Tost Rings
Check if they are conform LN65091, or if they are cheaper welded ring. The
latter have a tendency to fail and cause significantly more wear than the Tost rings. |
Tost Rings
This weekend we found a tost ring that was split. It was difficult to see because the rope was rapped around the split. From the looks of it, it had been split for a long time. I do not know how old the ring is or when it actually failed. Take a few minutes and inspect your rings! I would post a photo, but I am not sure how. Safe Soaring, Scott We had a ring break a few years ago at a CAP flight academy. It was found while winch launching. I don't have the rings, but they were purchased through a known vendor. The academy leader was to follow-up with the vendor but passed away, so I don't know if there was any resolution. Frank Whiteley |
Similar Threads | ||||
Towing Schweizer Gliders with tost rings? | [email protected] | Soaring | 12 | December 22nd 10 03:59 AM |
TE Probe O-rings | vontresc | Soaring | 1 | May 7th 10 12:56 AM |
Dual tow rings | brianDG303[_2_] | Soaring | 0 | November 28th 09 01:06 AM |
Dual tow rings | brianDG303[_2_] | Soaring | 1 | November 27th 09 10:15 PM |
Libelles & Tost Rings | nowhere | Soaring | 9 | July 21st 04 05:08 PM |
