Hi all,
I own a Thrustmaster Attack throttle, combined with a joystick (Top Gun?) and Elite rudder pedals. The joystick plugs into the rudders which plugs into the throttle. This combo worked fine with my old computer, but now I've upgraded to a new computer and run into some problems. 1. The soundcard don't have any game port. This can be fixed with an USB-Game port-adapter. 2. These adapters can't handle digital units (so I've heard), and the attack throttle is digital. 3. The throttle has no drivers campatible to winXP (I've been told) This leaves me with a couple of alternatives: a) Sell the controls, and buy a new USB stick with built-in throttle and twisting handle to simulate pedals. b) Get a USB-Game port-adapter to use my old joystick together with my pedals, and forget about the throttle. c) Get a USB-Game port-adapter to the pedals, and buy a USB joystick with throttle. (Will that work?) I'm a gliderpilot in real life, so I really like the pedals when flying simulators (because you have to make use of the pedals in every turn with a sailplane) to keep my flying trim up to date. Anybody that have had the same problem and solved it? Anybody that have a sugestion what I should do? Greatings, J |
You can try to sell your Elite Pedals on www.ebay.com, should get a pretty
good price for them if you market them correctly. I'm going to be flying gliders this coming spring, what kind are you flying. Do you have a glider that you can recommend for MS Flight Simulator FS2004 (FS9)? Dashi "news.ericsson.se" wrote in message ... Hi all, I own a Thrustmaster Attack throttle, combined with a joystick (Top Gun?) and Elite rudder pedals. The joystick plugs into the rudders which plugs into the throttle. This combo worked fine with my old computer, but now I've upgraded to a new computer and run into some problems. 1. The soundcard don't have any game port. This can be fixed with an USB-Game port-adapter. 2. These adapters can't handle digital units (so I've heard), and the attack throttle is digital. 3. The throttle has no drivers campatible to winXP (I've been told) This leaves me with a couple of alternatives: a) Sell the controls, and buy a new USB stick with built-in throttle and twisting handle to simulate pedals. b) Get a USB-Game port-adapter to use my old joystick together with my pedals, and forget about the throttle. c) Get a USB-Game port-adapter to the pedals, and buy a USB joystick with throttle. (Will that work?) I'm a gliderpilot in real life, so I really like the pedals when flying simulators (because you have to make use of the pedals in every turn with a sailplane) to keep my flying trim up to date. Anybody that have had the same problem and solved it? Anybody that have a sugestion what I should do? Greatings, J |
So you're suggesting me to get a new twistable all-in one stick?
I forgot to mention that price is important, so I will not get very expensive things... I'm flying the types we have at our club: Bergfalke IV, Pilatus B4, DG500 and LS-8. In MSFS2002 there is a couple of good gliders available, look at this site. You can even create some sort of thermals of your own with add-on programs. I think they will do fine in FS2004 as well. http://www.virtualsoaring.org http://www.virtualsoaring.org/aircraft/aircraft3.html MSFS does not simulate lift very well. You can get these thermals, but they are not very good in my opinion. I've flown Flight Unlimited 3 a lot, which do simulate ridge lift very nice. Just tune in some wind and surf the ridges all around Washington state. ![]() With my new computer I want to try the dedicated glider simulators SFPC (http://www.sfspc.de/index_e.htm) and Sailors of the sky (http://www.sailorsofthesky.com). /J "Dashi" wrote in message ... You can try to sell your Elite Pedals on www.ebay.com, should get a pretty good price for them if you market them correctly. I'm going to be flying gliders this coming spring, what kind are you flying. Do you have a glider that you can recommend for MS Flight Simulator FS2004 (FS9)? Dashi "news.ericsson.se" wrote in message ... Hi all, I own a Thrustmaster Attack throttle, combined with a joystick (Top Gun?) and Elite rudder pedals. The joystick plugs into the rudders which plugs into the throttle. This combo worked fine with my old computer, but now I've upgraded to a new computer and run into some problems. 1. The soundcard don't have any game port. This can be fixed with an USB-Game port-adapter. 2. These adapters can't handle digital units (so I've heard), and the attack throttle is digital. 3. The throttle has no drivers campatible to winXP (I've been told) This leaves me with a couple of alternatives: a) Sell the controls, and buy a new USB stick with built-in throttle and twisting handle to simulate pedals. b) Get a USB-Game port-adapter to use my old joystick together with my pedals, and forget about the throttle. c) Get a USB-Game port-adapter to the pedals, and buy a USB joystick with throttle. (Will that work?) I'm a gliderpilot in real life, so I really like the pedals when flying simulators (because you have to make use of the pedals in every turn with a sailplane) to keep my flying trim up to date. Anybody that have had the same problem and solved it? Anybody that have a sugestion what I should do? Greatings, J |
![]() "Aake" wrote in message ... So you're suggesting me to get a new twistable all-in one stick? I forgot to mention that price is important, so I will not get very expensive things... No I'm not suggesting that, I thought that you were trying to get rid of your Elite pedals and I offered a suggestion on how to do that. Personally I would get an adapter and keep the pedals, try this out with your current joystick/throttle and see how it works. Dashi I'm flying the types we have at our club: Bergfalke IV, Pilatus B4, DG500 and LS-8. In MSFS2002 there is a couple of good gliders available, look at this site. You can even create some sort of thermals of your own with add-on programs. I think they will do fine in FS2004 as well. http://www.virtualsoaring.org http://www.virtualsoaring.org/aircraft/aircraft3.html MSFS does not simulate lift very well. You can get these thermals, but they are not very good in my opinion. I've flown Flight Unlimited 3 a lot, which do simulate ridge lift very nice. Just tune in some wind and surf the ridges all around Washington state. ![]() With my new computer I want to try the dedicated glider simulators SFPC (http://www.sfspc.de/index_e.htm) and Sailors of the sky (http://www.sailorsofthesky.com). /J "Dashi" wrote in message ... You can try to sell your Elite Pedals on www.ebay.com, should get a pretty good price for them if you market them correctly. I'm going to be flying gliders this coming spring, what kind are you flying. Do you have a glider that you can recommend for MS Flight Simulator FS2004 (FS9)? Dashi "news.ericsson.se" wrote in message ... Hi all, I own a Thrustmaster Attack throttle, combined with a joystick (Top Gun?) and Elite rudder pedals. The joystick plugs into the rudders which plugs into the throttle. This combo worked fine with my old computer, but now I've upgraded to a new computer and run into some problems. 1. The soundcard don't have any game port. This can be fixed with an USB-Game port-adapter. 2. These adapters can't handle digital units (so I've heard), and the attack throttle is digital. 3. The throttle has no drivers campatible to winXP (I've been told) This leaves me with a couple of alternatives: a) Sell the controls, and buy a new USB stick with built-in throttle and twisting handle to simulate pedals. b) Get a USB-Game port-adapter to use my old joystick together with my pedals, and forget about the throttle. c) Get a USB-Game port-adapter to the pedals, and buy a USB joystick with throttle. (Will that work?) I'm a gliderpilot in real life, so I really like the pedals when flying simulators (because you have to make use of the pedals in every turn with a sailplane) to keep my flying trim up to date. Anybody that have had the same problem and solved it? Anybody that have a sugestion what I should do? Greatings, J |
Thanks Dashi.
Preferably, I will keep the pedals to use them with some kind of stick. The question is what, and haw to make it work. Maybe an adapter will work with my pedal and stick, but then I'll be in lack of a throttle. I'll try it anyway. "Dashi" wrote in message ... "Aake" wrote in message ... So you're suggesting me to get a new twistable all-in one stick? I forgot to mention that price is important, so I will not get very expensive things... No I'm not suggesting that, I thought that you were trying to get rid of your Elite pedals and I offered a suggestion on how to do that. Personally I would get an adapter and keep the pedals, try this out with your current joystick/throttle and see how it works. Dashi I'm flying the types we have at our club: Bergfalke IV, Pilatus B4, DG500 and LS-8. In MSFS2002 there is a couple of good gliders available, look at this site. You can even create some sort of thermals of your own with add-on programs. I think they will do fine in FS2004 as well. http://www.virtualsoaring.org http://www.virtualsoaring.org/aircraft/aircraft3.html MSFS does not simulate lift very well. You can get these thermals, but they are not very good in my opinion. I've flown Flight Unlimited 3 a lot, which do simulate ridge lift very nice. Just tune in some wind and surf the ridges all around Washington state. ![]() With my new computer I want to try the dedicated glider simulators SFPC (http://www.sfspc.de/index_e.htm) and Sailors of the sky (http://www.sailorsofthesky.com). /J "Dashi" wrote in message ... You can try to sell your Elite Pedals on www.ebay.com, should get a pretty good price for them if you market them correctly. I'm going to be flying gliders this coming spring, what kind are you flying. Do you have a glider that you can recommend for MS Flight Simulator FS2004 (FS9)? Dashi "news.ericsson.se" wrote in message ... Hi all, I own a Thrustmaster Attack throttle, combined with a joystick (Top Gun?) and Elite rudder pedals. The joystick plugs into the rudders which plugs into the throttle. This combo worked fine with my old computer, but now I've upgraded to a new computer and run into some problems. 1. The soundcard don't have any game port. This can be fixed with an USB-Game port-adapter. 2. These adapters can't handle digital units (so I've heard), and the attack throttle is digital. 3. The throttle has no drivers campatible to winXP (I've been told) This leaves me with a couple of alternatives: a) Sell the controls, and buy a new USB stick with built-in throttle and twisting handle to simulate pedals. b) Get a USB-Game port-adapter to use my old joystick together with my pedals, and forget about the throttle. c) Get a USB-Game port-adapter to the pedals, and buy a USB joystick with throttle. (Will that work?) I'm a gliderpilot in real life, so I really like the pedals when flying simulators (because you have to make use of the pedals in every turn with a sailplane) to keep my flying trim up to date. Anybody that have had the same problem and solved it? Anybody that have a sugestion what I should do? Greatings, J |
Elite and CH Flight Sim Yoke - USB | tscottme | Instrument Flight Rules | 3 | December 21st 10 11:34 PM |
Elite and CH Flight Sim Yoke - USB | tscottme | Simulators | 2 | May 3rd 04 06:24 AM |
Elite simulation software | Marco Rispoli | Simulators | 5 | October 2nd 03 07:46 PM |
Airman flying high with elite team | Otis Willie | Military Aviation | 0 | September 17th 03 03:24 AM |
FS2004 tail draggers - no rudder pedals - what do I do?? | Hogarth Kramer | Simulators | 1 | August 18th 03 05:43 PM |
