Could someone tell me how to push back from the terminal in FS2002 prof
please? I can thrust forward and turn hard, but unless I disable "reset after crash" when I hit the terminal building the sim stops and, yes, resets itself. I have tried reverse thrust too, but that doesn't seem towork. Is there a proper way to pushback? |
On Sun, 15 Aug 2004 20:33:48 GMT, "cruise" wrote:
Could someone tell me how to push back from the terminal in FS2002 prof please? I can thrust forward and turn hard, but unless I disable "reset after crash" when I hit the terminal building the sim stops and, yes, resets itself. I have tried reverse thrust too, but that doesn't seem towork. Is there a proper way to pushback? shift+P, press again to stop pushback. |
shift p to push back then
press 1 or 2 without pressing any other keys to turn left or right shift p again to stop or you could use y for slew "cruise" wrote in message ... Could someone tell me how to push back from the terminal in FS2002 prof please? I can thrust forward and turn hard, but unless I disable "reset after crash" when I hit the terminal building the sim stops and, yes, resets itself. I have tried reverse thrust too, but that doesn't seem towork. Is there a proper way to pushback? |
... shift p to push back then press 1 or 2 without pressing any other keys to turn left or right shift p again to stop Specifically: Press 1 to make the TAIL (not nose) turn left, meaning the nose will swing to the right Press 2 to make the TAIL (not nose) turn right, meaning the nose will swing to the left -- Kurt Weber |
fs2002 problem | Roger Maskell | Simulators | 9 | June 17th 04 11:14 AM |
FS2002 Compass Anomaly - PLEASE HELP | GM EWA | Simulators | 0 | January 13th 04 11:20 PM |
Difference Between FS2002 Pro vs. the Standard Versions? | Bill Wolff | Simulators | 4 | January 12th 04 03:26 AM |
Radio problem in FS2002 | Scet | Simulators | 2 | September 12th 03 10:19 AM |
Help needed - fs2004 zaps fs2002 props | Ian D | Simulators | 1 | September 11th 03 10:20 PM |
