FS 2004 with multiple monitors - how to save settings?
Old December 7th 04, 09:19 AM
Horst Walter
Default FS 2004 with multiple monitors - how to save settings?
Hi,
running MS FS 2004 on multiple screens is cool. However, I was not
able to figure out how I can save a configuration for this.
I always have to reopen the extra windows when I restart FS 2004. Is
there no chance to save (multiple) configurations for this so I can
start with my last setup straight away.
Any ideas?
regards HW
Old December 7th 04, 10:56 AM
Talon
HW, there is a way to do it, or at least I can. I run in windowed mode and
I don't know if this is the secret but all you need to do is get the sim
set-up to your liking with your panels or whatever located on the other
monitor and then click on file, save flight and a dialogue box will come up
so that you can name the flight. You also have the option to check off a
box that says make this the default flight which will start with this saved
flight everytime instead of the create a flight menu. If you don't make it
the default flight simply go to select a flight and the file name you saved
should appear on the list under Myflights. When the flight opens it should
have your monitors setup on the other screens as you left it.
Paul
"Horst Walter" wrote in message
om...
Hi,
Any ideas?
regards HW
Old December 7th 04, 11:57 AM
Quilljar
Yes I can confirm this. Set up all the windows, everything you want as you
like it, even the weather; then save the flight. Call it 'Heathrow with
windows' or something like that, if you wish. When you select it again, it
should come up exactly. From then on you can fly or slew to anywhere else in
the world and it will stay with the windows, then you can save a flight from
another postion etc etc ....
Quilljar
Old December 7th 04, 02:37 PM
Trip Lane
I agree also. It works the same way here. - Trip
"Quilljar" wrote in message
in the world and it will stay with the windows, then you can save a flight
from another postion etc etc ....
Quilljar
2004 Homebuilt Statistics Ron Wanttaja Home Built 8 January 15th 05 04:24 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
16 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 17th 04 12:37 AM
FS 2002 Multiple Monitors Hugh Roberton Simulators 1 September 22nd 03 01:49 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
