WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE
AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Eric |
see also :
http://www.lba.de/dokumente/ad/2003-245-e.pdf (for the Turbo version) Marc Bob Kuykendall a écrit: English-language version he http://www.lba.de/dokumente/ad/2003-246-e.pdf Bob K. |
Nothing too serious. Just cut a few dozen holes in each wing, do a
borescope inspection and if you are lucky, repair the holes. Should be back in action by the end of the season. Ours is booked in for Monday. http://www.schempp-hirth.com/en/index.html gives details "Marc Till" ] wrote in message ... see also : http://www.lba.de/dokumente/ad/2003-245-e.pdf (for the Turbo version) Marc Bob Kuykendall a écrit: English-language version he http://www.lba.de/dokumente/ad/2003-246-e.pdf Bob K. |
Eric van Geetsum writes:
WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Hi Eric, thank god the pilots are safe! Do you know anything more about how the accident happened? Are there any 'official' sources, e.g. like www.bfu-web.de where an analysis of such accidents is done? Failure of the wings sounds a bit like they went 'very' fast before the glider broke? Safe landings! Bernd |
Report by LBS states "manouevering speed" - ergo a lot below Vne...
There was no reference to unusual attitudes, turbulence or any other factor. The LBA report implies that the wing failed while being flown in the certified flight envelope. One assumes they would not ground the fleet on grounds of not being airworthy unless they were fairly sure there was some structural fault. Question is whether it was a singular fault, damage to the specific aircraft, or generic to the design. |
WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Hi Eric, thank god the pilots are safe! Do you know anything more about how the accident happened? Are there any 'official' sources, e.g. like www.bfu-web.de where an analysis of such accidents is done? Failure of the wings sounds a bit like they went 'very' fast before the glider broke? Safe landings! Bernd PS: The only I could find so far (source: DAeC): 25.07, 16.30 Schempp Duo Discus Thermiksegelflug Primärbruch des linken Tragflügels im Flug / Beide Insassen konnten sich mit dem Fallschirm retten. |
Hi,
ich vermute mal, dass es dieser Unfall war. http://de.news.yahoo.com/030725/27/3k388.html mfg, Robert http://www.ballonfahrten-niederrhein.de "Bernd Dorien" schrieb im Newsbeitrag ... Eric van Geetsum writes: WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Hi Eric, thank god the pilots are safe! Do you know anything more about how the accident happened? Are there any 'official' sources, e.g. like www.bfu-web.de where an analysis of such accidents is done? Failure of the wings sounds a bit like they went 'very' fast before the glider broke? Safe landings! Bernd |
Southern Sailplanes, the UK agents, have been told
that the wing failed about 4 metres from the tip. The glider was still flying (presumably not very well) and so the pilots were able to get out successfully. Apart from the fact that all the Duos with the relevant serial numbers are grounded they have no information as to what action needs to be taken by owners until an Airworthiness Directive appears. John Galloway At 23:18 31 July 2003, Eric Van Geetsum wrote: WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Eric |
The AD & Technical note are available. Check
http://www.schempp-hirth.com/en/serv...gen/index.html Mike Green John Galloway wrote: Southern Sailplanes, the UK agents, have been told that the wing failed about 4 metres from the tip. The glider was still flying (presumably not very well) and so the pilots were able to get out successfully. Apart from the fact that all the Duos with the relevant serial numbers are grounded they have no information as to what action needs to be taken by owners until an Airworthiness Directive appears. John Galloway At 23:18 31 July 2003, Eric Van Geetsum wrote: WTH IMEDIATE EFFECTIVENESS THE GERMAN AUTHORITIES HAVE SUSPENDED THE AIRWORTHINESS OF THE DUO DISCUS (T) ALL DUO'S ARE GROUNDED DUE TO A WING FAILURE IN FLIGHT (BOTH PILOTS BAILED OUT AND LANDED SAFELY WITH THERE CHUTE.) MORE DETAILS LOOK AT: www.lba.de/dokumente/ad/lta-dt/2003-245-d.pdf www.lba.de/dokumente/ad/lta-dt/2003-246-d.pdf Eric _____ | `-----------( )-----------' ' mighty gorilla Duo Discus N175DD PW-5 N80MG |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Air Force Print News for July 30, 2003 | Otis Willie | Military Aviation | 0 | July 31st 03 10:35 PM |
Air Force Print News for July 9, 2003 | Otis Willie | Military Aviation | 0 | July 10th 03 02:41 AM |
NavNews for Tuesday, July 08, 2003 | Otis Willie | Military Aviation | 0 | July 10th 03 02:39 AM |
Business Aircraft & Jet Preview - July 10, 2003 - Van Nuys Airport (VNY) | Mergatroide | General Aviation | 0 | July 2nd 03 05:36 PM |
