used radios
Old August 2nd 16, 01:10 PM posted to rec.aviation.soaring
HGXC[_4_]
Default used radios
Is there a source or distributor for used radios? I am told that there was a change in the type of radios that are allowed in Europe and that there may be pilots transitioning to newer equipment.
Thanks,
Dennis
Old August 2nd 16, 01:49 PM posted to rec.aviation.soaring
Default used radios
Thanks,
Dennis
Several available on W&W.
UH
Old August 2nd 16, 02:47 PM posted to rec.aviation.soaring
rudolph stutzmann
Default used radios
Thanks,
Dennis
http://www.glidersource.com/cgi-bin/...pe=Instruments
Old August 2nd 16, 07:29 PM posted to rec.aviation.soaring
JS
Default used radios
And of course the most ads will be found he
http://www.segelflug.de/osclass/inde...&sCategory=110
Old August 2nd 16, 07:36 PM posted to rec.aviation.soaring
HGXC[_4_]
Default used radios
Thanks,
Dennis
Thanks much to all of you ...appreciative it.
Dennis
Old August 4th 16, 09:09 PM posted to rec.aviation.soaring
Ross[_3_]
Default used radios
Sent you a message the other day.
Cheers
Old August 5th 16, 12:33 AM posted to rec.aviation.soaring
Default used radios
Frequency spacing has been an issue outside NA for a while....... Thus, good radios for us (now), maybe moot down the road.
What support does your, "good in NA now" have now and down the road?
BTW, "NA" means North America.
Old August 5th 16, 01:16 PM posted to rec.aviation.soaring
Default used radios
Barnstormers.com has several used radios under Gliders/sailplanes for $250 to $350 and they are in the US.
JJ
FS: Radios and Instruments Ross[_3_] Soaring 3 June 17th 16 11:40 AM
Need VHF radios for Africa HECTOP Owning 7 July 2nd 04 01:26 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
Really strange going-on with radios Roy Smith General Aviation 3 March 15th 04 12:52 PM
TKM radios Peter Gottlieb Piloting 5 August 15th 03 02:44 PM
