Gluing phenolic
Old June 9th 04, 05:37 AM
B2431
Default Gluing phenolic
Waht is the best way to glue two piece of phenolic together?
Dan, U.S. Air Force, retired
Old June 9th 04, 05:59 PM
Bob Kuykendall
I've never had to glue chunks of phenolic together. But I have glued
phenolic to fiberglass (both epoxy and polyester resin) to form
reinforcing pads where composite structure meets steel structure. For
that I always scarf the edges of the phenolic to an included angle of
about 30 degrees, and I always sand or grind the phenolic to take the
shiny finish off of it.
There are some pictures on this Web page of me bonding in the phenolic
reinforcements for a test control stick installation:
http://www.hpaircraft.com/center_sti...e_26_march.htm
And here's some pictures of a composite wing spar with Garolite
reinforcements where the main pin bores will be:
http://www.hpaircraft.com/hp-24/update_4_dec_02.htm
http://www.hpaircraft.com/hp-24/update_21_march_04.htm
As far as what's the best way to join phenolic parts together, I guess
it depends on what specific kind of phenolic you're using (These days
I mostly use Garolite G10, which I'm not sure you'd really call
"phenolic"). And also what kinds of loads you're trying to transfer
through the glue joint. I can't give you much general advice there -
the only things I know that work are the things I've tested.
I hope that helps some.
Thanks, and best regards to all
Bob K.
Old June 12th 04, 05:40 AM
B2431
(Leon McAtee)
Date: 6/9/2004 7:14 PM Central Daylight Time
Message-id:
(B2431) wrote in message
In my experience the best way to glue phenolic together is with AN3-X.
Most if not all of the epoxy resins we homebuilders use bonds poorly
to phenolic. Drilling holes in the phenolic fitting and using cotton
flox in the resin as a kind of composite rivet makes for a useable
structure. Think encapsulation rather than bonding.
Leon McAtee
Q builder
I am building and LED indicator lamp holder. I have a 3/8" and a 1/8" phenolic.
I want to glue/epoxy them together to make 1/2" thick. Using your idea of
encapsulation how would I do this?
Old June 12th 04, 11:44 PM
Leon McAtee
Leon McAtee
Q builder
Thought you were thinking about structural things like rudder
hinges.....
For what your considering - I think - just sand well with something
like 120 grit sandpaper and use any good epoxy. Whack it with a
hammer and it will probably break at the epoxy/phenolic surface but
for holding LEDS it should be just fine.
Spar gluing Lou Parker Home Built 26 November 21st 03 08:29 PM
