Mounting GPS/antenna on Carbon panels
Old October 25th 03, 12:25 AM
Anthony McNicholas
Default Mounting GPS/antenna on Carbon panels
The Volkslogger manual states that 'During installation,
assure that the integral antenna has a clear view of
the sky and is not shielded by metal or carbon fiber
parts.' (there is no similar comment in the Colibri
version 3.0 manual.)
Has anyone with GPS units mounted on carbon panels
encountered reception problems? Would a carbon pannel
interfere with reception if the back of the GPS antenna
is flush against a carbon pannel even if the top of
the antenna still had a 'clear view of the sky' vertically
upwards?
Does anyone know if there is an external antenna option
for Volksloggers? Also, now that the Colibri seems
to have a built-in antenna as standard is there an
external antenna option for it also?
Old October 25th 03, 04:13 AM
Paul Remde
Hi,
It has always been my understanding that you can mount the GPS antenna near
(above) metal or carbon fiber without problems. If you mount it below the
metal or carbon fiber, you will have problems. As long as you mount the GPS
antenna so that the metal or carbon fiber will not block its view of the GPS
satellites, you will get good signal. It may actually help to have metal or
carbon fiber below the antenna. I am not an expert on radio signal
transmission, but I have played with a lot of GPS units.
Good Soaring,
Paul Remde
Cumulus Soaring Supplies
http://www.cumulus-soaring.com
"Anthony McNicholas" wrote
in message ...
upwards?
Old October 25th 03, 07:10 AM
bumper
There is no problem mounting a GPS antenna on a carbon fiber panel or on
metal. You just don't want metal or carbon *between* the antenna and its
view of the sky. The more unobstructed the antenna's view, the better.
in message ...
upwards?
Old October 25th 03, 01:23 PM
Scott Correa
in message ...
Carbon is "radio opaque" which means it doesnt allow thru
transmission of rf waves. Fiberglass is "radio clear".
Basically, don't put the antenna in the "shadow" of the
carbon components when viewed in the line of sight.\
Scott
Old October 25th 03, 10:01 PM
Mike Borgelt
On 24 Oct 2003 23:25:24 GMT, Anthony McNicholas
Excellent advice
upwards?
The carbon will shield the antenna's view of the sky
for Volksloggers?
Last I heard there was. BUt I haven't sold one, only with internal
antenna.
Mike Borgelt
Old October 26th 03, 12:17 PM
Harold Ennulat
External mounted antena is no longer an option on the Volkslogger. When
they went from a round 9-pin plug to the RJ-45 style plug they lost real
estate inside the box that now precludes the mount for an external antenna
plug.
Harold Ennulat
ENTEC
in message ...
upwards?
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
carbon fiber dutchpilot Home Built 0 June 16th 04 12:20 PM
Foil Antenna on Carbon Fiber Dennis Mountains Home Built 7 April 24th 04 12:54 AM
Carbon fiber vs. antennas Jim Weir Home Built 8 January 2nd 04 01:40 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
