I can't find anything in my books about how to make a 90 degree turn
(e.g., downwind to base) while in a full slip, but maybe that's because it's so obvious. (Given my limited # hours, just because something seems obvious to me doesn't mean I'm not going to check it out.) I figure I'll turn with roll input, but can't picture the side effects from doing that. If I know the side effects I can have a chance of being ahead of the plane during the maneuver. Anyway, is there going to be any adverse yaw from turning in this mode? Even if there is, I don't think I can do anything about it, but enquiring minds want to know. The other question is if the attitude going to change as a side effect of the roll input. This will be in a 2-33. Thanks |
At 02:42 05 February 2004, Isoar wrote:
I can't find anything in my books about how to make a 90 degree turn (e.g., downwind to base) while in a full slip, Funny that, but then you should take a massive pinch of salt when you read posts about making you turns with the rudder. If you need to side slip at all during your downwind, base and final, best do it on the straight parts and use proper coordinated well banked turns between. The one thing you should always avoid getting into is turning with excessive amounts of rudder. Why? This is where spins develop from, because in the event of you stalling, the likelyhood of you surviving when low, as you would be on your base turn, or final turn are very slim. Get into the habit of flying turns in a coordinated manner right from the start, at all times. I figure I'll turn with roll input, but can't picture the side effects from doing that. There are no side effects of performing a correct well banked coordinated turn. If I know the side effects I can have a chance of being ahead of the plane during the maneuver. If you fly in a coordinated manner you dont have to think ahead of the plane Anyway, is there going to be any adverse yaw from turning in this mode? any aileron input will produce adverse yaw Even if there is, I don't think I can do anything about it, if you were flying coordinated turns it would not be something you have to factor in. but enquiring minds want to know. absolutely. problem though with this news group, which is ment to be a gliding news group, there are to many power pilots preaching power techniques! The other question is if the attitude going to change as a side effect of the roll input. This will be in a 2-33. there will always be an attitude change in any turn. Thanks |
Pete Zeugma wrote in message ...
At 02:42 05 February 2004, Isoar wrote: I can't find anything in my books about how to make a 90 degree turn (e.g., downwind to base) while in a full slip, Funny that, but then you should take a massive pinch of salt when you read posts about making you turns with the rudder. If you need to side slip at all during your downwind, base and final, best do it on the straight parts and use proper coordinated well banked turns between. The one thing you should always avoid getting into is turning with excessive amounts of rudder. Why? It's a slip, NOT a skid. I'm not using excessive amounts of ruddre, but just the opposite - essentially too little rudder to the extreme. I most often do one of these when getting into a 2-33 after flying glass with effective spoilers for a while. When on base leg, I realize my normal pattern altitude is too high for the little bit of sink the spoilers of the 2-33 provide. So as I turn base to final, I apply rudder away from the direction of turn and lots of aileron into the turn. Viola - a huge amount of altitude lost in the turn and as I line up on final, the contols get 'normalized' again and spoilers back to 2/3 or so for a normal flare and touchdown. I usually get the angles figured out for the 2-33 after a couple flights and the slip goes away, unless of course, I want to have some fun. Like slipping down to the flare, flare aggressively, do a high AOA touchdown (almost 2 point) and get stopped within 1-200' of touchdown ![]() I've even done this in my ASW-20B with full flaps and spoilers. Set up a landing while a gust front os blowing about 50 knots down the runway. So the pattern is high with a planned turn to final at 5-600' AGL pretty much over the numbers. About half way down base leg, the wind quits. Now I'm waaaay high. So I pull out full flaps, full spoilers, and do the slipping turn. I slipped it all the way down to about 50', and touched down almost exaclty where I'd planned when the wind was still blowing. Tom ASH-26E |
ISoar wrote:
I can't find anything in my books about how to make a 90 degree turn (e.g., downwind to base) while in a full slip, but maybe that's because it's so obvious. (Given my limited # hours, just because something seems obvious to me doesn't mean I'm not going to check it out.) Speaking for myself, when I say I'm making a "slipping turn from base to final", what I really mean is that I start off in a coordinated moderately banked turn. When the nose is still pointing something like 20 to 30 degrees away from the runway, I slowly start feeding in opposite rudder to transition into a forward slip. Adjustments are made in yaw, pitch, and roll, to maintain a stable forward slip on the runway heading until any excess altitude is eliminated, at which point I transition to straight flight and a normal landing. If this is something you haven't done, you definitely should get an instructor to show you how, this is not something you want to be learning on your own... Marc |
Funny thing this discussions. Slipping turns from base to final were part of
my practical exam to get my license in Germany. Well that's now 20+ years ago, and we did that on Ka7, Ka8 and things like that. It is coordinated flight, by the way. -- Bert Willing ASW20 "TW" "Marc Ramsey" a écrit dans le message de . com... ISoar wrote: I can't find anything in my books about how to make a 90 degree turn (e.g., downwind to base) while in a full slip, but maybe that's because it's so obvious. (Given my limited # hours, just because something seems obvious to me doesn't mean I'm not going to check it out.) Speaking for myself, when I say I'm making a "slipping turn from base to final", what I really mean is that I start off in a coordinated moderately banked turn. When the nose is still pointing something like 20 to 30 degrees away from the runway, I slowly start feeding in opposite rudder to transition into a forward slip. Adjustments are made in yaw, pitch, and roll, to maintain a stable forward slip on the runway heading until any excess altitude is eliminated, at which point I transition to straight flight and a normal landing. If this is something you haven't done, you definitely should get an instructor to show you how, this is not something you want to be learning on your own... Marc |
On Thu, 5 Feb 2004 11:28:19 +0100, "Bert Willing"
wrote: Funny thing this discussions. Slipping turns from base to final were part of my practical exam to get my license in Germany. Well that's now 20+ years ago, and we did that on Ka7, Ka8 and things like that. It is coordinated flight, by the way. An approach without flaps by sideslip-only (including sideslip turn from downwind to final) was also required during my instructor examination. I did that in a G-103 Twin Astir, but I also saw the same being done with an ASH-25. Lots of fun, by the way. Nothing more thrilling than taking part in a precision landing contest without even touching the flap lever... ![]() Bye Andreas |
The main difference is when you stop the sideslip with these new
composite planes. Higher speed required to maintain safe sideslip position but these planes has no same drag in normal glide position as a KA7 has. So expect to run much longer ![]() /Janos Andreas Maurer wrote: On Thu, 5 Feb 2004 11:28:19 +0100, "Bert Willing" wrote: Funny thing this discussions. Slipping turns from base to final were part of my practical exam to get my license in Germany. Well that's now 20+ years ago, and we did that on Ka7, Ka8 and things like that. It is coordinated flight, by the way. An approach without flaps by sideslip-only (including sideslip turn from downwind to final) was also required during my instructor examination. I did that in a G-103 Twin Astir, but I also saw the same being done with an ASH-25. Lots of fun, by the way. Nothing more thrilling than taking part in a precision landing contest without even touching the flap lever... ![]() Bye Andreas |
On Thu, 05 Feb 2004 16:21:14 +0100, Janos Bauer
wrote: The main difference is when you stop the sideslip with these new composite planes. Higher speed required to maintain safe sideslip position but these planes has no same drag in normal glide position as a KA7 has. So expect to run much longer ![]() This is the problematic point here. ![]() It is possible to keep the sideslip even during the flare (to increase drag), but the lower wing tip is very close to the ground then... not a game for a beginner. Frankly spoken, I have no idea how a "normal" pilot without lots of sideslip experience is going to land a glass glider safely without the use of aibrakes. Bye Andreas |
Not even talking about aerobatic exams in a Lo100 :-)
-- Bert Willing ASW20 "TW" "Andreas Maurer" a écrit dans le message de ... On Thu, 5 Feb 2004 11:28:19 +0100, "Bert Willing" wrote: Funny thing this discussions. Slipping turns from base to final were part of my practical exam to get my license in Germany. Well that's now 20+ years ago, and we did that on Ka7, Ka8 and things like that. It is coordinated flight, by the way. An approach without flaps by sideslip-only (including sideslip turn from downwind to final) was also required during my instructor examination. I did that in a G-103 Twin Astir, but I also saw the same being done with an ASH-25. Lots of fun, by the way. Nothing more thrilling than taking part in a precision landing contest without even touching the flap lever... ![]() Bye Andreas |
On Thu, 5 Feb 2004 18:13:39 +0100, "Bert Willing"
wrote: Not even talking about aerobatic exams in a Lo100 :-) Never mention glider aerobatics in my presence anymore... ![]() Bye Andreas |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
"Proceed on Course" = "Right turn approved"? | Bob Chilcoat | Piloting | 41 | July 18th 04 11:48 PM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Rate of turn indicator on commercial jets (Boeing / Airbus) | Mark | Simulators | 1 | November 1st 03 10:35 AM |
IFR in the 1930's | Rich S. | Home Built | 43 | September 21st 03 01:03 AM |
