IPAQ Wiring - which pins are used
Old February 22nd 04, 01:16 PM
Michael
Default IPAQ Wiring - which pins are used
There are commercial solutions availabe, ready to use.
But I would like to know which pins are used on the
IPAQ 3900 side for a two wire communication with the GPS
and which pins are used for the +5V power supply.
The IPAQ connector has some 22 pins and I guess that for
power pins 19 gets +5V and pin 21 gets ground.
A standard serial cable may connect pins 6,7,8,9,10,11,12,13,14,
whereas the USB cable connects to what? Is it pin 17 and 22 or
some of the serial pins?
Can someone explain the pin usage for a 4 wire power/com cable
on the IPAq side?
Thanks a lot
Michael
Old February 23rd 04, 12:02 AM
Gary
Here goes
1 Power V_ADP + 5 Volt
2 Power V_ADP +
3 Power V_ADP +
4 Power V_ADP +
5 Reserved - Do not use
6 RS232 DCD
7 RS232 RXD For GPS
8 RS232 TXD For GPS
9 RS232 DTR
10 GND Ground Negative side for your 5 volt -
11 RS232 DSR
12 RS232 RTS
13 RS232 CTS
14 DS232 RING
15 GND Ground
16 No Connect - Do Not Use
17 USB Detect
18 No Connect - Do Not Use
19 USB - UDC +
20 No Connect - Do Not Use
21 USB - UDC -
22 Ground
Note: Pin out- 22 Pin Cradle Connector IPAQ Side
Notched Side will be the even numbers
Gary
(Michael) wrote in message . com...
on the IPAq side?
Thanks a lot
Michael
Old February 23rd 04, 12:08 AM
K.P. Termaat
The 22 pin connector that fits into the iPaq 3900 series uses the following
pins for a connection to a NMEA serial port:
pins 1,2,3,4 = 5Volt
pins 10,15,22 = common
pin 7 = RD (input to iPaq)
pin 8 = TD (output from iPaq)
When using a DB9 male connector for the serial port connection use the
following pins on this connector:
pin 2 = data in (to iPaq)
pin 3 = data out (from iPaq, but normally not used)
pin 5 = common
pin 8 = +5Volt
Good luck,
Karel, NL
"Michael" schreef in bericht
om...
on the IPAq side?
Thanks a lot
Michael
Old March 14th 04, 12:03 PM
John Ferguson
Hi,
Wonder if you can help. I'm looking at a plug for the
3900 series Ipaq and it has 4 rows of staggered pins
for soldering to. Does anyone know the pin numbering
sequence for the plug, thanks in advance
John
uses the following
connection use the
pin 5 = common
pin 8 = +5Volt
Old March 14th 04, 05:01 PM
tango4
Try www.internationalsoaring.org/Pinouts.html
Ian
Old March 15th 04, 07:41 PM
Jibpilot
or you might try
http://www.kolumbus.fi/ari.torpstrom/pinouts_.htm nice pictures of the pins
Gunnar
Old March 15th 04, 08:25 PM
tango4
Same picture but the connector for the 3900 that he has is different. I am
trying to get a matching photo to the one he has
Ian
Old March 15th 04, 09:35 PM
John Ferguson
Thanks for your help with the pinouts, I have to admit
that I got my pin count wrong and have been trying
to use 12 (RTS) instead of 7. Found out by plucking
pins out of a plug until I was sure.
My plug is numbered like this
1 5 9 13 17 21
3 7 11 15 19
4 8 12 16 20
2 6 10 14 18 22
Hope the formatting is retained.
John
Old March 15th 04, 09:48 PM
tango4
I have plugs by 2 different manufacturers and neither of them has 4 rows of
pins!
Ian
"John Ferguson" . co.uk
wrote in message ...
1 5 9 13 17 21
3 7 11 15 19
4 8 12 16 20
2 6 10 14 18 22
John
Old March 15th 04, 01:17 AM
John Ferguson
Thanks Ian, unfortunately, you plug is a bit different
to mine. Yours has 5 pins in the top then two rows
of 6 then one of 5.
Mine has 6 pins in the top row then two rows of 5 and
a last row of six.
Has anyone managed to get one of these cables working
with a 5450 Ipaq ?
All help appreciated.
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 5th 03 12:45 AM
Commercial - iPAQ Cradles In Stock Paul Remde Soaring 0 October 29th 03 11:57 PM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 07:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 04:45 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 07:02 PM
