Apart from the *better* handling of a fixed tailplane,
is there any aerodynamic advantage of a fixed tail/elevator over an all flying tail? I can't help feeling that when the stick's not in the middle the fixed tail/elevator looks less efficient (And I used to prefer the light stick forces and not needing to constantly re-trim, when I flew a Cirrus, rather than the Discus I have to put up with these days - but NO I'm not offering to swap :-) ) Kevin |
Kevin Neave wrote in message ...
Apart from the *better* handling of a fixed tailplane, is there any aerodynamic advantage of a fixed tail/elevator over an all flying tail? Summarizing what Fred Thomas has to say about it, 1. The elevator tail is a flapped airfoil where the flap goes the "wrong" way: the elevator goes up for low speeds, but the tail needs to generate positive lift at low speeds; while the elevator goes down at high speeds, when the tail has a download on it. As a result, to keep an elevator tail operating inside its laminar drag bucket, it has to be bigger than an all-flying tail would have to be. Yes, the elevator tail is less efficient, as it appears. Score one for the all-flying tail. 2. Score a half for the elevator tail during a winch launch, because then there is a download on the tail during the launch, while the elevator is deflected upward (i.e., the airfoil flap is deflected the right way for once). 3. It's harder to design an all-flying tail to have "good handling," which translates into appropriate stick forces. An elevator, hinged at its leading edge, essentially trails in the breeze and contributes nothing to pitch stability, but the fixed portion of the tail keeps providing stability (of course trim can modify the "trailing" behavior of the elevator a bit, but you get the idea). If you hinge an all-flying tail at its leading edge, or anywhere ahead of its aerodynamic center, the whole thing contributes essentially nothing to pitch stability when stick-free: if you hinge it behind the a.c. then the control surface naturally deflects in the right direction, but the control deflection is unstable - if you're nose-high the tail will automatically go to a "down" control input, but it will go to a FULL down control input! There are lots of techniques available to improve the handling of an all-flying tail, but that's the heart of the problem. So it comes down to handling and efficiency during winch launches, I guess! |
| Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 01:33 AM |
| Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 08:33 PM |
| Announcing THE book on airshow flying! | Dudley Henriques | Military Aviation | 2 | January 7th 04 04:41 PM |
| Flying and the New Family | Marco Leon | Piloting | 33 | December 24th 03 07:11 PM |
| Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Home Built | 4 | July 26th 03 12:34 PM |
