I have some almost new mylar seals that are coming unstuck.
Last year I had my wings at the shop. They got a new coat of wax and new mylars were installed. I'm guessing the process of waxing and the sticking of the mylars became somewhat merged, hence my current problem. So now I'm going to attempt to reinstall or replace them myself. Is it ok to reuse mylars after proper cleaning? If so, how do you get them perfectly clean? Is acetone all I need? Do I need more than acetone and sandpaper to correctly prep the gelcoat of my wing before installing new mylars? I've heard silicone wash is recommended but have had no luck finding it locally. Can anyone recommend a source for silicone wash? Anyone have other recommendations or advice? Thanks, John |
Last year I had my wings at the shop. They got a new coat of wax and new mylars were installed. I'm guessing the process of waxing and the sticking of the mylars became somewhat merged, hence my current problem. So now I'm going to attempt to reinstall or replace them myself. Is it ok to reuse mylars after proper cleaning? If so, how do you get them perfectly clean? Is acetone all I need? Do I need more than acetone and sandpaper to correctly prep the gelcoat of my wing before installing new mylars? I've heard silicone wash is recommended but have had no luck finding it locally. Can anyone recommend a source for silicone wash? Anyone have other recommendations or advice? Thanks, John DO NOT PUT SILICONE ON YOUR GLIDER!!! It's a very bad idea with GRP. You have to get the wax off before fitting the seals - you can do this by sanding or using acetone. It is possible to refit the seals by using double sided tape Rgds, Derrick. |
Is it ok to reuse mylars after proper cleaning? Yes, remove them without bending (creasing) a hair dryer may help, then remove all the stickie stuff with acetone. get them perfectly clean? With acetone. Sand 10mm strip, inside area with 220, do same on wing area where mylar goes, then wipe everything down with acetone. I use a small roller to apply considerable force on the mylar to insure good bonding to the stickie stuff. Put on your transition tape and then wax. JJ Sinclair |
| Thread Tools | |
| Display Modes | |
| mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 03:52 PM |
| ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 04:45 PM |
| mylar seals | D.A.L | Soaring | 1 | February 23rd 04 08:15 PM |
| Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
| Mylar (again) | JJ Sinclair | Soaring | 0 | December 11th 03 11:40 PM |
