I need to do a short test run on my ventus 2cxm engine. The fuselage is on its cobra dolley in my garage, and I can wheel it into my driveway and tie the tail to a post. I'm nervous about this, in case there is some pitfall I haven't considered. Has anyone done an engine test run like this?
The fuselage may try to roll in the trailer cradle. Stabilize it so it can not do roll. Best and safest way is to install the wings for weight and stability.
Tom Boise, ID On Friday, November 24, 2017 at 11:44:35 AM UTC-7, wrote: I need to do a short test run on my ventus 2cxm engine. The fuselage is on its cobra dolley in my garage, and I can wheel it into my driveway and tie the tail to a post. I'm nervous about this, in case there is some pitfall I haven't considered. Has anyone done an engine test run like this? |
On Friday, November 24, 2017 at 1:44:35 PM UTC-5, wrote:
...Has anyone done an engine test run like this? Yes, and broken their canopy, run prop into trailer top, and other very interesting outcomes. Watch YouTube "Deep Fried Turkey Fire" instead; just as entertaining and much less expensive. |
On Friday, November 24, 2017 at 2:06:20 PM UTC-5, Dave Nadler wrote:
On Friday, November 24, 2017 at 1:44:35 PM UTC-5, wrote: ...Has anyone done an engine test run like this? I almost forgot: A well-known German manufacturer did this at the factory last year (mighta been 2015), and trashed the new glider and trailer bound for their USA dealer... Can't make this stuff up! |
At 19:09 24 November 2017, Dave Nadler wrote:
On Friday, November 24, 2017 at 2:06:20 PM UTC-5, Dave Nadler wrote: On Friday, November 24, 2017 at 1:44:35 PM UTC-5, wrote: ...Has anyone done an engine test run like this? I almost forgot: A well-known German manufacturer did this at the factory last year (mighta been 2015), and trashed the new glider and trailer bound for their USA dealer... Can't make this stuff up! Don't do it! I used to do this with a DG400 but I had a proper substantial steel frame to hold the fuselage (it anchored via the wing pins). Even with this system the whole procedure felt very unsafe, especially at full throttle; it also took far longer than driving to the airfield and rigging the glider properly. Dave W |
On Friday, November 24, 2017 at 11:09:47 AM UTC-8, Dave Nadler wrote:
On Friday, November 24, 2017 at 2:06:20 PM UTC-5, Dave Nadler wrote: On Friday, November 24, 2017 at 1:44:35 PM UTC-5, wrote: ...Has anyone done an engine test run like this? I almost forgot: A well-known German manufacturer did this at the factory last year (mighta been 2015), and trashed the new glider and trailer bound for their USA dealer... Can't make this stuff up! I've seen a fuselage-only engine test at Kirchheim, they have hard points outside the shop especially for it. Been present for some engine stand runs at Williams. Quite a nice rig Rex has, using the glider's engine controller, etc. with the engine out of the glider. I've done one run on the back of the trailer with ASH26E. Didn't take it to full power, seeing no need. A little forward of the normal rigging position on the trailer, using the trailer ramp as a chock, since the 26 landing gear swings forward of the doors. Saw horses with a 4x4 through the spar box for torque control. Worked as planned. But you're right to be nervous. The amount of pucker factor involved makes assembling the glider seem a better choice. While you're at it, keep the pilot current too. Jim |
On Friday, November 24, 2017 at 2:50:52 PM UTC-5, JS wrote:
On Friday, November 24, 2017 at 11:09:47 AM UTC-8, Dave Nadler wrote: On Friday, November 24, 2017 at 2:06:20 PM UTC-5, Dave Nadler wrote: On Friday, November 24, 2017 at 1:44:35 PM UTC-5, wrote: ...Has anyone done an engine test run like this? I almost forgot: A well-known German manufacturer did this at the factory last year (mighta been 2015), and trashed the new glider and trailer bound for their USA dealer... Can't make this stuff up! I've seen a fuselage-only engine test at Kirchheim Right, SH was not the manufacturer I mentioned above ;-) Though I can think of some of their customers who've damaged their plane/motor trying what the OP suggests... |
Don't do it!
/Users/randyteel/Desktop/DG 1001/1992-02-e Engine Test Run.pdf |
Don't do it! From DG...Never test run the engine without the wings assembled to the fuselage. Due to the engine torque the fuselage will tilt the with higher engine speed and roll to the front. "Mortal Danger"
I need to do a short test run on my ventus 2cxm engine. The fuselage is on its cobra dolley in my garage, and I can wheel it into my driveway and tie the tail to a post. I'm nervous about this, in case there is some pitfall I haven't considered. Has anyone done an engine test run like this? I have done winterising warm up runs many times like this, with a 2x4 through the spar box on saw horses; then I spray preservation oil into the Rotax carbs; as it is an M you have throttle control; stay away from full power. John F |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine Test Firing at the S-IB Static Test Stand 9808563.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:39 PM |
F-1 Engine Test Firing at the S-IB Static Test Stand 6335341.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:39 PM |
Looking for a motorglider with a rotax 505 engine near Detriot MI | Tim Taylor | Soaring | 0 | July 13th 04 07:16 PM |
Flying a motorglider without the engine? | Eric Greenwell | Soaring | 1 | September 23rd 03 05:38 AM |
