Recommendations for cataract surgery lenses for flying
Old March 20th 18, 03:51 PM posted to rec.aviation.soaring
teck48[_2_]
Default Recommendations for cataract surgery lenses for flying
I'm due for cataract surgery. Any good or bad experiences with lens implants for flying? Eye doc is recommending multi focus lenses (as opposed to mono focus). And a slightly different lens in each eye. Both multifocal, but dominant eye implant optimized for distance. Anyone have any experience? Thanks! –Tom
Old March 20th 18, 04:16 PM posted to rec.aviation.soaring
Retting
A few questions........age, type of flying you do...power,racing.
R
Old March 20th 18, 04:28 PM posted to rec.aviation.soaring
gkemp
That is just the type of cataract lenses I had and they were great for flying.
gkemp
Old March 20th 18, 07:41 PM posted to rec.aviation.soaring
Dan Marotta
I have single focus lenses and I have 20:10 distance vision.Â* I need
reading glasses for up close, however.
gkemp
Dan, 5J
Old March 20th 18, 07:48 PM posted to rec.aviation.soaring
jfitch
If you have not tried multifocal lenses, you may want to sample before you do something that is somewhat permanent. There are many multifocal contact lenses with different focal region strategies, I'd have the doctor recommend one similar to the lens and try it for a few days.
I have used multifocal contact lenses for a number of years and find that one in both eyes gives up more far vision than I would like. Multifocals trade far vision for near in general. Individuals adapt differently to these lenses, and some never adapt - that's why I'd say try before they cut.
Old March 20th 18, 09:22 PM posted to rec.aviation.soaring
teck48[_2_]
Thanks for the thoughts. I'm 65 and fairly active. I'm a hobby glider pilot.. And small dinghy sailor. I make videos and do a lot of computer and writing work.
I'm extremely near sighted but not astigmatic. I'm a fussy ******* about glasses, but once these replacement lenses are implanted it's a bit late to be fussy....
–Tom
Old March 20th 18, 10:49 PM posted to rec.aviation.soaring
Dan Marotta
As I mentioned earlier, I use cheap reading glasses, the kind you get at
the grocery store pharmacy.Â* I have 7 pair in the house, car, garage,
hangar, etc.Â* I also have THESE
https://www.amazon.com/Tifosi-Veloce-1040800186-Reading-Glasses/dp/B00EKERBU4/ref=sr_1_1?s=apparel&ie=UTF8&qid=1521586078&sr=1-1&nodeID=7141123011&psd=1&keywords=tifosi+bifoca l
sunglasses with clear vision lenses for distant vision and bifocal
readers built in.Â* I use them for driving and flying.Â* Very happy with them.
On 3/20/2018 3:22 PM, teck48 wrote:
Thanks for the thoughts. I'm 65 and fairly active. I'm a hobby glider pilot. And small dinghy sailor. I make videos and do a lot of computer and writing work.
–Tom
Dan, 5J
Old March 21st 18, 01:21 AM posted to rec.aviation.soaring
jfitch
–Tom
The multifocal contact lenses come with a prescription correction for far field vision, so they correct that at the same time. It should give you an idea of how your new lenses will work.
I wear one multifocal contact lens while flying or anytime I'm out and around. This lets me see the instrument panel, charts, phone, menu or whatever. My distance vision is still better than 20/20 with it in. The contact lens is a bit of a PITA (in, out, and care), so if I had cataracts I would do the multifocal lens replacement, but I'd shop carefully. I've tried about 5 different types of multifocal contacts, and some certainly worked better (for me) than others.
I've found a pair of sunglasses that I like for flying with or without the multifocal lens. The reason I like them over others I've tried is that the bifocal cheater can be ordered larger and higher than most (which covers the instrument panel better without the neck craning) and they are also available in gradient shading, which keeps from shading the instrument panel. They are available with a prescription correction if you need it.
https://flyingeyesoptics.com/product...on-rx-bifocal/
Old March 21st 18, 07:32 AM posted to rec.aviation.soaring
Peter Whitehead
The thread was regarding the possibility of using multi-focal INTRA-Ocular lenses at cataract surgery, not contact lenses.
I would suggest looking at the website www.allaboutvision.com and choose 'multifocal IOL's' to learn a bit more.
I am a family doctor, not an ophthalmologist, but as a glider pilot flying in the same sky as you, maybe one day, I might prefer that you opt for single focus lenses for distance vision. My understanding is that the clarity of distance vision is less good with multi-focal IOL's.
Good luck with your choice.
Old March 21st 18, 02:09 PM posted to rec.aviation.soaring
Retting
J Fitch was making a good suggestion to try multi-focal contacts BEFORE going under the knife. I tried multi-focal contacts and opted for mono-focal. I found the multi to be problematic, distracting. Distance vision field reduce. Flying Boeings and racing gliders, I wear tri-focals sunglasses ....Plano/1.0/2.0. 1.0 for the panel and 2.0 for the charts. Plano is no correction on top half of lense.
When I have cataract surgery, I will go with mono for the best possible distance vision. Since I always wear sunglasses, let those handle the ‘close in, reading’ issues.
Cheers,
R
Flying to Texas...recommendations? Jay Honeck Piloting 57 March 14th 07 10:19 PM
Cataract Surgery [email protected] Owning 3 June 22nd 06 07:02 PM
Recommendations for flying in Florida? Alan Finger Piloting 1 January 8th 06 09:46 PM
Cataract Jules Beaudoin Piloting 8 November 27th 03 11:36 PM
