LS6b and D (seperately) ittel FSG2T
Old July 20th 18, 09:38 PM posted to rec.aviation.soaring
Dan M
Default LS6b and D (seperately) ittel FSG2T
I recently purchased an LS6B and was hoping for some assistance working the kinks out of it before flying.
The canopy comes up and cocks off to (I think) the left. I was told this can be "shimmed." Indeed there were two rather large "nuts" near the base of the canopy that appear to adjust this.
I was hoping someone might be able to tell me the proper procedure for fixing this. I was thinking dive head first into the cockpit, have someone close and lock the canopy and then turn the two nuts until they're tight? But are they supposed to be staked or locked down in some way? Is it supposed to be adjusted with the canopy closed? Are washers supposed to be inserted to give the nuts something to wedge into?
As a side note, the ship cane with a Dittel FSG71M. I had a somewhat newer, spare FSG2T laying around (that I've never used). The two radios should be 100% plug-in compatible but when I swapped radios, the microphone didn't appear to work at all (this was probably the microphone settings) and the external speaker was significantly quieter. Any idea why the speaker may have been quieter on the 2T than the 71M? I can't tell that there is any other adjustment besides the volume knob on the 2T.
Old July 20th 18, 09:48 PM posted to rec.aviation.soaring
If canopy closes and latches right I would suggest not messing with it.
From painful experience making one fit after repair in the area.
UH
Old July 20th 18, 09:57 PM posted to rec.aviation.soaring
Ummmm.....yeah, if it latches fairly easily, don't mess with it.
If this is your biggest issue in Soaring life, maybe someone will link on how to make it better,
Old July 20th 18, 09:59 PM posted to rec.aviation.soaring
Dan M
UH
Could you elaborate on the concern? I had a friend hold the canopy mostly centered and just tightened one of the nuts by hand and it appeared to noticeably improve. It seemed like a proper repair should be pretty easy/straightforward.
Old July 20th 18, 11:22 PM posted to rec.aviation.soaring
Bob Kuykendall
I recommend you make precision templates of the left wing, then compare them to the right wing. That will give you something to worry about besides a minor asymmetry in canopy opening.
Or you could just fly and enjoy a ship that goes like stink and flies straight as an arrow despite its somewhat artisanal character.
--Bob K.
Old July 21st 18, 03:01 AM posted to rec.aviation.soaring
Brad[_2_]
the LS-7WL I flew for a few seasons suffered from "fishing lure" syndrome: someone left the canopy open on a windy day and by the time they realized the mistake it was wobbling in the breeze like a Dick Knight spoon. it did require some adjustments to the mounting hardware to realign with the latching pins. never was back to original condition, but it was/is manageable. keep those canopies CLOSED when you are away from the aircraft.
Old July 21st 18, 05:59 AM posted to rec.aviation.soaring
I keep wedge of soft foam rubber in the glider to help damp the "fishing lure" tendency. When I am rigging or doing stuff in the cockpit I wedge the foam between the forward canopy frame edge and the cockpit front coaming. Really helps in light to moderate breeze. In strong wind, the canopy is either closed or my hand is holding on to it.
Nice Dick Knight spoon reference Brad, but the Mepps Flying C spinner might be a more descriptive comparison should the canopy depart from the glider.
RC
F.S. Dittel FSG2T Set Ross[_3_] Soaring 1 March 1st 16 05:42 AM
FS: Dittel FSG2T Ross[_3_] Soaring 2 February 1st 16 06:32 AM
FS: Dittel FSG2T Romeozulu Soaring 0 March 31st 15 08:48 AM
LS6b for Sale - Canada Dave Springford Soaring 4 January 28th 13 03:53 PM
FS LS6b DaveSpringford Soaring 0 March 29th 04 02:38 AM
