Need Tost Standard Drum Brake Wheel that fits a 5.00 -5 tire. This will go on a DG400. Looks like it is standard on several other gliders.
The Spec are 125 x 20 for the bearing. Changed my brake pads and found out the drum material has some cracks. Looking for new or used but good shape. One not available at W&W or other vendors at present Thanks Kevin Anderson |
On Wednesday, March 27, 2019 at 4:42:29 PM UTC-7, wrote:
Need Tost Standard Drum Brake Wheel that fits a 5.00 -5 tire... Changed my brake pads and found out the drum material has some cracks. We've seen these cracks in several Tost 5" wheels, so it might be hard to find a used but uncracked wheel half. If your DG is licensed Experimental, we can set you up with a Matco disk brake unit that's much more effective than the Tost. --Bob K. |
Sounds interesting and I would like to explore some more. I emailed you my contact info. Please email yours and I will get in touch later today.
Have you converted a DG400 and how involved is the conversion? Others might be interested in the details also. Thanks Kevin |
Standard Jantar wheel brake assembly | [email protected] | Soaring | 9 | April 6th 19 02:34 AM |
Tost 5“Penta disk brake wheel Mod for Duo Discus | Mike I Green | Soaring | 0 | February 6th 12 09:38 PM |
FS Cobra brake drum w/new bearing | Hartley Falbaum[_2_] | Soaring | 1 | December 3rd 11 01:05 PM |
2-33 brake drum | [email protected] | Soaring | 2 | June 9th 07 02:22 AM |
Glider Drum Brake Rebuild | [email protected] | Soaring | 4 | January 17th 06 09:39 PM |
