Becker 4201
Old April 25th 19, 03:06 AM posted to rec.aviation.soaring
soaringjac
Default Becker 4201
Will the Becker 4201 run off 12v battery? Seems like it needs 14v
Old April 25th 19, 03:11 AM posted to rec.aviation.soaring
Dave Springford
Default Becker 4201
It will run from a 12V battery. Have used lead-acid 12 V 9 ah in the past and now use K2 LiFePo4 battery due to it's higher capacity.
Old April 25th 19, 03:23 AM posted to rec.aviation.soaring
soaringjac
Default Becker 4201
Great, Thanks Dave!
Old April 25th 19, 04:58 AM posted to rec.aviation.soaring
JS[_5_]
Default Becker 4201
Great, Thanks Dave!
Probably the only 57mm cutout radio that won't would be older versions of the Microair, featuring distorted transmissions when a 12v SLA is slightly low.
The Becker AR4201 has a secret weapon: The newer AR6201 is a direct replacement, plug and play.
Old April 25th 19, 01:56 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Becker 4201
Great, Thanks Dave!
I never noticed before that the specifications for the Becker AR4201's required supply ranges are;
Nominal supply voltage 13.75 V.d.c.
Supply voltage range 12.4 V to 15.1 V
While the Becker AR6201 has a MUCH more tolerant supply range;
Nominal supply voltage range .... 11.0 to 30.3 V
extended supply voltage range ... 10.25 V to 32.2V
That being said, I have successfully used TX/RX on a AR4201 with SLA and LiFePo4 batteries down to 12Vdc (and below but I imagine the TX range was reduced below 12Vdc). Just the other day one of my club's ship was able to power up with an (unknown) very low 8Vdc SLA battery ... which quickly died completely once we hit the PTT.
LiFePo4 batteries are highly recommended these days and well worth the extra $$$'s. My testing of LiFePo4 batteries shows a very flat voltage curve in the sweet spot around ~12.5Vdc after which the curve descends in a hurry following many hours of use. See https://groups.google.com/forum/#!to...ng/F2sS33W-d6M.
- John OHM Ω
Becker AR 4201 John Foster Soaring 15 October 6th 18 05:33 PM
FS: 5 Becker 4201 + 1 Becker 3201 + 1 Dittel FSG5 Handheld Ross[_3_] Soaring 10 April 4th 18 04:36 PM
FS: Becker 4201 5 Available Ross[_3_] Soaring 6 February 28th 17 06:56 AM
FS: Becker 4201 Romeozulu Soaring 0 March 7th 14 11:21 AM
FS: Becker AR 4201 Don[_4_] Soaring 0 September 19th 12 05:16 PM
