Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Headset conversion
Old February 19th 05, 02:58 PM
aol
Default Headset conversion
I have a couple of Davd Clarks given to me by my nephew, a former Air Force
loadmaster. I want to convert to use on civil aviation radios. As a former
engineer and ham radio operator I understand radio principles very well and
I am aware of the impedances of military com systems (5 ohm mics, 19 ohm
speaker). I am not that savy with civil aviation radios, however. I have
managed to easily convert the speaker side with impedance matching
transformer. I am also aware that the mic side is not just a simple
impedance matching issue. Does david clark have a mic element replacement
for the M87A/C boom mic that I can order without having to order a complete
conversion kit (for over $100 dollars). I know I would be just as well off
to get a headset off ebay but I want to waste my time with this useless
project for those rainy days when I can't fly the plane.
Cheers all
Bruce Stafford (KE5NT)
Old February 19th 05, 06:49 PM
Brian Whatcott
Cheers all
[I compacted the following from an "Avionics" article]
" There are applicable standards for cockpit audio, namely TSO-C50,
and DO-214 for signal guidelines.
Once upon a time, a microphone was a carbon element, with a 150-ohm
impedance (borrowed from the telephone industry). It required external
DC excitation of at least 8 to 12 volts DC to produce audio of about
150 millivolts (mV). Headsets and radio outputs had a 600-ohm
impedance and required at least 50 milliwatts (mW) of power to produce
acceptable levels. Both microphone and headset signals were normally
referenced to the airframe ground. If a speaker existed, it was
understood to have an impedance of 4 ohms and be driven at 5 watts.
Military operators adopted "noise canceling" microphones like the M87
and M101, which had a dynamic microphone (mic) element built like a
studio microphone. The M87 had an active diaphragm with balanced
openings on both sides of the mic housing. The concept has the voice,
mixed with ambient noise, entering one side of the diaphragm and
noise-only entering the other side. The noise cancels mechanically in
the diaphragm, and the resulting signal is voice only.
Dynamic self-excited microphones offered low impedance (about 5 to 8
ohms) but operated at low signal level (often under 1 mV).
A low-level microphone must be accompanied by a low-impedance headset
to keep drive voltages low. This established the 8- to 20-ohm standard
headset/dynamic microphone combination commonly used by the military.
.. Military users also adopted amplified dynamic microphones and
600-ohm headsets as an alternative. (The amplified dynamic mic has low
impedance but also a small outboard amplifier to make it work like a
"carbon equivalent" microphone.)
Military audio systems often had to support different mic and headset
standards within a single station (or audio box for each pilot). And
each user typically had his own station control within the aircraft."
Hope this helps
Brian Whatcott Altus OK
Old February 20th 05, 10:38 PM
aol
For the RST guy with the hard on - I asked J about the origin of the
headsets and he said he was asked to take them with him when he left the
service. He had used them for a number of years. So much for that. By the
way, I am a purple heart Vietnam veteran of the Marine Corps and not much
into stealing government property. The last poster is thanked immensely for
the good info. I have an idea I'm working on which I think will work but
since you have a least one dip**** on this forum I don't think I'll be back.
I've got better things to do than get ****ed of at "patriots."
"Brian Whatcott" wrote in message
Force
and
complete
Cheers all
Hope this helps
Old February 20th 05, 11:21 PM
RST Engineering
My apologies, sir, if I misstated the case.
I currently live within spitting distance of three Air Force bases, and
formerly within baseball throwing distance of three Navy bases and two
Marine Corps bases. I have been doing "do it yourself" avionics for over 35
years. The number of times I've been asked at a local meeting how to
convert "this helmet I just picked up out of the trash" number in the
dozens, if not the hundreds. I just don't believe that the military is
throwing away that much hardware, especially as some of the stuff I've seen
as "trash" has never been worn.
So if I lumped you in with all those goofballs, again, my apologies. To
make amends, tell you what I'm going to do. I'll email you my original
design for conversion of your headset if you will confirm receiving this
message. Can you receive attachments, and can you read .pdf files?
"aol" wrote in message news:1j8Sd.27608$Cs.7792@okepread02...
for the good info. I have an idea I'm working on which I think will work
but since you have a least one dip**** on this forum I don't think I'll be
back. I've got better things to do than get ****ed of at "patriots."
Old February 21st 05, 12:56 AM
Mike W.
My brother is currently in the Navy, beleive me the military is very
wasteful. He has brought home some things that were new (clothing mostly)
and he was told by superiors to 'make it go away, it's getting trashed'.
"RST Engineering" wrote in message
35
seen
David & Clark conversion? Greg Copeland Products 4 January 27th 05 12:52 PM
Panther C.A.T. headset. Ross Taylor Products 0 October 22nd 04 11:59 PM
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 03:47 PM
Bose makes good on my wife's headset. Kyler Laird General Aviation 3 March 10th 04 02:08 PM
Bose makes good on my wife's headset. Kyler Laird Piloting 3 March 10th 04 02:08 PM
