We are a group of three German aerobatic pilots seeking a Pitts S-1S,
preferably N-registered, with a 200 hp Lycoming. Regarding the Pitts, we are beginners. As every plane has its typical "teething troubles", we wish to get in contact with S-1S owners/sellers/pilots who are willing to offer their support. Perhaps we can avoid some of already-known beginner's mistakes!? Any advice would be highly appreciated with regard to: - Certification - Flying skills/training - Maintenance (AD's, mods, etc.) - Parts supply - Experience with options/upgrades (keywords: Wolf cowls, spring gear, Haigh tail wheel, Penn Yan, Hooker, etc.) Please e-mail to: Many thanks in advance! Sascha |
![]() Sascha Schott wrote: We are a group of three German aerobatic pilots seeking a Pitts S-1S, preferably N-registered, with a 200 hp Lycoming. Most S-1Ss are 180hp. I've been told the 200hp engine doesn't like being over rev'd, so it needs the CS prop. (All of the factory S-1Ss are 180hp and fixed pitch prop.) Any advice would be highly appreciated with regard to: - Certification Some are factory (standard CofA), some homebuilt. - Flying skills/training Lots of dual in a 2 holer with the right instructor. Mostly ciruits (pattern work). Can't help with the rest. I owned a share in one maintained by the local Pitts guru and he took care of that stuff. I believe that IAC has lots of Pitts maintenance info. Great fun, but a one purpose airplane, rick |
you mean you couldnt do 200nm in one from penn to boston and back ?
wrote in message oups.com... Sascha Schott wrote: We are a group of three German aerobatic pilots seeking a Pitts S-1S, preferably N-registered, with a 200 hp Lycoming. Most S-1Ss are 180hp. I've been told the 200hp engine doesn't like being over rev'd, so it needs the CS prop. (All of the factory S-1Ss are 180hp and fixed pitch prop.) Any advice would be highly appreciated with regard to: - Certification Some are factory (standard CofA), some homebuilt. - Flying skills/training Lots of dual in a 2 holer with the right instructor. Mostly ciruits (pattern work). Can't help with the rest. I owned a share in one maintained by the local Pitts guru and he took care of that stuff. I believe that IAC has lots of Pitts maintenance info. Great fun, but a one purpose airplane, rick |
![]() ODB wrote: you mean you couldnt do 200nm in one from penn to boston and back ? You could, but it wasn't much fun. Why, well... - The one I had a share in had a range of about 160nm, plus fuel reserve (cruised about 105knots @ 9gph and had a 16gal tank), so you'd do a fuel stop enroute, each way. (A coarse pitch prop might have allowed a 200nm non-stop. This one had a 56" pitch prop and did 120mph @ 2500RPM with the throttle about 1/3 open.) - It was fun to gas up. The tank opening was such that the big nossles on the fuel trucks didn't fit it. So, we carried this funky chunk of clear hose and had to convince the fuel truck guy to let us do it. (sometimes they refused and ended up spilling gas all over the place) - Then it had to be re-started. Ours didn't have a full electrical system, so that meant a hand prop (great fun when it's a hot fuel injected 180hp lyc) or a booster cable for 12 volt. (We had one with jumper clips, but I remember one guy getting hit with a $100 charge for the boost start.) You can avoid this with a full electrical system, but if you're serious about aeros, you don't want to be carrying a generator and battery around all the time. - You travel alone, with your head poking out a golpher hole. - Oh, and by the time you put the booster cable and gas hose in the baggage cubby hole behind your head, well, you were travelling with the clothes on your back. (Clean undies are way overrated:-) A great way to travel, so long as it's daylight and good weather. rick ps: So I almost never left the aerobatic box right on the airport. Lots of 0.3hr flights in my logbook. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Combat Related Special Compensation update for Sept. 8-12 | Otis Willie | Military Aviation | 0 | September 17th 03 03:38 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
