Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off!
At 03:59 01 February 2020, soaringjac wrote:
Just started using seeyou for the first time. I created some waypoints in s= eeyou and noticed the altitude shown for some of the waypoints are way off.= I double checked the exact same point in Google earth and the difference i= s about 1000'. This isn't the case for all custom waypoints I made, but it = is true for most of them. How are you guys creating accurate waypoints and = waypoint altitudes. Kind of crazy that seeyou is so off! Are you getting confused between metres and feet? See you will work in either and will convert between them. Paul |
On Saturday, February 1, 2020 at 1:00:05 AM UTC-8, Paul Ruskin wrote:
At 03:59 01 February 2020, soaringjac wrote: Just started using seeyou for the first time. I created some waypoints in s= eeyou and noticed the altitude shown for some of the waypoints are way off.= I double checked the exact same point in Google earth and the difference i= s about 1000'. This isn't the case for all custom waypoints I made, but it = is true for most of them. How are you guys creating accurate waypoints and = waypoint altitudes. Kind of crazy that seeyou is so off! Are you getting confused between metres and feet? See you will work in either and will convert between them. Paul its definitely showing me feet |
Hi,
I suspect that one of 2 things is happening. - You may be using a bad turnpoint database. I recommend the data found he http://cumulus-soaring.com/seeyou.htm#Downloads - If you are viewing a flight log, SeeYou can automatically use the take-off and landing elevations and the SeeYou ground elevation database to offset all the flight log points to account for barometric pressure changes. It is a very nice feature. You may want to check-out my SeeYou Tips document. http://cumulus-soaring.com/seeyou/SeeYou-Tips.pdf Best Regards, Paul Remde On Friday, January 31, 2020 at 9:59:13 PM UTC-6, soaringjac wrote: Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! |
On Saturday, February 1, 2020 at 7:14:46 AM UTC-8, Paul Remde wrote:
Hi, I suspect that one of 2 things is happening. - You may be using a bad turnpoint database. I recommend the data found he http://cumulus-soaring.com/seeyou.htm#Downloads - If you are viewing a flight log, SeeYou can automatically use the take-off and landing elevations and the SeeYou ground elevation database to offset all the flight log points to account for barometric pressure changes. It is a very nice feature. You may want to check-out my SeeYou Tips document. http://cumulus-soaring.com/seeyou/SeeYou-Tips.pdf Best Regards, Paul Remde On Friday, January 31, 2020 at 9:59:13 PM UTC-6, soaringjac wrote: Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! Thanks Paul! I am not using any turnpoint database and not viewing any flight log. I am just trying to mark some local landmarks as waypoints to put into my S100 vario. Im going to play around with it a bit more and see if i can figure out whats going on, but to me it seems like the see your elevations are not accurate. I guess i can always create the waypoints and then edit their altitudes based on the alt i get from google earth, which kind of sucks |
On Sat, 01 Feb 2020 07:38:03 -0800, soaringjac wrote:
On Saturday, February 1, 2020 at 7:14:46 AM UTC-8, Paul Remde wrote: Hi, I suspect that one of 2 things is happening. - You may be using a bad turnpoint database. I recommend the data found he http://cumulus-soaring.com/seeyou.htm#Downloads - If you are viewing a flight log, SeeYou can automatically use the take-off and landing elevations and the SeeYou ground elevation database to offset all the flight log points to account for barometric pressure changes. It is a very nice feature. You may want to check-out my SeeYou Tips document. http://cumulus-soaring.com/seeyou/SeeYou-Tips.pdf Best Regards, Paul Remde On Friday, January 31, 2020 at 9:59:13 PM UTC-6, soaringjac wrote: Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! Thanks Paul! I am not using any turnpoint database and not viewing any flight log. I am just trying to mark some local landmarks as waypoints to put into my S100 vario. Im going to play around with it a bit more and see if i can figure out whats going on, but to me it seems like the see your elevations are not accurate. I guess i can always create the waypoints and then edit their altitudes based on the alt i get from google earth, which kind of sucks Post one of the problematic turnpoints here so we can see what might be wrong. CUP files are just plaintext, so almost any program that can display a text file can display it for cut'n pasting - even Word. -- Martin | martin at Gregorie | gregorie dot org |
On Saturday, February 1, 2020 at 9:43:59 AM UTC-8, Martin Gregorie wrote:
On Sat, 01 Feb 2020 07:38:03 -0800, soaringjac wrote: On Saturday, February 1, 2020 at 7:14:46 AM UTC-8, Paul Remde wrote: Hi, I suspect that one of 2 things is happening. - You may be using a bad turnpoint database. I recommend the data found he http://cumulus-soaring.com/seeyou.htm#Downloads - If you are viewing a flight log, SeeYou can automatically use the take-off and landing elevations and the SeeYou ground elevation database to offset all the flight log points to account for barometric pressure changes. It is a very nice feature. You may want to check-out my SeeYou Tips document. http://cumulus-soaring.com/seeyou/SeeYou-Tips.pdf Best Regards, Paul Remde On Friday, January 31, 2020 at 9:59:13 PM UTC-6, soaringjac wrote: Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! Thanks Paul! I am not using any turnpoint database and not viewing any flight log. I am just trying to mark some local landmarks as waypoints to put into my S100 vario. Im going to play around with it a bit more and see if i can figure out whats going on, but to me it seems like the see your elevations are not accurate. I guess i can always create the waypoints and then edit their altitudes based on the alt i get from google earth, which kind of sucks Post one of the problematic turnpoints here so we can see what might be wrong. CUP files are just plaintext, so almost any program that can display a text file can display it for cut'n pasting - even Word. -- Martin | martin at Gregorie | gregorie dot org All you need to do to replicate is to make a waypoint in seeyou and note the elevation, then go to google earth or something similar and get the elevation for the same location. Most likely it is pretty different. In a couple cases for me its almost 1000' difference |
This is *not* what happens for typical users. If it did everybody would be screaming. So no us just going and trying is not going to help you because it works fine except as noted near fine resolution peaks etc. So again, just post the waypoints you are seeing errors for.
soaringjac wrote on 1/31/2020 7:59 PM:
Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! For what purpose will you use the waypoints? If it's for task planning, the correct elevation doesn't matter; if it's for potential landing places, you should not depend on SeeYou, but on a more accurate source. SeeYou is a flight planning tool, and it's your flight computer that needs elevation accuracy. I use official databases as my first choice; for landing places not in the official databases, I use databases from pilots I trust, sometimes from Google, perhaps topographic maps. I also plan to arrive higher at those landing places, partly because the elevation may not be known as accurately as airports on the charts. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Saturday, February 1, 2020 at 7:48:36 AM UTC-8, Eric Greenwell wrote:
soaringjac wrote on 1/31/2020 7:59 PM: Just started using seeyou for the first time. I created some waypoints in seeyou and noticed the altitude shown for some of the waypoints are way off. I double checked the exact same point in Google earth and the difference is about 1000'. This isn't the case for all custom waypoints I made, but it is true for most of them. How are you guys creating accurate waypoints and waypoint altitudes. Kind of crazy that seeyou is so off! For what purpose will you use the waypoints? If it's for task planning, the correct elevation doesn't matter; if it's for potential landing places, you should not depend on SeeYou, but on a more accurate source. SeeYou is a flight planning tool, and it's your flight computer that needs elevation accuracy. I use official databases as my first choice; for landing places not in the official databases, I use databases from pilots I trust, sometimes from Google, perhaps topographic maps. I also plan to arrive higher at those landing places, partly because the elevation may not be known as accurately as airports on the charts. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Just adding a couple local landmarks to my S100, mainly going to use to see if I have glide to the various waypoints. Not doing any XC or competition stuff. I might try some databases but it seems a bit overkill for now. I just want a couple local landmarks. |
| Thread Tools | |
| Display Modes | |
| LXNAV 8000 OAT Incorrect | Deming Gray | Soaring | 27 | December 13th 18 11:05 PM |
| Seeking help regarding SeeYou waypoint management | [email protected] | Soaring | 2 | February 16th 18 02:19 AM |
| Warning: GPS data incorrect | Cheetah236 | Instrument Flight Rules | 17 | September 23rd 05 08:50 AM |
| SeeYou to LX7000 Waypoint Task Files | Ken Kochanski (KK) | Soaring | 1 | May 28th 05 01:22 AM |
| Incorrect Coastlines..Channel Islands....HELP !!!! | Derek | Simulators | 0 | March 24th 05 12:50 AM |
