Flight plan and aircraft equipment
Old March 24th 05, 06:46 PM
Default Flight plan and aircraft equipment
When you file a flight plan or request flight following, and you have to
indicate how the aircraft is equiped I usually say /u because the plane
does not have a GPS unit. Now that I have the airmap 1000 and will be
flying with that, when contacting flight service can I say /g, or is that
only if the GPS is a fixed piece of equipment in the airplane?
Mike Flyin'8
PP-ASEL
Temecula, CA
http://flying.4alexanders.com
Old March 24th 05, 06:51 PM
Rod Madsen
Only if it is installed and is IFR approved (which the Airmap 1000 isn't)
Rod
Mike Flyin'8
PP-ASEL
Temecula, CA
Old March 24th 05, 06:56 PM
Cool. Thanks for the quick response! I noticed the section of the AIM
says /G must have "En Route and Terminal Capabilities"
What is that? I looked online and can not find what that means...
Rod
Mike Flyin'8
PP-ASEL
Temecula, CA
Old March 24th 05, 09:11 PM
Peter Clark
I believe it refers to the unit auto-changing the sensitivity on the
CDI (5NM - .3NM) when transitioning to (30NM radius of the
destination airport?) the terminal area and getting set up for an
approach.
Old March 24th 05, 09:20 PM
BTIZ
"Peter Clark" wrote in message
approach.
It also means that it has to be approved for IFR flight. Also read AC 90-94.
BT
Old March 24th 05, 09:39 PM
Steven P. McNicoll
For the purposes of a VFR flight plan or flight following, nobody cares if
it's fixed/portable or approved/unapproved.
Old March 24th 05, 09:53 PM
if it's fixed/portable or approved/unapproved.
So am I allowed to say /G when flying VFR when using the AM1000? I know
the reason for telling them is so they know you can accept direct routing.
For this scenario the AM1000 would work just fine, but in the AIM it says
something about "En Route and Terminal Capabilities" next to the /G
description.
Mike Flyin'8
PP-ASEL
Temecula, CA
Old March 24th 05, 10:01 PM
Newps
Yes.
I know
You're VFR, you won't be routed anywhere.
description.
They are talking about IFR ops.
Old March 25th 05, 01:50 AM
Bob Noel
In article , Newps
Yes.
really? It's ok to lie about the aircraft equipment? Or is that just
a quick way to get across the point that you have a VFR GPS without
having to tie up the frequency?
Bob Noel
looking for a sig the lawyers will like
Old March 25th 05, 03:48 AM
Happy Dog
"Newps" wrote in message
Yes.
No.
I know
routing.
Unless you're in controlled airspace.
Do you just make this stuff up as you go along?
moo
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
