HANDHELD RADIO
Old March 28th 05, 03:46 AM
Default HANDHELD RADIO
All,
I have been using a JRC JHP-500 handheld radio for field communications
and have been a bit disappointed with it's performance. It has a
standard 6" flex antenna. When I am in the air and someone tries to
talk with me using the handheld, the transmission always sounds very
weak, even if I am flying right over the top of them at the airport.
For all I know, the radio is fine and the real culprit may simply be
the antenna.
Any suggestions?
Any suggestions on other (stock) handheld transceivers that have worked
well for others that won't break the bank?
Old March 28th 05, 04:59 AM
BTIZ
Hint,... it's not the antenna... it's the radio... JRC = Japan Radio Corp...
Get an ICOM
BT
All,
the antenna.
Any suggestions?
Old March 28th 05, 07:04 AM
F.L. Whiteley
please read the following
http://www.icomamerica.com/downloads/cq-interview.pdf
"BTIZ" wrote in message
news:ViL1e.543$ZV5.432@fed1read05...
Corp...
Get an ICOM
BT
All,
the antenna.
Any suggestions?
Old March 28th 05, 08:08 AM
BTIZ
ok... I think we all knew that... but from what I read... ICOM is not JRC...
just cause ICOM is "made in Japan".. that does not make it JRC...
I did not see any affiliation to JRC in the article...
so.. whats your point?
BT
"F.L. Whiteley" wrote in message
Corp...
Get an ICOM
BT
All,
the antenna.
Any suggestions?
Old March 28th 05, 11:16 PM
F.L. Whiteley
just checking
JRC has a pretty good track record, but one or two bad experiences can be
disappointing.
YMMV,
Frank
news:h3O1e.565$ZV5.57@fed1read05...
JRC...
BT
Corp...
Get an ICOM
BT
All,
communications
the antenna.
Any suggestions?
worked
Old March 28th 05, 02:50 PM
COLIN LAMB
Interesting to see JRC trashed, as they are a respected manufacturer. Here
is a quote from "Receivers Past & Present":
"The Japan Radio Company was established in 1915 and is one of the oldest
and largest electronics manufacturing companies in the world. J.R.C. is a
respected leader in marine radio equipment ... and avionics."
The JRC line of radio receivers are considered top of the line.
Headquarters for Vertex, Icom and JRC are all in Japan.
If the radio is not transmitting properly, I would read the manual and check
the antenna and do not assume that it is the radio because it does not say
Icom. Icom and Vertex are sold in large quantities to hams and are more
well known than JRC here in the US, but that is simply due to marketing and
not quality.
Colin N12HS
Old March 15th 16, 04:34 AM posted to rec.aviation.soaring
JVC= Japan Victor Company, an old subsidiary of RCA - RCA-Victor
Even if you by an American radio it's probably A. Made in Japan or B. Manufactured with Japanese components.
But Icon is a good low to mid end radio, but if you're talking about a back-up radio that could be the difference of survival or not a couple dollars in your pocket sure won't do you any good when you're 8-10ft ASL on a some mountaintop!
Old March 28th 05, 06:00 AM
You might want to check the solder connection beneath the BNC
connector. It involves opening up the case, but it isn't too difficult
as long as you keep track of the tiny screws and different components.
A friend of mine had the performance of his JRC take a serious
downgrade, and he opened up the case and found a split solder
connection beneath the BNC connector, with a quick re-solder all was
fixed. Shortly after I had the exact problem and solution with my JRC.
It now works well!
Mike Reyes
All,
communications
the antenna.
Any suggestions?
worked
Boosting ICOM IC-A23 Handheld Aviation Radio CHANGE USERNAME TO westes Instrument Flight Rules 23 June 9th 04 12:41 PM
STS Handheld Radio Repair - USA Ray Lovinggood Soaring 3 April 25th 04 01:33 PM
Vertex VXA-150 Pro V handheld radio question Alan Meyer Soaring 2 April 24th 04 01:42 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
