VLD and max altitude
Old March 29th 05, 06:53 AM
Chris W
Default VLD and max altitude
Can someone tell me if my thinking is correct here. First VLD is the
speed where there is the least drag on the plane right? So it takes the
least amount of power to maintain level flight at VLD, any slower or
faster in level flight requires more power? Now suppose you are at an
altitude where the fastest speed you can maintain is VLD, would that
mean that the plane can't climb any higher? Also would that be a
reasonable way to determine VLD, (i.e. climb as high as you can and the
indicated airspeed at that altitude would be VLD)?
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
Old March 30th 05, 02:27 AM
Andrew Sarangan
You need two separate plots to discuss this issue. One is drag vs speed.
This is where the minimum L/D is defined. The other is power vs speed.
This is where the minimum power to maintain level flight is defined.
Chris W wrote in news462e.4423$Tn.2163@lakeread06:
Old March 30th 05, 03:51 PM
John T Lowry
"Chris W" wrote in message
news462e.4423$Tn.2163@lakeread06...
the least amount of power to maintain level flight at VLD, any slower
or faster in level flight requires more power? Now suppose you are at
an altitude where the fastest speed you can maintain is VLD, would
that mean that the plane can't climb any higher? Also would that be a
the indicated airspeed at that altitude would be VLD)?
Chris W
Has anyone mentioned that you can't GET to maximum altitude with finite
fuel and finite time?
John Lowry
Flight Physics
Old March 30th 05, 04:08 PM
Mike Rapoport
"John T Lowry" wrote in message
ink.net...
altitude where the fastest speed you can maintain is VLD, would that mean
that the plane can't climb any higher? Also would that be a reasonable
way to determine VLD, (i.e. climb as high as you can and the indicated
Chris W
John Lowry
Flight Physics
Max altitude is reached with minimium fuel right before the engine quits.
You certainly can't reach max altitude starting with zero or infinite fuel.
Mike
MU-2
Old March 30th 05, 07:55 PM
John T Lowry
"Mike Rapoport" wrote in message
ink.net...
ink.net...
the speed where there is the least drag on the plane right? So it
takes the least amount of power to maintain level flight at VLD, any
slower or faster in level flight requires more power? Now suppose
you are at an altitude where the fastest speed you can maintain is
VLD, would that mean that the plane can't climb any higher? Also
would that be a reasonable way to determine VLD, (i.e. climb as high
as you can and the indicated airspeed at that altitude would be
VLD)?
Chris W
finite fuel and finite time?
John Lowry
Flight Physics
quits. You certainly can't reach max altitude starting with zero or
infinite fuel.
Mike
MU-2
Von Mises, p. 416: "It can be seen by simple reasoning that the ceiling
altitude cannot be reached within a finite time."
John Lowry
Flight Physics
