Finding German Spec Rivet replacement
Old April 24th 20, 07:54 PM posted to rec.aviation.soaring
Default Finding German Spec Rivet replacement
I need to replace a rivet on my canopy latch on my LS-6. It is a DIN 7338 type B (semi tubular) 6mm diameter, with 15mm length from the drawing and emailing from DG. Its the rivet that handle pivots on when pushing the aft latch pin backwards. I think I can replace it with a bolt/washer/nut combo, but it won't look as nice, and I'd like to keep things to spec as possible.
I live in the USA, so its been a challenge from some googling, to finding german spec fasteners or american equivalents for a brake lining rivet with the needed dimensions. I can purchase the rivet from manufactures but I have to buy a minimum of 1000 rivets.
I was wondering if anyone had a source to buy a much more manageable amount of rivets, or if someone has found a good solution to a replacement since its the same latch used on LS-6/7/8.
Of course if someone has some extras around, I'd be happy purchase a couple and pay for shipping.
I understand the DG tax, and even if it was free, it still be a pain to get a replacement from DG since one rivet isn't close to their minimum for shipping something, for obvious reasons.
Old April 24th 20, 09:05 PM posted to rec.aviation.soaring
Those rivets also usually require a special tool to swage the end. Bushing,screw, and locknut may be an easier solution.
UH
Old April 24th 20, 10:40 PM posted to rec.aviation.soaring
RobKol
https://valleyfastener.com/rivets/semi-tubular-rivets/
Old April 29th 20, 07:55 AM posted to rec.aviation.soaring
6 mm is .23622 inches. The hole is likely "ovalized" so ream (not drill!) the hole to a 0.25 inch round hole and put an inch rivet in it. Inch tubular rivets are widely available.
You will also need tools: Rivet squeezer (likely require a pneumatic device for a steel rivet) and the proper "roll" die. Local A&P may have the tools and install the rivet for you. It is a skill. Unlikely most people would get it right the first time. The tools are expensive.
I would and have done what UH suggested: Bolt, bushing, and locking nut, if space allows.
Old April 29th 20, 03:05 PM posted to rec.aviation.soaring
I replaced the rivet with a 1/4” Cleve’s pin with enough washers to make it snug, keep it there with a carter pin.
JJ
Old April 29th 20, 04:10 PM posted to rec.aviation.soaring
JJ
Clevis pin. Cotter pin. Translated to English from whatever language was originally used.
Old April 29th 20, 07:09 PM posted to rec.aviation.soaring
JJ
Translated from Californian.
LOL
UH
Old April 29th 20, 10:17 PM posted to rec.aviation.soaring
OK, you guys..........a Clovis pin looks just like the hollow rivet, but it’s solid and has a hole in one end where a carter pin and at least one washer is used to secure the device in place. Aircraft Mechanics know all about these things! While we’re here........I remember a UK Airworthiness Directive that read “ With a torch in one hand and a spanner in the other hand, remove the xxxx”
Took me a week to figure out a “torch” was a flashlight and a “spanner” was a Crescent Wrench!!!
JJ.
Old April 29th 20, 10:22 PM posted to rec.aviation.soaring
As usual, JJ's idea is a good one. If you go this route, ensure you carefully band the cotter pin ends over very well and neatly. They have the strong potential to impale the user, if not. Get your tetanus shot!
Old April 29th 20, 11:38 PM posted to rec.aviation.soaring
As I recall, I unbolted the canopy locking handle from the canopy rail, inserted the Clovis Pin with the hole facing outboard and then bent the Carter Pin so as to make it look like a gigantic Smiley Face! Therefore, preventing pilot lacerations!
Anybody in need of translation?
JJ
PS, the handle was reinstated by holding the little nuts with needle - nose pliers and driving the screw from its other end on the seal side of the canopy rail!
Find a German Spec Rivet [email protected] Soaring 0 April 24th 20 07:53 PM
3x vs 4x rivet gun? Michael Horowitz Home Built 5 August 31st 08 02:30 AM
Mil-Spec and Mil-Spec kit? Michael Horowitz Home Built 6 October 11th 06 06:44 AM
A380 spec's G. Sylvester Piloting 30 January 21st 05 10:12 AM
mil spec Del Rawlins Home Built 2 March 21st 04 01:12 AM
