Hello all,
Short of looking through the docs of all the possible GPS' out there I am hoping I can get a general, if not, specific answer to the following. Do any of the handheld aviation GPS' have the capability to display location in UTM, MGRS, and different datums such as NAD 27 or WGS84? I suspect if they have that capability you'd be able to program waypoints via the same systems. Currently I am using a Garmin 12 XL which has and is serving me well. I just program the lat/long of the surrounding airports or the ones I am going to and viola. I can also use it while hiking or fishing. HOWEVER (there is always a however) today I was out flying and wanted to go to an airport I knew was close by but I did not have it programmed. This is where the aviation GPS would have helped. Thanks, Fred |
Hello Fred:
I have a number of handheld GPS units. I use them in search and rescue and they all have UTM, NAD27 and WGS84, plus a number of other options. Although I started out with the Garmin 12XL, I changed over to the Magellan, because the map versions were less expensive. The Magellan has a built in map. They also sell a topo CD, which can be downloaded to the GPS. The beauty of this particular program is that the entire United States is on one CD - which means large coverage of downloaded maps with limited memory in the GPS. And, this version of the topo has most of the airports right on the map. I think Garmin now has built in maps, but the Magellan is available for about $150. I can draw the desired locations on the computer and download to GPS quickly. The Magellan comes with a serial cable and uses 2 penlight batteries rather than the 4 in the older Garmin. Perhaps one minor glitch is that when I mark waypoints and upload to computer, it converts all to lat/long and strips off the UTM. Minor annoyance, though. Colin |
| Thread Tools | |
| Display Modes | |
| VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 06:03 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 10:40 PM |
| Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 02:26 AM |
| Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 01:14 AM |
