I think I finally tracked down the serial connector for 1520's & 30's.
www.mouser.com Part #656-DA1P018M91 which is JAE 18-pin wire to board connector DA1P018M91. $6.25 each. Can anyone confirm this is correct? Thanks. |
Certainly looks like the right part, correct number
of pins (18) and physical plug size. At 02:30 16 April 2005, wrote: I think I finally tracked down the serial connector for 1520's & 30's. www.mouser.com Part #656-DA1P018M91 which is JAE 18-pin wire to board connector DA1P018M91. $6.25 each. Can anyone confirm this is correct? Thanks. |
Compaq Aero 1500 Cradle | PENN2P | Soaring | 1 | October 18th 04 06:04 PM |
Aero 1520 serial plug pinout | Jon Marshall | Soaring | 5 | June 30th 04 01:07 AM |
