My LS8 has 'root rib vents': can I put a wing on the
ground after filling tanks without having water drip from the vent tubes? Manual states this is prohibited on LS8s fitted with 'winglet vents', but says nothing about my case. Thanks in advance, cheers Flavio |
Flavio Formosa schrieb:
My LS8 has 'root rib vents': can I put a wing on the ground after filling tanks without having water drip from the vent tubes? No. The vent tube will fill with water and (some of) that will run out when you level the wings again. It will run in to the fuselage and out the bottom of it if the wing gap is nicely sealed. Not a real problem but I'd avoid it anyway. Manual states this is prohibited on LS8s fitted with 'winglet vents', Because all the water would run in to the wing if the winglet gap is well sealed. At least the metal parts near the end of the wing would be in water. Not good. regards Marcel |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
C210 fuel tank vents | Eric Brown | Owning | 2 | September 27th 03 02:59 AM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
