Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Does an "IFR approved" GPS placard require database updates?
Old June 1st 05, 04:18 AM
Doug
Default Does an "IFR approved" GPS placard require database updates?
In regard to insurance, unless your insurance excludes it, you are
covered. So read your policy, paying close attention to the exclusions.
I can't imagine that a policy would exclude coverage for something like
that. All mine requires is the airplane be in annual at the anniversary
date of the policy and that I have a current medical. If, for example,
my annual expires or my medical expires, I am still covered so long as
I had them when the policy was initiated (the anniversary date).
You hear a lot of rumors about "insurance wont cover that". Most of
them quoted by people who never owned a plane and never read an
insurance policy.
Read your insurance. Does it say you have to comply with the minimum
equipment list to be covered? I would bet it doesn't.
Think about it. If your car had an expired inspection and you ran a
stop sign causing damage, do you think your car insurance would NOT
cover you?
Old June 7th 05, 07:33 PM
Jeroen Wenting
cover you?
Small difference.
Car maintenance isn't required by law (I know in many places a minimum
maintenance level for certain safety related things is required but nothing
requires you to have maintenance performed at set intervals).
For aircraft maintenance is required by law.
Old June 7th 05, 08:17 PM
Judah
"Jeroen Wenting" jwenting at hornet dot demon dot nl wrote in
cover you?
Small difference.
nothing requires you to have maintenance performed at set intervals).
In New York and New Jersey an inspection is required. Most cars must pass
inspection at least once every 12 months. I think some newer cars are
allowed longer...
If during the inspection it is determined that the car requires
maintenance, for example needs new brakes or has a broken taillight, it
will fail inspection unless the problem is repaired. In New Jersey, it's a
big hassle because the inspectors work for the DMV, and don't do repairs on
site. In New York, it's a bit easier because most service centers can get
certified as state inspectors. I'm not sure what state you are in that
doesn't require some sort of vehicle inspection, but then they don't let us
carry guns in NY either.
Old June 8th 05, 12:50 AM
Doug
Like I said, READ the policy. Only the policy itself will tell you. And
in general, if it is not excluded, it is covered. I gave you an example
of what MY policy says. Others may handle it differently. But insurance
is designed to cover mistakes. Insurance doesn't always require
compliance with laws for coverage. What if you ran a stop sign and ran
into someone and did damage with a car? Certainly you would be covered
(unless it is excluded). Would you buy car insurance that excluded
coverage if you broke the law? Even negligence is covered. It is
negligent to run a stop sign.
If you violate a FAR and have an accident, is the insurance invalid?
Mine is still valid. There is no exclusion for that. It is highly
likely that if you have an accident you will have violated some FAR.
The idea that insurance is invalid because the pilot violated a FAR is
one that you hear quite frequently. I think it is usually, not always,
wrong. Usually there IS coverage in spite of such an error.
Does an "IFR approved" GPS placard require database updates? Doug Instrument Flight Rules 7 June 11th 05 04:32 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
"Proceed on Course" = "Right turn approved"? Bob Chilcoat Piloting 41 July 18th 04 11:48 PM
Is AWC an approved weather source? Andrew Sarangan Piloting 1 June 26th 04 01:01 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
