LX90xx fln or flx file install for Flarm Contest ID?
Old May 24th 21, 02:13 PM posted to rec.aviation.soaring
CS[_2_]
Default LX90xx fln or flx file install for Flarm Contest ID?
Need help on how to install either the .fln or .flx file on the LX90xx, so that the contest ID from powerflarm traffic will show on the display.
Old May 24th 21, 02:27 PM posted to rec.aviation.soaring
Jeffrey Resnik
11.1.6 Uploading FlarmNet Files
The FlarmNet information is also updated via the SD card/USB stick. Go to the FlarmNet site (www.flarmnet.org), select the Download latest FlarmNet File tab and download the file for the LX8000 (e.g. 20170819.fln). Copy this file to the SD card.
In the Files and Transfer menu select the Update Databases menu item. Select the FlarmNet file and wait until the update completes.On Monday,
Also via the WIFI Module
Old May 24th 21, 08:05 PM posted to rec.aviation.soaring
CS[_2_]
Thanks, we tried that and the Lx9070 did not recognize either the 20210518.fln nor the converted (fln2flx) 20210518.flx file on the SD card.
Old May 25th 21, 04:27 AM posted to rec.aviation.soaring
Jeffrey Resnik
If of interest, I can forward the file that I used which was recognized by the LX9000 from the SD Card.
Old May 25th 21, 12:08 PM posted to rec.aviation.soaring
CS[_2_]
Thank you, I have sent my email address to you at both your mac and gmail accounts.
Old May 26th 21, 06:49 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
You should post this question to the LXNav user Google group.
https://groups.google.com/g/lxnav-user-group.
Old May 28th 21, 01:51 PM posted to rec.aviation.soaring
CS[_2_]
Different SD card solved our problem, thanks all for the suggestions.
LX90XX/80XX Training Videos Dave Springford Soaring 0 July 12th 20 01:24 AM
ETE calculation in LX90xx Pat Russell[_2_] Soaring 4 February 14th 20 01:36 PM
How did you install your FLARM brick and/or ADS-B Out? [email protected] Soaring 43 November 30th 19 05:14 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
If You've Flown a FLARM Stealth Contest, Vote Here [email protected] Soaring 143 December 24th 15 12:33 AM
