Is anyone aware of statistical or other data that would indicate what
percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Many of the small Lyc. engines have a TBO of around 2,000 hours. My O-320-D3G (TBO 2,000hrs) has now 2,200 hrs since new, it's never been opened for any reason. Of the above time, 1,100 hrs have been flown in my RV-6. I change oil (15W50) and full-flow filter every 50 hrs, cut-open the filter for inspection, and have the oil analyzed. The compression is still in the mid-70s. I plan to continue flying until any of oil analysis/compression/oil consumption would indicate a noticeable departure from their historic values. But the one other thing I worry about is the matter of metal fatigue, which would not be indicated by any of the factors that I am observing, but which could lead to engine stoppage. If you have any data to support using these engines past their TBO it would be much appreciated. |
The parts subject to fatigue (crank and rods) are generally not replace
during overhaul. Mike MU-2 "Wolfgang" wrote in message om... Is anyone aware of statistical or other data that would indicate what percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Many of the small Lyc. engines have a TBO of around 2,000 hours. My O-320-D3G (TBO 2,000hrs) has now 2,200 hrs since new, it's never been opened for any reason. Of the above time, 1,100 hrs have been flown in my RV-6. I change oil (15W50) and full-flow filter every 50 hrs, cut-open the filter for inspection, and have the oil analyzed. The compression is still in the mid-70s. I plan to continue flying until any of oil analysis/compression/oil consumption would indicate a noticeable departure from their historic values. But the one other thing I worry about is the matter of metal fatigue, which would not be indicated by any of the factors that I am observing, but which could lead to engine stoppage. If you have any data to support using these engines past their TBO it would be much appreciated. |
In rec.aviation.owning Mike Rapoport wrote:
: The parts subject to fatigue (crank and rods) are generally not replace : during overhaul. Right. They are inspected (magnafluxed, etc), but not replaced unless flawed. If they are flawed (read: cracked). A cracked rod/crank/cam is NOT going to live for 2000 hours and then die at 2050 hours. It's going to die much quicker than that. If it's worn much, it'll show up in the oil. If the engine isn't abused (long periods of sitting, excessively high temps cracking cylinders, subject to overly excessive thermal gradients, etc), it should run for a good while. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
"Wolfgang" wrote in message om... Is anyone aware of statistical or other data that would indicate what percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Many of the small Lyc. engines have a TBO of around 2,000 hours. My O-320-D3G (TBO 2,000hrs) has now 2,200 hrs since new, it's never been opened for any reason. Of the above time, 1,100 hrs have been flown in my RV-6. I change oil (15W50) and full-flow filter every 50 hrs, cut-open the filter for inspection, and have the oil analyzed. The compression is still in the mid-70s. I plan to continue flying until any of oil analysis/compression/oil consumption would indicate a noticeable departure from their historic values. But the one other thing I worry about is the matter of metal fatigue, which would not be indicated by any of the factors that I am observing, but which could lead to engine stoppage. If you have any data to support using these engines past their TBO it would be much appreciated. IMHO, piston engines will most often fail gracefully in that they give good indications of ill health well before outright failure. No guarantees, of course. But, it's pretty hard to find a generally smooth running engine with low oil consumption and good compression that has failed catastrophically. The above does not extend to accessories like magnetos and fuel systems which do fail suddenly and can result in an engine stoppage. It also assumes that you know the history of this particular engine and that it has enjoyed excellent maintenance without suffering any trauma like a prop strike. |
Wolfgang wrote:
Is anyone aware of statistical or other data that would indicate what percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Hours are not a good measure of the condition of an engine. I can tell you from having a relatively low time Lycoming blow on me in flight and seeing other engines go way past TBO even when subjected to student flight training. It's all a matter of how regularly it is flown and maintained. The club I was in had a 172 with something like 2400 SMOH on it (and it was over twice that much total time). The owner finally relented and had it overhauled because the flying club president was worrying too much. Remember that while the engine may still be going strong, the accessories (Bendix mags and the like) probably need more frequent attention. There comes a point when you got to take it down anyhow so you get the "might as wells" and open it up. |
Ron Natalie wrote: Wolfgang wrote: Is anyone aware of statistical or other data that would indicate what percentage of engines make it well beyond the factory specified TBO, and how much longer they can be flown safely? I worry about sudden engine failure due to metal fatigue. Hours are not a good measure of the condition of an engine. I can tell you from having a relatively low time Lycoming blow on me in flight and seeing other engines go way past TBO even when subjected to student flight training. It's all a matter of how regularly it is flown and maintained. The club I was in had a 172 with something like 2400 SMOH on it (and it was over twice that much total time). The owner finally relented and had it overhauled because the flying club president was worrying too much. Remember that while the engine may still be going strong, the accessories (Bendix mags and the like) probably need more frequent attention. There comes a point when you got to take it down anyhow so you get the "might as wells" and open it up. The big problem on Lycomings is not fatigue, but corrosion of the #1 & #2 cam lobes on engines infrequently flown. Moisture collects in the top of the forward part of the crankcase, which is where the cam is located; #1 & #2 cam lobes are right therre to get the moisture. Very often you will see those cam lobes worn down more than the others at overhaul. The engine will run, but power and smoothness will be degraded. |
"Orval Fairbairn" wrote in message
news ![]() The big problem on Lycomings is not fatigue, but corrosion of the #1 & #2 cam lobes on engines infrequently flown. Moisture collects in the top of the forward part of the crankcase, which is where the cam is located; #1 & #2 cam lobes are right therre to get the moisture. Prop acting as a heatsink? Cooler at the front due to airflow? Paul |
For corrosion and other reasons stated by other posters, there is also
a time limit of 12 years that Lycoming suggests as TBO. If the engine has not been torn down and inspected for 20 years, relying on hours only is risky. |
The limiting factor isn't generally crank/rod/ or other major
component fatigue (especially in those bullet-proof O-320s)but is probably corrosion and cam/lifter spalling. Oil analysis might catch either one. I doubt the factory has any info beyond that they would or even could release. From a strictly cumulative fatigue analysis standpoint there could have been an innocent relatively short term event in the engine life such as simply max throttle on a bitterly cold winter day that has done most of the fatigue damage. Or it could simply be long term operation at a wrong RPM where the crankshaft & prop are resonant. This type of "abuse" exists, but the wise ones (i. e. the certifiers) have decided and found that there is enough metal in this engine that it seems to be able to handle it. Hence for example there is no prohibited RPM range. Certainly the operating experience of a large fleet helps reinforce this. Whether that is true for precisely all supposedly identical engines and all conditions is impossible to say, but the history on this engine series is probably the best in the business. But engineering is an art, not a science. As one (mechanical) I can understand why the factory is reluctant to say to keep operating it. I have an O-320 E2D in a 172M last assembled over 29 years ago, & now at 1700 hrs TTSN. It has been opened only slightly for the oil pump gear AD, but otherwise it has shown no deterioration in compression, smoothness, or oil consumption over its lifetime. I'd like to think I have run it pretty carefully, but I realize I am running a slight chance. On the other hand, seeing the occasional AD show up on newly manufactured parts scares me too. The comfort I have is that I personally know the entire history of its operation. My decision is to keep operating it. Our IA once mentioned a Citabria in fish spotting duty out over the Atlantic that had 3800 hrs on it without overhaul. Unfortunately the limits of technology has to make it your call. But others are doing it too. |
| Lycoming engines "code" | Philippe | Home Built | 3 | September 11th 04 03:25 AM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
