Went out the the airport to carve up some air this afternoon in the Archer.
During the preflight, I noticed that I could get almost no flow from the right sump drain. Was concerned that if the sump drain was blocked, there might be stuff in the tank that could also block the fuel line or pickup. However, I was only going up for an hour or so, had plenty of fuel in the left tank, so I didn't use the right tank unless I was at least 2,000' AGL. Shot three landings at three different airports, and had a nice time, although with 100 degree temps and a density altitude of well over 2,000', I was drenched after an hour of this. Oh well, an uncomfortable hour in the air is better than any hour at work. After parking the plane, one of my partners turned up, and I showed him the drain cock problem. "Oh, yeah", he says. "I had that two days ago as I was getting ready for an Angel Flight. Showed it to John (our A&P) who said it was probably a spider building a nest inside the drain cock. I eventually got a spider out in the drain jar". Sure enough, probing inside with a piece of wire dislodged a lot of organic crap (but no spider), and the fuel flows freely again. My partner had cleaned it out once, so there are apparently more than one of these little *******s building nests. Where else can they be crawling? -- Bob (Chief Pilot, White Knuckle Airways) |
I more commonly see dirt daubers (little black wasp-looking critters).
Those things can completely plug a tank fuel drain with mud while you are inside eating a hamburger. Heck, that's what the pre-flight is for! |
I'm surprised the fuel flowing out didn't dislodge it. I get a pretty good
flow out if my Warrior's sumps when the tanks are full. I suppose they can clog the pitot/static holes and the fuel overflow as well. You didn't happen to take a digital photo, did you? "Bob Chilcoat" wrote in message ... Went out the the airport to carve up some air this afternoon in the Archer. During the preflight, I noticed that I could get almost no flow from the right sump drain. Was concerned that if the sump drain was blocked, there might be stuff in the tank that could also block the fuel line or pickup. [snip] Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
The spider had apparently already been dislodged by the time I got there (as
I mentioned, my partner had had some problems the day before). However, digging with the probe of my fuel tester, I was able to get a number of sticky things out that were probably spider eggs. Eventually, the fuel flow flushed everything out, but it took several tries. -- Bob (Chief Pilot, White Knuckle Airways) "Marco Leon" mmleon(at)yahoo.com wrote in message ... I'm surprised the fuel flowing out didn't dislodge it. I get a pretty good flow out if my Warrior's sumps when the tanks are full. I suppose they can clog the pitot/static holes and the fuel overflow as well. You didn't happen to take a digital photo, did you? "Bob Chilcoat" wrote in message ... Went out the the airport to carve up some air this afternoon in the Archer. During the preflight, I noticed that I could get almost no flow from the right sump drain. Was concerned that if the sump drain was blocked, there might be stuff in the tank that could also block the fuel line or pickup. [snip] Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Archer Tach Red Arc | Greg Esres | Owning | 15 | February 9th 05 08:28 AM |
M20 Air/Oil separator | Jay Honeck | Owning | 70 | September 3rd 04 06:34 PM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Looking for user comment : Oil Sump Heater | Javier Gorordo | Owning | 8 | December 2nd 03 01:33 PM |
sump drain cleaning | Mike Noel | Owning | 15 | August 15th 03 02:41 AM |
