My Continental 85 is leaking oil and appears to be from pushrod tubes and
valve covers. It is on an experimental plane. While I can cure the one leaking valve cover, the pushrod tubes have those heavy "wirecircles with two tangs" over the rubber end fittings. Some tubes are leaking at bottom and others at top with no discernable pattern to the leak locations. Are there any after-market clamps (installable like a hose clamp hopefully) that would be able to replace the originals? Is there any "non-teardown" fix? Wondering along the line of front wheel drive vehicle axle constant-velocity joints and the split-boots sometimes used. I did notice that the intake tubing joint rubber fittings had substantial screw clamps. However they don't appear to be workable for the tubes. Would appreciate some thoughts, thanks,Dick |
As it's experimental you might be able to get away with something you make.
There are aftermarket VW pushrod tubes that screw together to install and then unscrew into position and clamp against their ends and their rubber grommets rather than the head off routine required with standard tubes. You then reinstall the pushrod. Don't know how these would compare to the Continental engine. Hope this helps, Peter "Dick" wrote in message om... My Continental 85 is leaking oil and appears to be from pushrod tubes and valve covers. It is on an experimental plane. While I can cure the one leaking valve cover, the pushrod tubes have those heavy "wirecircles with two tangs" over the rubber end fittings. Some tubes are leaking at bottom and others at top with no discernable pattern to the leak locations. Are there any after-market clamps (installable like a hose clamp hopefully) that would be able to replace the originals? Is there any "non-teardown" fix? Wondering along the line of front wheel drive vehicle axle constant-velocity joints and the split-boots sometimes used. I did notice that the intake tubing joint rubber fittings had substantial screw clamps. However they don't appear to be workable for the tubes. Would appreciate some thoughts, thanks,Dick |
On Wed, 17 Nov 2004 12:03:14 GMT, "Dick" wrote:
Real Gaskets Corp. makes an STC'd retrofit pushrod tube replacement kit that you can install without removing the cylinders. You pull the pushrods, remove the old tubes by cutting them in half with a Dremel / cut-off wheel or whatever and the new ones go in with a spring ala a Continental O-470 style pushrod tube. I have a kit on my C-145 and am happy with it. See: http://www.realgaskets.com/files/horizontal.htm It's part # RG-200PRT-1 Bela P. Havasreti My Continental 85 is leaking oil and appears to be from pushrod tubes and valve covers. It is on an experimental plane. While I can cure the one leaking valve cover, the pushrod tubes have those heavy "wirecircles with two tangs" over the rubber end fittings. Some tubes are leaking at bottom and others at top with no discernable pattern to the leak locations. Are there any after-market clamps (installable like a hose clamp hopefully) that would be able to replace the originals? Is there any "non-teardown" fix? Wondering along the line of front wheel drive vehicle axle constant-velocity joints and the split-boots sometimes used. I did notice that the intake tubing joint rubber fittings had substantial screw clamps. However they don't appear to be workable for the tubes. Would appreciate some thoughts, thanks,Dick |
![]() "Bela P. Havasreti" wrote in message ... On Wed, 17 Nov 2004 12:03:14 GMT, "Dick" wrote: Real Gaskets Corp. makes an STC'd retrofit pushrod tube replacement kit that you can install without removing the cylinders. You pull the pushrods, remove the old tubes by cutting them in half with a Dremel / cut-off wheel or whatever and the new ones go in with a spring ala a Continental O-470 style pushrod tube. I have a kit on my C-145 and am happy with it. See: http://www.realgaskets.com/files/horizontal.htm It's part # RG-200PRT-1 Bela P. Havasreti Real gaskets are out of sight. I make my own from silicone sheet. You can too and save 8 bucks apiece or just use the right kind of stock gaskets and a high-quality gasket seal on the valve covers. Cross-tighten evenly and not too much torque. 20-30 inch-pounds is usually enough. 480 bucks for pushrod tubes? Outrageous. Unless you have money to burn. No offense to Bela, of course. Just re-swage the old ones on the cylinder ends. It can be done without removing the jugs. If the leaks are around the pushrod tube bosses on the crankcase, I'd still pull the jugs and replace the boots to save $80 per cylinder. Buy you some good clamps. I use spring clamps. I have never seen a boot get old and wear out, but then I guess everything is mortal. Even Barnyard Boob. |
On Wed, 17 Nov 2004 12:45:51 -0500, " jls"
wrote: "Bela P. Havasreti" wrote in message ... On Wed, 17 Nov 2004 12:03:14 GMT, "Dick" wrote: Real Gaskets Corp. makes an STC'd retrofit pushrod tube replacement kit that you can install without removing the cylinders. You pull the pushrods, remove the old tubes by cutting them in half with a Dremel / cut-off wheel or whatever and the new ones go in with a spring ala a Continental O-470 style pushrod tube. I have a kit on my C-145 and am happy with it. See: http://www.realgaskets.com/files/horizontal.htm It's part # RG-200PRT-1 Bela P. Havasreti Real gaskets are out of sight. I make my own from silicone sheet. You can too and save 8 bucks apiece or just use the right kind of stock gaskets and a high-quality gasket seal on the valve covers. Cross-tighten evenly and not too much torque. 20-30 inch-pounds is usually enough. 480 bucks for pushrod tubes? Outrageous. Unless you have money to burn. No offense to Bela, of course. Just re-swage the old ones on the cylinder ends. It can be done without removing the jugs. If the leaks are around the pushrod tube bosses on the crankcase, I'd still pull the jugs and replace the boots to save $80 per cylinder. Buy you some good clamps. I use spring clamps. I have never seen a boot get old and wear out, but then I guess everything is mortal. Even Barnyard Boob. No offense taken.... I hear ya (and for the most part agree). I bought the re-swaging tool from (I think) El Reno aviation, and re-swaged all the pushrod tubes on the left side (port side for you mariners) of my C-145-2, but one cylinder still leaked. So I only bought (1) Real Gaskets pushrod tube kit to fix that 1 cylinder (I was tired of it leaking). I wish the kits weren't so expensive. I have no affiliation what-so-ever, but still think it is a superior design than the original (Continental finally fixed their pushrod tube design faux pas with the O-470). A friend just rebuilt a C-85 and sprung for RG pushrod tube kits for all 4 cylinders. I'm sure he didn't particularly like writing the check, but wanted to make the engine more serviceable while it was all apart.... 1000 hours down the road or whatever, it'd be nice to just compress the spring, pull the offending pushrod out and replace the seals to fix any future leaks. Bela P. Havasreti |
As food for thought...
seeing the spring loaded pushrod tube referenced by Bela makes me wonder if some kind of external spring could be installed over a tube (without removing the tube) and press against some sort of seal applied linearly at both ends; kind of like teflon string (as opposed to tape) that plumbers use. just changed the toilet inlet valve and saw the shank washer just seal the valve body with finger tightness.. if not a spring, how about some sort of clamp over the tube that would hold the hand fabbed string gasket tightly in place? Since this is an experimental, what does everyone think?? thanks, Dick http://www.realgaskets.com/files/horizontal.htm It's part # RG-200PRT-1 |
PLEASE don't do it this way. Remove them the old-fashioned way. Cut that tube
off with a saw and I guarantee you chips in the oil pan. Not good. Jim You pull the -pushrods, remove the old tubes by cutting them in half with a Dremel / -cut-off wheel or whatever and the new ones go in with a spring ala a -Continental O-470 style pushrod tube. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() "Jim Weir" wrote in message ... PLEASE don't do it this way. Remove them the old-fashioned way. Cut that tube off with a saw and I guarantee you chips in the oil pan. Not good. Jim Couldn't one push a piece of cloth rolled in a ball down the tube, past where it is to be cut, and contain the shavings? Don't jump me, it is just an idea; wondering if it would work. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.797 / Virus Database: 541 - Release Date: 11/15/2004 |
On Wed, 17 Nov 2004 17:36:03 -0500, "Morgans"
wrote: "Jim Weir" wrote in message .. . PLEASE don't do it this way. Remove them the old-fashioned way. Cut that tube off with a saw and I guarantee you chips in the oil pan. Not good. Jim Couldn't one push a piece of cloth rolled in a ball down the tube, past where it is to be cut, and contain the shavings? Don't jump me, it is just an idea; wondering if it would work. I'll see if I can find the original instructions, but I think that's how they suggest you do it. If I find the instructions, I'll post back what it says. What I did is use vise grips to collapse the tube near the outer end (where it enters the rocker arm area). The metal is fairly soft, and easy to deform. A small cut-off wheel on a Dremel makes quick work out of cutting the tube in two at about the same location. There are no metal chips scattered anywhere with this method, just a small amount of residual aluminum and abrasive wheel dust associated with the cutting process. Bela P. Havasreti |
On Wed, 17 Nov 2004 23:19:08 GMT, Bela P. Havasreti
wrote: On Wed, 17 Nov 2004 17:36:03 -0500, "Morgans" wrote: "Jim Weir" wrote in message . .. PLEASE don't do it this way. Remove them the old-fashioned way. Cut that tube off with a saw and I guarantee you chips in the oil pan. Not good. Jim Couldn't one push a piece of cloth rolled in a ball down the tube, past where it is to be cut, and contain the shavings? Don't jump me, it is just an idea; wondering if it would work. I'll see if I can find the original instructions, but I think that's how they suggest you do it. If I find the instructions, I'll post back what it says. What I did is use vise grips to collapse the tube near the outer end (where it enters the rocker arm area). The metal is fairly soft, and easy to deform. A small cut-off wheel on a Dremel makes quick work out of cutting the tube in two at about the same location. There are no metal chips scattered anywhere with this method, just a small amount of residual aluminum and abrasive wheel dust associated with the cutting process. If it is thin enough to bend with visegrips, could you cut it with a set of large bolt cutters? |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Flight test report and intake leak question | nauga | Home Built | 11 | April 12th 04 04:12 PM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Zenith Zodiac XL question | Mick | Home Built | 4 | January 14th 04 05:47 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
