Becker 4404-1 Transponder Behaviour
Old July 16th 05, 11:52 PM
Ian
Default Becker 4404-1 Transponder Behaviour
Hi
A question for those who fly with Becker 4401-1 transponders.
Normally the "Reply Indicator" triangle on the display of our transponder
flashes briefly when the unit is interrogated, but otherwise it remains
off.
Today I noticed today that it was displayed continuously. This was
when I was at low altitude and the transponder was shielded from ATC
radar by a mountain. When I climbed higher it seemed to behave more
normally, but still displayed for several seconds on some occasions.
Is this normal behavior for this unit that I have just not noticed before,
or has ours developed some kind of fault?
I can't help thinking that a continuously "Reply Indicator" implies
continues transmission, which can't be healthy.
Thanks
Ian
Old July 17th 05, 08:03 PM
Gary Evans
Mine only responds to ATC queries, which increase or
decrease in relation to distance. If yours sends replies
when out of ATC range I would suspect the unit.
At 08:54 17 July 2005, Ian wrote:
Hi
Normally the 'Reply Indicator' triangle on the display
of our transponder
off.
This was
shielded from ATC
to behave more
some occasions.
not noticed before,
I can't help thinking that a continuously 'Reply Indicator'
implies
Thanks
Ian
Old July 18th 05, 04:22 PM
bumper
Transponders will also reply to TCAS interrogations, even when out of ATC
radar range. Putting the glider in a metal hangar or glider trailer should
adequately "shield" the transponder. If it replies then, I'd think you have
a problem. Easy approach would be to just fly with it for awhile and see if
it returns to the behavior you expect (g).
bumper
"Gary Evans" wrote in message
Hi
of our transponder
off.
This was
shielded from ATC
to behave more
some occasions.
not noticed before,
implies
Thanks
Ian
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Home Built 0 August 6th 03 04:21 AM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Owning 0 August 6th 03 04:21 AM
