Best spark plug cleaning tool?
Old August 7th 05, 03:26 PM
Jim Burns
Default Best spark plug cleaning tool?
Various size jewellers screwdrivers and one of these
http://cgi.ebay.com/ws/eBayISAPI.dll...tegory=22 660
Jim Burns
Old August 7th 05, 02:18 PM
Dan Luke
"Peter" wrote:
What do people use for this?
Dental picks are perfect; you can get them in all sorts of shapes.
http://www.indigo.com/tools/gphtools/dental-picks.html
Old August 7th 05, 08:46 PM
David Lesher
I found a small 12vdc power sandblaster at a hamfest once; is sandblasting
a good technique for aviation plugs?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old August 8th 05, 03:20 AM
George Patterson
We used one at the Esso station I working in as a teenager. The shop at Kupper
airport used one that looked an awful lot like it.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 8th 05, 06:00 AM
private
"Peter" wrote in message
Hi All,
I am looking for something for digging out the lead deposits from the
bottom plugs on an IO-540.
A friend has a very old tool which looks like a swiss army knife, but
instead of the knife blades it has a number of hard steel rods, about
3" long and varying in diameter from 1mm to about 2mm. They are
serrated along their length. I am not sure if this tool was ever
intended for cleaning plugs but it works very well.
snip
It sure sounds like a welder's oxy-acetylene torch tip cleaner. They are
not expensive and are available at most welding suppliers. The serrations
start about 1/4" from the end, I would suspect they would work even better
for cleaning plugs if these non serrated tips were cut off as it would allow
the cleener portion to reach right to the bottom of the plug.
Old August 10th 05, 07:08 AM
nuke
This works pretty good, I have one:
http://www.aircraftspruce.com/catalo...theleadout.php
Run it off a little inverter you can plug into a cigarette lighter in
your car or truck.
Peter wrote:
Hi All,
Obviously one needs to be careful to not damage the ceramic insulator
(these are Champion iridium fine wire plugs).
What do people use for this? It has to be portable, so mains powered
plug cleaners aren't really suitable, and also I don't think they get
the real deposits out.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Spark plug question for Archie John S Home Built 0 February 17th 05 06:56 PM
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
Vintage spark plug Robert Eagle Restoration 0 November 30th 04 08:57 PM
Pilot/Owner Signoff for spark plug maintenance? John Clonts Owning 3 September 14th 04 11:08 AM
Q: Spark Plug Life john smith Owning 7 August 15th 03 05:11 PM
