Thinking about handicapping contest weather
Old August 16th 05, 03:31 PM
Bill Daniels
Default Thinking about handicapping contest weather
I've been replaying on-line contest .IGC files with Henryk Birecki's
"GPS_LOG WinCE". (This is a training function to learn Henryk's software)
It's possible to set the software so auto-select the McCready number based
on actual thermal strengths. Other software can do the same thing.
The average M number is a pretty good way to determine how good the day was.
For example, one day might be a M= 6.1 and the result is some very long,
fast flights. Another might be a M=2.2 and shorter and slower flights
result.
My thought is that it might be possible to run the day's contest results
through similar software to determine the average M number and use that
number to handicap the weather in addition to handicapping the gliders.
This is a simplistic way to reduce the day's soaring weather to a single
number.The result would be to make the contest more equal for different
gliders.
That would interest me because my Nimbus 2C is not competitive with it's
handicap in strong weather since the US Sports Class disallows water
ballast. On the other hand, smaller gliders are not competitive in weak
weather where the unballasted Nimbus is at it's best. Canceling WX effects
could make the Sports Class more attractive.
Thoughts?
Bill Daniels
Old August 16th 05, 04:43 PM
result.
gliders.
Thoughts?
Bill Daniels
Do you mean that every glider will have to a weather handicap value for
each strength of weather? In your example your Nimbus needs a
"favourable" weathercap on strong days and the smaller gliders need
their favourable number on weak days.
What I'd like is a handicap calculation that allows my small glider to
score top points when I land out trying to cross those reeeeeally big
blue gaps that only your big wings can handle :-)
Martin, UK
Old August 17th 05, 02:12 AM
Bill Daniels
software)
based
was.
result.
gliders.
effects
Thoughts?
Bill Daniels
Well, I was sort of heading toward the idea of letting a computer look at
all the competitors .IGC files to get a "power number" for the day. This
would be a number related to the average strength of the thermals
encountered during the time window from opening the start gate to the close
of the task. This number would then be used, after the fact, as it were,
to alter the glider handicap table so as to make it fair for the day.
The competitors collective .IGC files contain a lot of information about the
soarability of the day. There might be a way to extract these data for
weather handicapping.
No doubt, someone has thought of this.
Bill Daniels
Old August 16th 05, 05:52 PM
Shaun McLaughlin
handicap value for
needs a
'favourable' weathercap on strong days and the smaller
gliders need
my small glider to
reeeeeally big
Martin, UK
Alot like AAT's then- great in theory- until you landout!
On topic, this was done at the British Overseas Nationals.
Results he
http://www.soaringclub.com/Framesets...BONnewstxt.htm
Shaun
Old August 16th 05, 07:19 PM
Don Johnstone
Rather than create a new handicap system how about
making the current one fairer.
For example ASW17 Glide angle 48:1 Max water with pilot
64lbs or 3 galls a side and a handicap of 106
LS8(18) Glide angle 48:1 Max water a lot handicap 106
ASW28 Glide angle 45:1 Max water even more handicap
100
and this is fair? Both the LS8 and ASW28 can fly at
warp speed and have a definite advantage in all conditions
because of their ability to loose weight.
Perhaps we need to start handicapping for weight carried
in excess of mauw (dry) or perhaps make the max handicap
100 but then again I suppose this would not give new
gliders an advantage so they would not be worth buying
any more although I did hear it said last week that
an ASW28 goes like greased weasel turd off a shiny
shovel.
At 15:48 16 August 2005, wrote:
Henryk Birecki's
'GPS_LOG WinCE'. (This is a training function to
the same thing.
is some very long,
and slower flights
result.
the gliders.
weather to a single
equal for different
gliders.
disallows water
competitive in weak
Thoughts?
Bill Daniels
handicap value for
needs a
gliders need
my small glider to
reeeeeally big
Martin, UK
Old August 17th 05, 04:12 AM
Steve Leonard
Of course, this thought goes to pot on a ridge day
like you will have at Mifflin, PA, or New Castle,
VA. Or a wave site like Omarama. And it may get seriously
flawed on an 'endless streets' day at a site like Uvalde.
Best bet is just take what you've got and go have fun.
Steve Leonard
Old August 17th 05, 06:11 AM
Andy Blackburn
Henryk Birecki's
learn Henryk's
software)
the McCready number
based
do the same thing.
how good the day
was.
is some very long,
and slower flights
result.
the gliders.
weather to a single
equal for different
gliders.
disallows water
Canceling WX
effects
Thoughts?
Part of the problem in accomplishing this is that a
large part the average climb for the day is influenced
by the individual pilot. I've seen two pilots flying
identical tasks one of whom saw an average thermal
strength of 5.5 knots and the other of 9 knots (!).
Picking the best thermals is the key differentiator
in cross-country speed (and hence distance). By handicapping
for it you are in part discounting skill - probably
the opposite of what's intended. If you average over
multiple traces you get into small numbers problems
in most areas because few OLC pilots fly the same tasks
on the same day.
It would be great to equalize for weather (or even
better, for weather/sailplane combinations) - but the
more I think about it the less likely it seems that
there is enough information available to estimate the
'pure' weather effects. If I fly 1 mile away from another
pilot and find a blue street that ups my XC speed (and
distance) by 20% was that pilot skill or a weather
difference that we should equalize for? How about if
I'm 10 miles away, 100 miles away, 1000 miles away?
It's worth further thought, but the basic problem is
the best pilots fly in the upper 10% of the lift strength
distribution while less skilled pilots flying in the
same air are lucky to fly in the upper 1/3 of the distribution.
9B
Old August 17th 05, 03:14 PM
Bill Daniels
"Andy Blackburn" wrote in message
Henryk Birecki's
learn Henryk's
software)
the McCready number
based
do the same thing.
how good the day
was.
is some very long,
and slower flights
result.
the gliders.
weather to a single
equal for different
gliders.
disallows water
Canceling WX
effects
Thoughts?
on the same day.
9B
Of course, no system will be perfect and it's easy to find situations that
would make it difficult. With wave or ridge lift available, the weather
factor could be devalued as most pilots would be able to use the lift
effectively. The biggest problems with weather are at the very strong or
very weak end of the thermal spectrum. For example. Region nine at Parowan
vs. the Sports Class Nationals at Ionia, Michigan.
I've analyzed a number of .IGC files from the On-Line Contest that were
flown in the same general area on the same day. The optimum McCready
numbers were fairly close to each other. I think that most doing the same
could reasonably be expected to say, "That was a 5 knot day".
I was thinking of a real contest where the flying was restricted to a task
area and the pilots were likely to be fairly good at thermalling. To help
get a more accurate picture of the day, the lower 25% of the contestants
could be discarded.
If the upper 25% of the pilots got 5 knots +or- 1knot at the best hour of
the day, that would seem to be a pretty good indication of the best the day
had to offer.
Bill Daniels
Old August 17th 05, 04:11 PM
Andy Blackburn
of the contestants
could be discarded.
at the best hour of
of the best the day
had to offer.
Oh, I thought you were suggesting a system for OLC
purposes - where the sample size would probably be
too small on average to be generally useful.
In a 'real' contest situation you might get enough
numbers to get usable results. I've talked about this
with members of the competition committee because I
think the idea has merit, at least in theory. Most
think it's too complicated and that we get enough complaints
about 'unfair' handicaps as it is. Honestly, I think
it would be hard to come up with a McCready adjustment
for every glider - particularly since most achieved
cross-country speeds far exceed the theoretical McCready
speed so it's not reasonable to base an adjustment
on McCready theory alone. In my experience the thing
that really spreads out the pack in sports class is
actually the ratio of interthermal distance to height
of the lift band. Wind speed in the boundary layer
also matters a lot. The guys flying the little gliders
at Parowan this year made heroic, but very low scoring
flights on the windy days.
If someone could come up with a reliable algorithm
for calculating the 'day strength slope' in the handicap
for all gliders I'd be very impressed.
9B
Old August 18th 05, 02:34 AM
David R.
The Brazillians use a weather based handicapping system for their nationals
(not enough gliders in any class to have a class based championship?) You
might want to look into it before inventing something from scratch.
Perhaps a Brazillian could post to tell us a bit about it?
regards,
dave r.
of the contestants
could be discarded.
at the best hour of
of the best the day
had to offer.
9B
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
