Google Earth
Old September 15th 05, 07:11 PM
ttaylor at cc.usu.edu
Default Google Earth
If you though Google maps were fun, try Google Earth. It often has
higher resolution than the maps and you can tilt your view into 3D.
Once in 3D, pull with your mouse and then let go and you can fly
over/through the terrain.
Hands down, the best view of the world yet. Can't wait till we can
link flight sims up with it. In much of the US view you can see down
to small bush details on the ridges. Some of the rest of the world is
not so detailed.
Tim
Old September 15th 05, 09:21 PM
ContestID67
See http://earth.google.com/.
Old September 16th 05, 01:43 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
not so detailed.
Tim
Google Earth is a blast! Its a shame so much of it is in low resolution format (-always over your house!) but the high res is brilliant.
Try "flying" up a mountain stream, or through really steep terrain.
We should be pushing this type to all we know, it will only get better.
Old September 16th 05, 09:25 AM
Mike Lindsay
In article , bagmaker
writes
not so detailed.
Tim
You can already see the sailplanes at Minden. But not at our field, the
res at 52.27N 001.09 E isn't good enough. Yet.
BTW I checked the long/lat for the Greenwich Observatory, and it was out
by about 200 metres.
Mike Lindsay
Old September 16th 05, 08:14 PM
GSA
Hi-res Vinon sur Verdon, France (LFNF) at 43.74N 005.78E
In 2006 the WC club class will be held here.
Hi-res gliders at Ocaņa, Spain at 39.935N 003.5W
Our own field Steinberg by Surwold at 52.955N 007.55E
Old September 20th 05, 09:37 AM
Stephen
"Mike Lindsay" wrote in message
writes
not so detailed.
Tim
Mike Lindsay
Zero longitude on the WGS84 datum is about 100m east of the line marked on
the ground at the observatory.
http://en.wikipedia.org/wiki/Prime_Meridian
The point of the arrow on this map
http://www.streetmap.co.uk/newmap.sr...=newsearch.srf
ties up fairly well with the zero longitude line on Google Earth and appears
to be pretty near 100m east of the observatory. The measurement tool is a
bit limited in it's resolution at this scale.
BTW if you convert your IGC logger file to a GPX file you can go fly your
flight again. If you're lucky enough to have good Google Earth imagery
where you're flying it's pretty realistic. This page seems to explain how
although a geek in the office wrote a script to do the conversion for me.
http://www.expandingknowledge.com/Je...htm#IGC_to_KML
Stephen
Old September 20th 05, 11:26 AM
Martin Gregorie
writes
higher resolution than the maps and you can tilt your view into 3D. Once
in 3D, pull with your mouse and then let go and you can fly over/through
the terrain.
The main problem is that Google Earth required a special piece of Windows
software to be installed. This is a problem for those of us who don't run
Windows and/or cannot install software on the machine they are using. I
recently stumbled on:
http://www.geabios.com/
Which has full earth coverage via a Flash/javascript application. Its
resolution isn't quite up to Google Earth but its easy to use. I was able
to find the CGC field without trouble though the quality was barely
enough to resolve the club house and not enough to see gliders. Still, as
a fairly fast way of looking at images without needing special software
its worth bookmarking.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 22nd 05, 12:07 PM
jleibacher
If you have the GoogleEarth program loaded on your Windoze system, all
of the "Worldwide Soaring Turnpoint Exchange" sites are accessible from
the kmz file available at
http://soaring.aerobatics.ws/TP/google_earth.html
Google Sux.. [email protected] Soaring 1 April 29th 05 10:48 PM
Google your favorite satellite shot of earth Stewart Kissel Soaring 1 April 9th 05 03:51 AM
Earth planes vs. UFOs from Outer Space? Adam Ben Nalois Military Aviation 24 December 17th 03 06:24 PM
GOOGLE Spam Doug Simulators 10 September 28th 03 12:06 PM
Copyright Đ2004-2025 AviationBanter.
