Aerodynamic Drag
Old September 24th 05, 01:57 AM
Kyle Boatright
Default Aerodynamic Drag
Help me figure out how much speed my RV can gain by fairing the Pitot Tube.
The pitot is made of 3/8" OD aluminium tube, with a 6" length perpendicular
to the airstream. That gives a surface area of 3/8" x 6" = 2 1/4 sq inches.
My understanding is that the Cd of a cylinder is .5 and the Cd of a faired
shape can be as low as 0.005, but let's assume 0.05 for the faired shape.
The effective area is .5 x 2 1/4 square inches = 1.125 square inches for the
cylinder.
and
0.05 x 2 1/4 = 0.1125 square inches for the streamlined shape.
The difference is 1.125-.1125 = 1.06875 square inches. Let's call it 1
square inch...
Assuming I'm in the ballpark so far, how much power can I "save" at 175 mph
by streamlining the pitot, which eliminates essentially 1 square inch from
the aircraft's effective frontal area?
KB
Old September 24th 05, 02:35 AM
Ernest Christley
cylinder.
and
square inch...
KB
Kyle, any answer you get will be further complicated by the
modifications in intersection drag. But ignoring that...
From http://142.26.194.131/aerodynamics1/Drag/Page4.html , the equation
for parasitic drag is:
Dp = CDp x S x ½ r V^2
Essentially, once you remove the drag of the unfair pitot tube, and then
accellerate, Dp will come out the same. You're using the all the horses
the engine has to make the plane go faster, vs dragging a pitot tube
around. So:
CDp x S1 x ½ r V1^2 = Dp = CDp x S2 x ½ r V2^2
I only marked S and V with ones and two's, because everything else will
drop out of the equation (making a BIG and unlikely assumption that the
drag coefficient doesn't change), leaving:
S1xV1^2 = S2xV2^2
But the useful form of this for your purposes is:
V2^2 = S1 x V1^2 / S2
Now, your fairing the pitot is only one part of the entire airplane, and
the entire airplance has to be considered to determine the increase in
speed. I have no clue what the surface area of an RV of any sort is
(but a Delta is 183ft^2 8*) Assuming your RV has the surface area of a
C-172, 174ft^2, you've just dropped 0.007ft^2. Plugging the numbers:
V2^2 = 174 x 175^2 / 173.993
V2^2 = 30,626
V2 = 175.00352
Are we ready for Reno yet 8*) You'd probably double this increase by
cleaning up the intersection drag. If the tube is located in a position
that will cause it to produce rough air for everything behind it, there
would also be some (insignificant) benefit to be gained there.
This is by far the hardest lesson about freedom. It goes against
instinct, and morality, to just sit back and watch people make
mistakes. We want to help them, which means control them and their
decisions, but in doing so we actually hurt them (and ourselves)."
Old September 24th 05, 02:57 AM
Kyle Boatright
"Ernest Christley" wrote in message
om...
Tube.
perpendicular to the airstream. That gives a surface area of 3/8" x 6" =
2 1/4 sq inches. My understanding is that the Cd of a cylinder is .5 and
the Cd of a faired shape can be as low as 0.005, but let's assume 0.05
the cylinder.
and
square inch...
mph by streamlining the pitot, which eliminates essentially 1 square inch
from the aircraft's effective frontal area?
KB
Kyle, any answer you get will be further complicated by the modifications
around. So:
S1xV1^2 = S2xV2^2
speed. I have no clue what the surface area of an RV of any sort is (but
a Delta is 183ft^2 8*) Assuming your RV has the surface area of a C-172,
V2^2 = 30,626
V2 = 175.00352
Fortunately (unfortunately?) the pitot tube is probably the easiest "big"
thing on the airframe I can streamline without hacking up the cowl to reduce
cooling drag or taking some other *extreme* measure. I had considered
fairing the pitot, the two fuel vents, the two fuel strainers, and the 4
aileron brackets that protrude into the airstream. My guess is that all of
these items together only amount to maybe 3 to 5 times the drag of the pitot
tube. Bottom line, if the combination of our math skills is correct, I'm
lookin' at less than a 1/2 mph improvement? If that's the case, I've got
MUCH better ways to spend my time. ;-)
As to your assumptions, I'd guess the RV has half the surface area of a
C-172. A couple of sources indicate the RV's flat plate area is ~2.3ft^2.
KB
Old September 24th 05, 05:03 AM
Mike Rapoport
Eanest:
How about a related question? On my Helio Courier the fusilage/wing
intersection is slightly less than 90deg. The intersection looks like an
aerodynamic disaster. How much drag would be eliminated with a fairing than
can only come down the fusilage three inches? How about a two part fairing
(one part would be on the door) that could come down 6 inches?
Mike
om...
Tube.
the cylinder.
and
square inch...
KB
around. So:
S1xV1^2 = S2xV2^2
V2^2 = 30,626
V2 = 175.00352
Old September 25th 05, 04:46 AM
Ernest Christley
Mike Rapoport wrote:
Eanest:
Mike, I think you are mistaking me for someone who knows what they are
talking about.
Seriously, though, I read a NACA report from the LARC site a while back
describing an experiment with fairings on a high wing aircraft. I can't
remember all the particulars, and a quick search just now proved
fruitless, but I remember that they realized significant speed gains
with increased fairing sizes. In my *opinion*, the more fairing you can
get the better.
Consider the right wing. The problem with intersection drag is that you
have the air being compressed both from the left off of the fuselage and
up from the wing. Down there in the corner, the poor air doesn't know
which way to go. So like FEMA or a southern city mayor, it chooses to
spin around in circles. We call these vortices, and they eat up a lot
of energy without producing anything. A fairing, even a small one, will
help direct the air, and stop the spinning, at least partly.
Tell you what, Mike, why don't you try and experiment? Roll up a few
sheets of newspaper for filler, and temporarily duct tape in a 3"
fairing. Fly the plane and measure the before and after speeds. It
would make a nice Sport Aviation article.
Old September 26th 05, 03:34 AM
Mike Rapoport
Thanks. I will try the experiment this winter (or at least I intend to try
it ). In addition to the Helio, I have a MU-2 which has large radius
fairings between the wing and fusilage. On the right side of the Helio
there is plenty of room for the fairing to come down the side of the
fusilage before it reaches the window but on the left side the door
restricts the fairing size. It is surprising to me that Helio left the area
unfaired.
Mike
om...
Eanest:
than can only come down the fusilage three inches? How about a two part
fairing (one part would be on the door) that could come down 6 inches?
talking about.
fruitless, but I remember that they realized significant speed gains with
increased fairing sizes. In my *opinion*, the more fairing you can get
the better.
spin around in circles. We call these vortices, and they eat up a lot of
energy without producing anything. A fairing, even a small one, will help
sheets of newspaper for filler, and temporarily duct tape in a 3" fairing.
Fly the plane and measure the before and after speeds. It would make a
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Forward CG Experience Jay Honeck Piloting 41 November 19th 03 02:54 PM
Did we decide if ballasted pullups are higher???????? Lars Peder Hansen Soaring 22 October 8th 03 12:45 AM
