Hello everyone,
I'm back in the shop again with a new problem. That is, how to drill accurate holes on-center through steel tubing. I need to attach 2 short lengths of 1/2" EMT tubing parallel to the top tube of a bicycle frame, one on each side. The EMT tubes will extend about 20" forward of the bike frame. The frame tube is about 1" dia. I want to drill horizontally through all 3 tubes and attach everything with a pair of #10 machine screws. Prob. is how to drill the holes on center so everything lines up. I have both a drill press and cordless drills at my disposal. Suggestions? Methods? Tools? Thanx, Harry Wright Brothers Bike Guru Wright 1902 glider Wright 1899 kite |
I would cut a couple chunks of 2X4 and clamp them to the frame and both bars
at the same time. If you don't have a centerdrill, use a punch to insure your drill starts in the right place. Then you can clamp the whole thing down to your drill press table. -- "Don't be misled, bad company corrupts good character." www.LCTPaintball.com www.LCTProducts.com "wright1902glider" wrote in message oups.com... Hello everyone, I'm back in the shop again with a new problem. That is, how to drill accurate holes on-center through steel tubing. I need to attach 2 short lengths of 1/2" EMT tubing parallel to the top tube of a bicycle frame, one on each side. The EMT tubes will extend about 20" forward of the bike frame. The frame tube is about 1" dia. I want to drill horizontally through all 3 tubes and attach everything with a pair of #10 machine screws. Prob. is how to drill the holes on center so everything lines up. I have both a drill press and cordless drills at my disposal. Suggestions? Methods? Tools? Thanx, Harry Wright Brothers Bike Guru Wright 1902 glider Wright 1899 kite |
Find two pieces of angle iron. Weld, bolt, glue, or tape together -
one up and one down. Set on the drill press and center the "V" section under the spindle using the smallest drill bit you have. Clamp in place. Just drop the EMT into the "V" and drill away. You can use the welded seam to keep the holes at each end in phase. Do the same for the bicycle frame or use the drilled EMT for a drilling jig. If you drill first with an 1/8" bit and bolt together using 8-32 bolts you can go back and drill with a long 3/16 bit in your cordless and have everything nice and tight. Hose clamps with a bit of old inner tube make good clamps on irregular things such as this......... ====================== Leon McAtee |
wright1902glider wrote:
Hello everyone, I'm back in the shop again with a new problem. That is, how to drill accurate holes on-center through steel tubing. I need to attach 2 short lengths of 1/2" EMT tubing parallel to the top tube of a bicycle frame, one on each side. The EMT tubes will extend about 20" forward of the bike frame. The frame tube is about 1" dia. I want to drill horizontally through all 3 tubes and attach everything with a pair of #10 machine screws. Prob. is how to drill the holes on center so everything lines up. I have both a drill press and cordless drills at my disposal. Suggestions? Methods? Tools? Thanx, Harry Wright Brothers Bike Guru Wright 1902 glider Wright 1899 kite Harbor Freight has a jig for about $5. Just a V-shaped piece of aluminum that bolts to the bench press table. Position it so that the bit drops down into the bottom of the V. Center punch the tube, and position the tube on the jig so that the bit drops to the punch depression. You'll get a centered hole every time. I build my own jig from a piece of steel angle and a couple of bolts before I realized that Harbor Freight sold the jig. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
In article .com,
"wright1902glider" wrote: Hello everyone, I'm back in the shop again with a new problem. That is, how to drill accurate holes on-center through steel tubing. I need to attach 2 short lengths of 1/2" EMT tubing parallel to the top tube of a bicycle frame, one on each side. The EMT tubes will extend about 20" forward of the bike frame. The frame tube is about 1" dia. I want to drill horizontally through all 3 tubes and attach everything with a pair of #10 machine screws. Prob. is how to drill the holes on center so everything lines up. I have both a drill press and cordless drills at my disposal. Suggestions? Methods? Tools? Thanx, Harry Wright Brothers Bike Guru Wright 1902 glider Wright 1899 kite Any reason you've ruled out epoxy in lieu of the bolts? Seems like you could make a nice neat job of it. You can get it in different colors, or add pigment to the clear stuff. |
Has anyone seen v-blocks for sale at Lowe's or HD?
Epoxy doesn't offer enough strength. I'm attempting to recreate a test-rig that the Wrights used before building the wind tunnel. It consists of a regular bicycle with third wheel mounted horizontally out in front of the handlebars. Attached vertically to either side of the horizontal wheel are model airfoils or flat plates. The theory was that using trigonometry, the wrights could evaluate various airfiol sections by measuring the angle of deflection off center, one airfoil vs. another. Of course, it wasn't acurate enough for scientific purposes, hence the wind tunnel, but it'll be fun to demonstrate at airshows. |
In article .com,
"wright1902glider" wrote: Epoxy doesn't offer enough strength. If you're paralleling the tubes for six inches or more, and you filled the notches between them top and bottom with a fillet of serious industrial epoxy, (not the five minute stuff) I'd think you'd be able to support more of a cantilevered load before the glue sheared, than you would before the tubing folded at the bolt holes. (EMT isn't very strong, and you're going to need a 0.187" hole for a #10 bolt.) But that's just a feeling. I was the guy who built the weakest cardboard bridge in high school physics, so I'm probably wrong. Anyway, I can see you like the bolts. You could make your own clamping fixture, a combination of the V-block idea and the two by four idea. If you have a table saw, you could cut stepped grooves in two 6 or 8 inch long wood blocks. The inner step has a width and depth of 1/2". The outer step has a width of 1" and a depth of 1/2." Drill some holes for drill bushings, available at the industrial hardware store, press them in, clamp the two halves around the three tubes, and drill. |
The best (strongest) epoxy is Belzona 1111 also refered to as Belzona
Super Metal. Super Metal is machineable, no VOC's, no solvents, does not rot, does not rust, does not shrink, or does not corrode. It is compatable with all metals. The same can not be said of Devcon, JB Weld, and most other epoxies on the market. Yes many claim to be as good as Belzona but experience and research has proven time and again they do not produce results as good as the Belzona product. Belzona is may be more expensive but, if results are important, is actually less expensive. www.belzona.com |
In article .com,
"Clay" wrote: The best (strongest) epoxy is Belzona 1111 also refered to as Belzona Super Metal. Super Metal is machineable, no VOC's, no solvents, does not rot, does not rust, does not shrink, or does not corrode. It is compatable with all metals. The same can not be said of Devcon, JB Weld, and most other epoxies on the market. Yes many claim to be as good as Belzona but experience and research has proven time and again they do not produce results as good as the Belzona product. Belzona is may be more expensive but, if results are important, is actually less expensive. www.belzona.com And speaking of epoxy and bicycles, recumbent bike guy might want to know, if he's still hanging around here, that there's a carbon fiber bicycle whose tubes are secured to titanium lugs with epoxy. |
Smitty Two wrote:
Anyway, I can see you like the bolts. You could make your own clamping fixture, a combination of the V-block idea and the two by four idea. If you have a table saw, you could cut stepped grooves in two 6 or 8 inch long wood blocks. The inner step has a width and depth of 1/2". The outer step has a width of 1" and a depth of 1/2." Drill some holes for drill bushings, available at the industrial hardware store, press them in, clamp the two halves around the three tubes, and drill. If you're going to do all that cutting on a table saw, then just set the blade at a 45 degree angle and run a block through twice so that it cuts a nice V. If you use a 2x4 block, set your fence at about 2.25" from center and you'll get a 1/2" wide V. Drill a couple holes to bolt it to the drillpress table. It won't be a permanent tool, but it'll work perfectly to build one bike. A further enhancement, I welded a short piece of angle to a C clamp. Makes holding the tube much easier. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Fixing screw holes in fabric | Brian Huffaker | Home Built | 4 | May 21st 05 02:16 AM |
Any sources of thin walled 4130 tubing in northern CA? | mike | Home Built | 3 | February 6th 05 03:20 PM |
source for aluminum tubing with rounded corners? | Kyler Laird | Home Built | 3 | June 1st 04 03:07 PM |
the complete minute by minute timeline on 911 | Krztalizer | Military Aviation | 27 | January 27th 04 04:35 PM |
Winching: Steel vs. Plasma | Bob Johnson | Soaring | 10 | August 12th 03 05:41 PM |
