Yes, this is a stupid question, and somewhat off topic for IFR.
But I get better answers here than elsewhere. Question: Why is it that devices to separate water from fuel are quite common cars (my F-350 truck has one), but such a device, which could save lives in an airplane, is not offered for airplanes ? Even as a retrofit ? |
common cars (my F-350 truck has one), but such a device, which could save lives in an airplane, is not offered for airplanes ? Even as a retrofit ? To this and other similar questions, the general answer is weight, cost, and reliability. Weight - all the gadgets and gizmos weigh something, and this gets removed from your useful load. If all the safety features people wanted were included, the airplane would never fly. I guess that would be pretty safe. Cars don't have to fly, so they can be as heavy as ittakes - a few pounds here and there don't really make a difference. But in the air they do. Cost - mainly certification cost, since any newfangled gizmo has to go through the FAA wringer to ensure that there are no unexpected surprises. Whether this is actually effective or not is subject to debate (witness the homebuilt arena) but it is necessary. Reliability - it's another gizmo to go TU, with unpleasant side effects. Cars can pull over when they break. Planes can't. In the case of this particular item (fuel/water separators), it would still not relieve the pilot of the necessity to check for water in the gas, since we all know that things that "shouldn't" happen, do anyway. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
I've never encountered water in a/c fuel either. However, I did in an
auto once and I wonder how a water separator would have handled it. I filled up an almost empty '95 Caravan with fuel that had a great deal of water in it. The van died before turning out of the station. After damning my luck at a breakdown on a raining winter evening 100s of miles from home, we looked for a meal and a hotel. Then I noticed that there were several people milling about the interstate exit, on foot! No one walks anywhere in January at an interstate exit. Further observation found that a number of cars were parked irregularly all over the place. I put 2 and 2 together and immediately went in the station and suggested that water was in the fuel and that the pumps needed to be closed. The confused teenager handling the desk didn't know what to do so insisted she call the owners and I went out and hung signs closing the station. Anyway, I concluded that the problem resulted from semi-melted ice all over the parking lot. They were damming up the cold rain and the water ran into the tanks during a fill or otherwise overcame whatever protection is normally in place. Ever seen 3 guys chain smoke while draining fuel tanks into 55 gallon drums. How would water sparators work with an 'enormous' quantity of water in the fuel? Jose wrote: Why is it that devices to separate water from fuel are quite common cars (my F-350 truck has one), but such a device, which could save lives in an airplane, is not offered for airplanes ? Even as a retrofit ? To this and other similar questions, the general answer is weight, cost, and reliability. Weight - all the gadgets and gizmos weigh something, and this gets removed from your useful load. If all the safety features people wanted were included, the airplane would never fly. I guess that would be pretty safe. Cars don't have to fly, so they can be as heavy as ittakes - a few pounds here and there don't really make a difference. But in the air they do. Cost - mainly certification cost, since any newfangled gizmo has to go through the FAA wringer to ensure that there are no unexpected surprises. Whether this is actually effective or not is subject to debate (witness the homebuilt arena) but it is necessary. Reliability - it's another gizmo to go TU, with unpleasant side effects. Cars can pull over when they break. Planes can't. In the case of this particular item (fuel/water separators), it would still not relieve the pilot of the necessity to check for water in the gas, since we all know that things that "shouldn't" happen, do anyway. Jose |
the fuel? Try adding alcohol to absorb the water. |
john smith wrote: How would water sparators work with an 'enormous' quantity of water in the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. |
the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. Drain it or ground run it. |
You can use a GATS jar for checking your fuel. It has a screen that
removes water when you pour back into the tank. My guess is that water separator are rather new, and the volume doesn't justify anyone producing a certified unit for aircraft? |
paul kgyy wrote:
You can use a GATS jar for checking your fuel. It has a screen that removes water when you pour back into the tank. My guess is that water separator are rather new, and the volume doesn't justify anyone producing a certified unit for aircraft? Not new at all. They've been used on diesel engines for at least 25 years. I had a water trapping filter on my fuel pump tank when I owned a 182 and ran auto gas in it. I definitely didn't want to be adding water to the tanks beyond what they might collect naturally, although, I never found water in the fuel in 6 years of flying. However, I was always expecting it given that the 67 had fuel bladders which were known for having wrinkles that could trap large amounts of water and let it loose at inopportune times. My partner and I always did a vigorous wing rock before draining the sumps, however, we never found anything. We did have the flush fuel cap upgrade which was supposed to greatly reduce the change of water ingestion. I'm not sure why they aren't used on airplanes, other than they add cost, weight, and another item to get certified. Also, although I never saw the problem on the diesels I used to operate, it may be that the filter has a nasty failure mode if it collects enough water. For example, maybe they clog completely. I don't know, just wondering if there isn't some downside like that which obviates the benefit for airplane use. Matt |
On Fri, 14 Oct 2005 13:28:51 -0700, Scott Moore
wrote: Yes, this is a stupid question, and somewhat off topic for IFR. But I get better answers here than elsewhere. Question: Why is it that devices to separate water from fuel are quite common cars (my F-350 truck has one), but such a device, which could save lives in an airplane, is not offered for airplanes ? Even as a retrofit ? I wasn't aware that there are any airplanes without water separators. My Cherokee has quick drains on each tank and each fuel manifold to check and drain any accumulated water. Checking for water is a preflight item. Before the fuel enters the carburetor it goes through a gascolator to separate dirt and water, which can also be tested with a quick drain. And of course the last chance is the carburetor bowl itself, which no one ever seems to check at annual, no matter how much I insist, but there's a drain plug nevertheless. Most other airplanes I've looked at seem similarly equipped. I believe the thesis for this topic is flawed. I never bother checking for water in the fuel on my car. There's no provision for checking the car for water anyway without disassembling stuff. RK Henry |
Scott Moore wrote: Yes, this is a stupid question, and somewhat off topic for IFR. But I get better answers here than elsewhere. Question: Why is it that devices to separate water from fuel are quite common cars (my F-350 truck has one), but such a device, which could save lives in an airplane, is not offered for airplanes ? Even as a retrofit ? Your F350 is a diesel. Gas engines in cars and trucks don't have water seperators. Cars and trucks don't have a way to test the fuel like aircraft. |
| fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 01:57 PM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 07:13 PM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
| Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 10:47 PM |
