Hello there,
I am considering the purchase of a Cardinal 177A with low frame and engine times, nice gps and slaved HSI. It has had 2 accidents, one in 2003 requiring major work to everything in front of and including the firewall. I have flown the plane and it feels heavier on the landings with more stick pressure required than in the 172`s I have flown but otherwise OK. I have heard that this early model Cardinal has tail stall issues and that one should not fill her up to the max permitted gross weight on warm days. I would be flying alone 95% of the time and in Canada where we only have cold days. ![]() Any thoughts by owners on this plane? Tien, CP |
![]() The tail stall problem with early Cardinal went away when the slots were put in the stabilator back in 1968. See this thread http://groups.google.com/group/rec.a...e?dmode=source If you are interested in purchasing a Cardinal, I highly recommend you checking out this website http://www.cardinalflyers.com/ You may want to consider joining the club for $34/yr. There is a wealth of information at the site for members. I joined CFO before purchasing our Cardinal. We have owned our C177B sinc March 2003 and have been very happy with our decision. The main drawback of the 177A is the 150HP engine. It may not be an issue if you don't live in high altitude areas and don't plan to fly with max load. One advantage of the 177B is the autogas STC which is worth consideration. Hai Longworth |
I have owned a 177A for eight years and love it. It has several
qualities hard to find anywhere, even in later year Cardinals. If you are looking at a 177A(Cessna 1969 model), and not a 1968 177(no A), then it came from the factory with the 180 HP engine. It is the 150 HP 1968 model that you can't fill the seats on a hot day.My 177A has a useful load of over a 1000 lbs, and I have flown it there several times and it handles it well. The slots in the Stabilator eliminated the stalling in the flare issue. Cardinals have great looks, room, and the early ones have a high useful load. I actually prefer the early airfoil that was changed the following year to a more Skyhawk like one. If you use alot of nose up trim, you should feel little pressure upon landing. Should get 118 knots at 75% cruise. Later models will do 130. Wouldn't trade it for anything in it's class. wrote: Hello there, I am considering the purchase of a Cardinal 177A with low frame and engine times, nice gps and slaved HSI. It has had 2 accidents, one in 2003 requiring major work to everything in front of and including the firewall. I have flown the plane and it feels heavier on the landings with more stick pressure required than in the 172`s I have flown but otherwise OK. I have heard that this early model Cardinal has tail stall issues and that one should not fill her up to the max permitted gross weight on warm days. I would be flying alone 95% of the time and in Canada where we only have cold days. ![]() Any thoughts by owners on this plane? Tien, CP |
![]() wrote in message ups.com... I have owned a 177A for eight years and love it. It has several qualities hard to find anywhere, even in later year Cardinals. If you are looking at a 177A(Cessna 1969 model), and not a 1968 177(no A), then it came from the factory with the 180 HP engine. It is the 150 HP 1968 model that you can't fill the seats on a hot day.My 177A has a useful load of over a 1000 lbs, and I have flown it there several times and it handles it well. The slots in the Stabilator eliminated the stalling in the flare issue. Cardinals have great looks, room, and the early ones have a high useful load. I actually prefer the early airfoil that was changed the following year to a more Skyhawk like one. If you use alot of nose up trim, you should feel little pressure upon landing. Should get 118 knots at 75% cruise. Later models will do 130. Wouldn't trade it for anything in it's class. Thanks everyone for your help. It is indeed a 177, 1968 with a 150 HP engine. I think I can live with its handling characteristics. Tien |
Tien Dao wrote:
Thanks everyone for your help. It is indeed a 177, 1968 with a 150 HP engine. I think I can live with its handling characteristics. There is a STC upgrade to 160hp if you so desire... Can still run on mogas as well, with the proper STC for that... |
![]() Darrel Toepfer wrote: There is a STC upgrade to 160hp if you so desire... Can still run on mogas as well, with the proper STC for that... It has a "PowerFlow Extractor Exhaust System" which is supposed to bump up the bhp somewhat putting it possibly in the neighborhood of 160 hp. Tien |
define hot day... out here that means 95F-115F on a field elevation of
3000MSL, that cranks the Density Altitude just a bit.. with 6000+MSL ridge lines to cross to get out of the valley.. BT wrote in message ups.com... I have owned a 177A for eight years and love it. It has several qualities hard to find anywhere, even in later year Cardinals. If you are looking at a 177A(Cessna 1969 model), and not a 1968 177(no A), then it came from the factory with the 180 HP engine. It is the 150 HP 1968 model that you can't fill the seats on a hot day.My 177A has a useful load of over a 1000 lbs, and I have flown it there several times and it handles it well. The slots in the Stabilator eliminated the stalling in the flare issue. Cardinals have great looks, room, and the early ones have a high useful load. I actually prefer the early airfoil that was changed the following year to a more Skyhawk like one. If you use alot of nose up trim, you should feel little pressure upon landing. Should get 118 knots at 75% cruise. Later models will do 130. Wouldn't trade it for anything in it's class. wrote: Hello there, I am considering the purchase of a Cardinal 177A with low frame and engine times, nice gps and slaved HSI. It has had 2 accidents, one in 2003 requiring major work to everything in front of and including the firewall. I have flown the plane and it feels heavier on the landings with more stick pressure required than in the 172`s I have flown but otherwise OK. I have heard that this early model Cardinal has tail stall issues and that one should not fill her up to the max permitted gross weight on warm days. I would be flying alone 95% of the time and in Canada where we only have cold days. ![]() Any thoughts by owners on this plane? Tien, CP |
I have taken it out of Santa Fe, ABQ, Flagstaff, Williams, etc. I had
it near gross this summer when I moved it to WJF. It gets pretty hot here in the Mojave. The DA out of Santa Fe was 9300 the day I took off there on July 4th weekend. Not that you don't notice the difference though ![]() afternoon. Lots of gusty crosswind, and that ridge ahead! Less than 4000' runway would be exciting though. I find that high humidity at 95-100 in Alabama was almost as bad, because the engine makes less power than in the dry air out west. |
Flying our Cardinal south for its new plumage - Long report | Longworth | Piloting | 20 | October 20th 05 05:01 AM |
Flying our Cardinal south for its new plumage - Long report | Longworth | Owning | 19 | October 20th 05 12:23 AM |
Any Cardinal owners that frequent this group? | Jack Allison | Owning | 6 | November 17th 04 03:05 PM |
Swift Boat Veterans For Truth: Are They Going To Sink John Kerry? | BUFDRVR | Military Aviation | 151 | September 12th 04 09:59 PM |
Lot of noise being made about Purple Hearts | Jack | Military Aviation | 154 | September 8th 04 07:24 PM |
