Triangle shaped ice/frost on the wing - anyone seen this?
Old December 6th 05, 02:32 PM posted to rec.aviation.piloting
Default Triangle shaped ice/frost on the wing - anyone seen this?
Yesterday, I was flying along the tops of a broken layer and picked up
a thin layer of frost/ice on the wings with a thin triangle-shaped
pattern to the frost. This was a new one to me.
Conditions:
Plane: Cherokee 180
Altimeter 30.05
Broken layer @ 4000MSL (~3000AGL)
OAT = -5degF
Clear above the 040 BKN layer
Time was 10am, which put the sun almost directly behind the plane.
The leading edge of the wing was clear (free of frost) from the
leading edge to approximately 8 inches back (chordwise).
At the 8-inch chord mark, several frost outlines in a triangle shape
were present. The frost outline started as a point, and tapered back
evenly on either side, slowly 'enlarging' the frost pattern so that it
looked like a triangle pointed towards the leading edge. There were
several of these patterns on the wing, one every few feet (spanwise).
The frost patterns were not aligned with the rivets.
The frost triangles were about 1-2 feet long and 6 inches wide.
The OAT gauge/windshield did not accumulate any frost/ice.
Explanations? Similar occurrences?
-Nathan
Old December 6th 05, 03:52 PM posted to rec.aviation.piloting
It is probably due to structure on your airplane being colder than the air.
The triangles are probably reinforcements or doublers under the skin. I get
this a lot on the MU-2 after landing when the fuel is at -40C and frost
forms on the underside of the wing where the fuel contacts the skin.
Mike
MU-2
"Nathan Young" wrote in message
news
Conditions:
Plane: Cherokee 180
Altimeter 30.05
OAT = -5degF
-Nathan
Old December 6th 05, 09:33 PM posted to rec.aviation.piloting
What, Prist can't fix that?! ;-)
Ben Jackson
http://www.ben.com/
Old December 7th 05, 10:15 PM posted to rec.aviation.piloting
On Tue, 06 Dec 2005 15:52:16 GMT, "Mike Rapoport"
I will have to ask my A&P. I am fairly certain that on a Cherokee,
the inner wing is much simpler than that... Ie ribs with the outer
wing skin riveted to them.
Old December 7th 05, 12:36 AM posted to rec.aviation.piloting
An advertisement for Sci-Fi Channel's new mini-series?
Old December 7th 05, 01:57 AM posted to rec.aviation.piloting
Well, this did happen in the Minneapolis area, so perhaps it had
something to do with the light pillars mentioned a day ago. :-)
Old December 7th 05, 05:16 AM posted to rec.aviation.piloting
I could throw in some more than usually uninformed speculation (even for
this group . . . ) about a random dot of frost forming, causing the
airflow to spread out laterally just a bit; gases cool when they expand
(happens in nozzles and many types of refrigerators); result is more
frost forming in the region just behind the dot; and the
forward-pointing triangle grows toward the rear of the plane.
Fits the available data presented thus far, and stranger things happen
in gas and liquid flows all the time -- but I have no idea if anything
like this is really happening here.
Old December 7th 05, 05:41 AM posted to rec.aviation.piloting
"AES" wrote in message
airflow to spread out laterally just a bit [...]
That was the theory I came up with too. That should be enough to cause you
concern for whether you're actually correct.
(I didn't post it, because it seemed too outlandish, even for me ).
Old December 7th 05, 09:46 PM posted to rec.aviation.piloting
"AES" wrote in message ...
Yes, maybe that is the area where the boundary layer was breaking from laminar flow to turbulent flow. It may be a new
way to figure out where to place the vortex generators...
This was my best guess as well. I wish had my digital camera with me
- would have been a good one to capture.
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
