Lycoming O-360 ring gear
Old January 8th 06, 02:11 PM posted to rec.aviation.owning
Default Lycoming O-360 ring gear
Hey all. Now that my holiday travels are over, I'm planning to do some
maintenance to my Cherokee. The ring gear has gotten chewed up over time, and now
will sometimes not disengage while the starter is rolling it over. Worn/broken teeth,
etc. I was pretty sure it was a 122-tooth model, but when I looked at it yesterday,
it had the rounded tooth bottoms like the 149. I've got a Skytec starter on it (I'll
have to look up the model number to be sure which one).
Anyway, I think it's quite possible that the wrong ring gear is on the engine.
What's the deal with the two models? I've heard conflicting reports that the older
Lycoming had 122 and then changed to 149. I've also heard that only the O-235 and
O-360's have 149s. I suspect it's probably the former and a mish-mash of
disinformation and ill-fitting ring gears. Since I need to replace the old one, I'm
confronted with the choice of which to get (at least until I verify which starter I've
got)
Questions:
- What's *supposed* to be on an O-360-A3A in a PA-28?
- Is one better than the other?
- How many people have the wrong starter/ring gear combo? I suspect it mostly works,
but probably wears quickly... probably what I've got going on.
Cheers,
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old January 8th 06, 03:15 PM posted to rec.aviation.owning
Questions:
When we removed the air conditioning on our Cherokee, I got my wake up
call as to how little Lycoming and Piper knew about what they installed
on these airplanes. The parts manuals conflicted with the microfiche at
the dealer which conflicted with what was actually installed on our
airplane. So, finding out which part was "right" was a challenge.
I used a method that seems to work well "PIDBWA" (Parts identification
by walking around). I checked the part numbers on other models I saw on
the ramp and at other airports. When I see what was ACTUALLY INSTALLED
on similar airplanes of the same year (and it agrees with one parts
listing or another), that is what I go out and try to find. I had this
problem with the pulley bulkhead/ring gear. 2 different ring gear
pitches, 2 different pulley diameters, and several different belt
widths. Throw in the ones for air conditioned models and... GAAAAAA! I
just checked out the Cherokees on the ramp and instantly got the
consensus. Oddly, the parts installed on all the beasts matched NOTHING
of what the parts places were finding in their documentation.
One place to find this particular part is a little place in Texas called
"Bobby's Planes and Parts". O.K. quit laughing. This guy had every
conceivable pulley bulkhead/ring gear assembly in stock and actually
KNEW what he was talking about. His comment, "yeah the parts manuals are
all wrong". If you get in a jam finding one, I can scrounge up the phone
number and you can see if he is still in business.
Good Luck,
Mike
Old January 9th 06, 05:54 AM posted to rec.aviation.owning
Hello guys. I've been browsing this forum for awhile, thinking about
taking up piloting. Just wanted to introduce myself.
Old January 9th 06, 09:13 PM posted to rec.aviation.owning
wrote)
Welcome. Stick around. Also, check out rec.aviation.student.
Montblack
Old January 9th 06, 12:25 PM posted to rec.aviation.owning
: Am pretty sure that all the OEM gear-reduction starters used one gear
: pitch (fine-149), and that the other was used only on the OEM
: direct-drive starters (coarse-122).
I don't know about the OEM gear-reduced ones, but Skytech makes their PM in
both flavors. I checked my paperwork last night and it looks like the starter that's
in it is the 149-12LS. I think I need to visually verify this, though. The gap
between the ring gear and starter seems a bit wider than it should be... maybe the
starter is actually a 122-12LS.... or maybe the ring gear teeth are all just worn down
too much.
: I'm sure you are aware that only the outer portion (the "gear") needs
: to be replaced, not the entire support assembly.
Yes... looks like the price on it tends to run about $130-$150
-Cory
* Cory Papenfuss *
Old January 10th 06, 12:12 PM posted to rec.aviation.owning
: did you count your ring gear teeth? I think the direct-drive starter
: gears were a little larger in diameter.
: sorry I don't have ready access to prestolite starter drives any more,
: the stuff I allegedly maintain nowadays read RPM in % N1 & N2.
I did this weekend and verified it's 149. The paperwork in the logbook says
the Skytec starter is a 149-12LS. Guess that means I put a 149 back on... just wish I
knew why it wore out in the first place. Maybe the old Prestolite was the wrong one
and wore it out prematurely... it *did* have a cracked mounting flange.
: : I'm sure you are aware that only the outer portion (the "gear") needs
: : to be replaced, not the entire support assembly.
: Yes... looks like the price on it tends to run about $130-$150
: heh. or twice that if you drop in on the support upside down, or fail
: to get it seated all the way. BTDT
Ooops. Guess I'll need to be extra-careful putting it on. How hot of an oven
is necessary? I dont' want to kill any heat treating on it, but I don't what to have
troubles (or lack of time) getting it on either.
-Cory
* Cory Papenfuss *
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 29th 05 11:17 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
A&P heroics Jim Piloting 31 July 18th 05 07:26 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
