Am I the only one that still has the Aero Advantage Dual Pump
installed? I see that the AD to remove the pump has finally arrived: http://dmses.dot.gov/docimages/p84/385862.pdf This is a stupid AD, in my opinion. The reason for the AD is that both chambers might fail at the same time. But, how is that any worse than a single-chamber pump failing? Fortunately, the FAA updated the AD to allow owners to retain the monitoring system, but unfortunately, the FAA has not yet granted FAA/PMA approval to Phoenix Group (www.aeroadvantage.com) to manufacture the simple part that is needed to do the mod. My choice of replacement will probably be yet another new style pump, the Sigma-Tek AEON pump (http://www.sigmatek.com). Interestingly, the guy at Phoenix Group (the company that took over Aero Advantage) implied that they a solution to the original flaw and still plan to bring an update to market, if they get financing. And, they'd overhaul the old units. |
I still have one on my C172. The problem is the big 6 cylinder
engines induce a torsional vibration that the pump is resonant to. This fatigues the shear point on the shaft and the pump can quit in less than 100 hours when used with certain 6 cyl engines. I have over 200 hours on my Aero Advantage pump but I am using a 4 cylinder Lycoming 0-320 and have had no problems. I have had 3 Airborne pumps fail so far. Not a single one got to the published Airborne TBO hours. One lasted 900 hours, one lasted 250 and one only lasted 50 hours. Is the Airborne pump better? Not in my opinion unless you have a 6 cyl engine. At least the feds are letting me keep the vacuum warning system. Anybody got real world reliability data on the AEON pump yet? John F On 23 Feb 2006 07:20:29 -0800, "rdant" wrote: Am I the only one that still has the Aero Advantage Dual Pump installed? I see that the AD to remove the pump has finally arrived: http://dmses.dot.gov/docimages/p84/385862.pdf This is a stupid AD, in my opinion. The reason for the AD is that both chambers might fail at the same time. But, how is that any worse than a single-chamber pump failing? Fortunately, the FAA updated the AD to allow owners to retain the monitoring system, but unfortunately, the FAA has not yet granted FAA/PMA approval to Phoenix Group (www.aeroadvantage.com) to manufacture the simple part that is needed to do the mod. My choice of replacement will probably be yet another new style pump, the Sigma-Tek AEON pump (http://www.sigmatek.com). Interestingly, the guy at Phoenix Group (the company that took over Aero Advantage) implied that they a solution to the original flaw and still plan to bring an update to market, if they get financing. And, they'd overhaul the old units. |
If you're asking about the piston pump, I think not ready for prime
time yet - heard some reports of early failure. The only reliable pumps are the oil-lubricated ones from Airwolf and other vendors. |
| Saratoga Gear Retract Problem | Yahoo! News | Owning | 16 | November 30th 05 12:17 AM |
| Looking for a reversible fuel transfer pump | [email protected] | Home Built | 13 | April 12th 05 10:26 PM |
| Aero Advantage closing shop. | Eric Ulner | Owning | 51 | May 17th 04 04:56 AM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| Dual Chamber Vacuum pump | Dave Butler | Owning | 0 | August 8th 03 03:50 PM |
