I'd be interested in "go/no-go" opinions of others, based solely on the
following information ... "Naturally aspirated, carburated, light twin (C172 engines) - hasn't been flown for 3 weeks - at the conclusion of last flight was fueled to the max. Has since been observed to have fuel dripping from the right-hand engine nacelle. Has been checkd by engineer who has put it down to "full tanks + volume change due to temperature changes". No other information available. My initial thought was "why wouldn't the excess fuel get forced out through the tank vents, rather than through "something" within the engine bay. How many of you would / would not fly this aircraft based on the above info? (I appreciate that more info would be nice, but it's all I have available). Many thanks, Cheers, |
Based on that, I would NOT fly the aircraft UNTIL I had
personally inspected it to see what was leaking and from where. If the float valve was leaking, the fuel level would rise and over-flow from the vent on the carb. That is an easy fix. If a fuel line is leaking, it is also an easy fix. If a crack is in the float bowl, you replace the carb, also easy but more expensive. What is the history of the airplane before and on the last flight? Was is parked with the fuel valves OFF or ON? -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "C J Southern" wrote in message ... | I'd be interested in "go/no-go" opinions of others, based solely on the | following information ... | | "Naturally aspirated, carburated, light twin (C172 engines) - hasn't been | flown for 3 weeks - at the conclusion of last flight was fueled to the max. | Has since been observed to have fuel dripping from the right-hand engine | nacelle. Has been checkd by engineer who has put it down to "full tanks + | volume change due to temperature changes". | | No other information available. | | My initial thought was "why wouldn't the excess fuel get forced out through | the tank vents, rather than through "something" within the engine bay. | | How many of you would / would not fly this aircraft based on the above info? | | (I appreciate that more info would be nice, but it's all I have available). | | Many thanks, | | Cheers, | | | |
![]() "Jim Macklin" wrote in message news ![]() What is the history of the airplane before and on the last flight? Was is parked with the fuel valves OFF or ON? Several years ago the aircraft showed the same symptoms - on that occasion the leak was due to a fractured primer line. Prior to the last flight there were no know issues. Aircraft is always parked with fuel selectors ON, but following the leak the right hand fuel selector has been turned off to stop any more leakage. Personal investigation would be difficult - it would require removal of the cowling (which presumably the engineer has done). If the cowling isn't removed, then the only place you can see anything is via the oil filler flap - which lets one see very very little. |
Removal of the cowling is required and I would want to
either do it or be present. Fuel lines can leak due to loose fittings, broken lines that crack from fatigue or abrasion. I would want to visually inspect for any signs of fuel stains and any damage. The problem is not just possible engine failure, but fire and explosion inside the wing or cowling. Since mechanics {engineers} often won't fly in airplanes they have performed maintenance upon, you, the PIC must be able to inspect the airplane and satisfy yourself. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "C J Southern" wrote in message ... | | "Jim Macklin" wrote in message | news ![]() | | What is the history of the airplane before and on the last | flight? Was is parked with the fuel valves OFF or ON? | | Several years ago the aircraft showed the same symptoms - on that occasion | the leak was due to a fractured primer line. | | Prior to the last flight there were no know issues. | | Aircraft is always parked with fuel selectors ON, but following the leak the | right hand fuel selector has been turned off to stop any more leakage. | | Personal investigation would be difficult - it would require removal of the | cowling (which presumably the engineer has done). If the cowling isn't | removed, then the only place you can see anything is via the oil filler | flap - which lets one see very very little. | | | |
![]() "Jim Macklin" wrote in message news ![]() Based on that, I would NOT fly the aircraft UNTIL I had personally inspected it to see what was leaking and from where. If the float valve was leaking, the fuel level would rise and over-flow from the vent on the carb. That is an easy fix. If a fuel line is leaking, it is also an easy fix. If a crack is in the float bowl, you replace the carb, also easy but more expensive. What is the history of the airplane before and on the last flight? Was is parked with the fuel valves OFF or ON? -- James H. Macklin ATP,CFI,A&P Don't see how the carb float valve could be leaking; the mixture is at idle cutoff, right? |
Idle cutoff stops flow of fuel to the venturi/throat, but
the float valve stops the flow of fuel into the carb float bowl. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. ".Blueskies." wrote in message ... | | "Jim Macklin" wrote in message news ![]() | Based on that, I would NOT fly the aircraft UNTIL I had | personally inspected it to see what was leaking and from | where. If the float valve was leaking, the fuel level would | rise and over-flow from the vent on the carb. That is an | easy fix. If a fuel line is leaking, it is also an easy | fix. If a crack is in the float bowl, you replace the carb, | also easy but more expensive. | | What is the history of the airplane before and on the last | flight? Was is parked with the fuel valves OFF or ON? | | | -- | James H. Macklin | ATP,CFI,A&P | | | | Don't see how the carb float valve could be leaking; the mixture is at idle cutoff, right? | | |
![]() "Jim Macklin" wrote in message news:eqeTf.118075$QW2.13026@dukeread08... Idle cutoff stops flow of fuel to the venturi/throat, but the float valve stops the flow of fuel into the carb float bowl. -- James H. Macklin ATP,CFI,A&P OK, so the float bowl is always filled as far as the (good) float/needle allows it to be while the mixture control is downstream of the float needle? Actually makes sense because the float is supposed to control the head pressure against the carb jet, and putting a cutoff in front of the float would only cause the bowl level to lower with very slight leaning due to the reduces head pressure. One of these days I'll get to mess around with one of these engines.... Thanks Jim... |
I had a commercial pilots certificate for some time before I
attended A&P school [Spartan] and I learned that I didn't know a lot of things about aircraft engines that I think a pilot should know. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. ".Blueskies." wrote in message t... | | "Jim Macklin" wrote in message news:eqeTf.118075$QW2.13026@dukeread08... | Idle cutoff stops flow of fuel to the venturi/throat, but | the float valve stops the flow of fuel into the carb float | bowl. | | -- | James H. Macklin | ATP,CFI,A&P | | | | OK, so the float bowl is always filled as far as the (good) float/needle allows it to be while the mixture control is | downstream of the float needle? Actually makes sense because the float is supposed to control the head pressure against | the carb jet, and putting a cutoff in front of the float would only cause the bowl level to lower with very slight | leaning due to the reduces head pressure. One of these days I'll get to mess around with one of these engines.... | | Thanks Jim... | | |
![]() "Jim Macklin" wrote in .....If the float valve was leaking, the fuel level would rise Not likely to happen on a low-wing twin. Maybe a Cessna single. |
Who said this was a low-wing twin?
"John Gaquin" wrote in message ... | | "Jim Macklin" wrote in | | .....If the float valve was leaking, the fuel level would | rise | | Not likely to happen on a low-wing twin. Maybe a Cessna single. | | |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
