Engine Data Plate
Old April 11th 06, 06:06 PM posted to rec.aviation.owning
Default Engine Data Plate
Hi,
I've got one question. Is it possible to check what is the serial number of
an engine if the engine data plate is suspected not to be a true one ? I
want to buy a Cessna 150 but the data plate looks a little bit strange and I
am not sure if it is correct.
Can you advise me the way to check it ?
Best regards
Mike /Poland/
Old April 12th 06, 07:37 PM posted to rec.aviation.owning
Maybe email Continental at www.tcmlink.com
Btw, many older data plates have lost their paint and such and are hardly
legible, but the serial numbers are stamped.
Kent Felkins
Tulsa
"Micha³ Cebrowski" wrote in message
Hi,
of an engine if the engine data plate is suspected not to be a true one ?
I want to buy a Cessna 150 but the data plate looks a little bit strange
and I am not sure if it is correct.
Best regards
Mike /Poland/
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
Old April 12th 06, 07:42 PM posted to rec.aviation.owning
On my Lycoming, the serial # is stamped into each half of the case
along the top edge of the line where the case halves are split, at the
rear of the engine (closest to the firewall).
Micha³ Cebrowski wrote:
Hi,
Best regards
Mike /Poland/
Old April 12th 06, 08:01 PM posted to rec.aviation.owning
I've seen circa 1967 Continental data plates on an O-300D that were
only a serial number stamped on a sheet of stainless. There obviously
was no other markings that had worn off.
data plate for 2-33 Peter Scarpelli Soaring 1 March 21st 06 12:53 AM
JPI Data Format and Conversion Josh Owning 4 June 13th 05 04:20 AM
JPI Data Format and Conversion Josh Piloting 4 June 13th 05 04:20 AM
