Attention Cambridge GPS-NAV, OLC and SeeYou users--v3.5 is now current
Old May 29th 06, 06:45 PM posted to rec.aviation.soaring
Default Attention Cambridge GPS-NAV, OLC and SeeYou users--v3.5 is now current
SeeYou V3.5 has been released with the Cambridge GPS-NAV Model 10/20/25
fix for OLC claims. If you use the GPS-NAV for OLC claims with SeeYou,
you need to download this new release. SeeYou v2.82 through v3.4 used a
windows DLL to convert the CAI file, and this was not completely
compatible with the DOS version used by OLC. The fix was for SeeYou to
use the DOS software, and this was implemented in the GPS-NAV patch
v3.5a, and now in the released v3.5. You can download the software
http://www.seeyou.si/
Note that there may still be a problem with OLC claims where waypoints
do not match up exactly with GPS-NAV files. In this case, the OLC web
claim form will show the waypoints in red with suggestions on the line
below. Just edit the waypoint entries using the suggested values to fix
this. When you click on check entry, the waypoints should all appear in
green, and the claim flight button will finish your claim. This only
happens infrequently, but you should be aware of it in case it happens
to you, Don't worry, it's easy to fix.
If you have problems with SeeYou, contact support at
infoatnaviterdotsi. SSA-OLC pilots in the US can contact the
SSA-OLC committee at olcatssadotorg for assistance. Other OLC users
should contact OLC at helpatonlinecontestdotorg.
Old May 29th 06, 07:11 PM posted to rec.aviation.soaring
fix for OLC claims.
Doug, do you happen to know if ConnectMe can be used in the ship to get
files to an iPaq and the results then claimed through desktop SeeYou
successfully?
Thanks, Bob
