Here's one for the pros: I was balancing my tail rotor and had it down to
0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Hi Stuart & Kathryn,
What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Hello Stu,
Do you clamp the rudder pedals while doing this? Have you checked the tail rotor tracking before? where do you put the reflecting tape for your DSS or Prodrive? How many hours do you have? Claude. "Steve R" a écrit dans le message de news: ... Hi Stuart & Kathryn, What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Claude Yep clamped pedals and track set up to the nearest 0.1 degree and
checked with eyeball. I'm putting the tape on the blade grip and am using the DSS. The Pro-Drive did a 180 flip on me and I got mad and took it off and am using the DSS. I've got 225hrs on the ship and the tail rotor has about 160. I can't feel any bearing troubles. Can't see how an out of track blade could cause the ips to increase and the phase angle to change so much. On the main rotor the out of track generates vertical vibration and doesn't affect the lateral very much at all. -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell "claude lescure" wrote in message ... Hello Stu, Do you clamp the rudder pedals while doing this? Have you checked the tail rotor tracking before? where do you put the reflecting tape for your DSS or Prodrive? How many hours do you have? Claude. "Steve R" a écrit dans le message de news: ... Hi Stuart & Kathryn, What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Steve: It is a Baby Belle. I recently repeated with just the engine
driving the main rotor and the tail rotor disconnected. I measured the vibration at the tail rotor gear box to see if the engine vibration was coupling thru the tail boom. Nope. I ran the engine up and took readings, backed it to idle and went up again. Did not get repeatable readings. I will try the balancer on a D.C. motor and flywheel I've rigged up and see what it does. I've been doing an article for our magazine on the comparison between the Pro-Drive balancer and the DSS Micro Balancer and stumbled onto this problem. In the past I've balanced mine and two other ships tail rotors down to the 0.05 ips levels fairly easily. Now with the readings skipping around, I don't have a chance. BTW balancing the main rotor at it's 500 rpm does not have this problem. It repeats nicely. -- Kathryn Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell "Steve R" wrote in message ... Hi Stuart & Kathryn, What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Steve,
It's been a while since I did any aviation maintenance, but the bearing thing was exactly my thought as she described an unattributed shift in the ips and phase angles on the repeated runs. Once upon a time (it was a Sikorsky product) a T/R paddle had debonded at one end, but internally, and was causing the maintenance pilot fits as he tried to balance it. He even accused me of putting it back together incorrectly just prior to my departing for vacation. He was wrong. When they swapped out the T/R paddle and it balanced out, they removed the boots from the bad T/R component and found it had failed. The only symptom that I remember was variable ips readings and changing phase angles of successive readings. Linc Steve R wrote: Hi Stuart & Kathryn, What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
Bad blade dampers on articulated (main) heads cause fits too. The test
equipment will say to make such-and-such adjustments, the guys make those adjustments, you run the test again thinking the numbers will be in limits or at least closer, and instead the equipment comes back with numbers that make no sense. I know the maintenance guys _hate_ changing out a damper. For the OP, are there accessories running off the shaft? (Oil cooling fan maybe?) What about the basics, is everything torqued properly, clean, nothing loose (gearbox oil cap, access panels, so on)? Linc wrote: Steve, It's been a while since I did any aviation maintenance, but the bearing thing was exactly my thought as she described an unattributed shift in the ips and phase angles on the repeated runs. Once upon a time (it was a Sikorsky product) a T/R paddle had debonded at one end, but internally, and was causing the maintenance pilot fits as he tried to balance it. He even accused me of putting it back together incorrectly just prior to my departing for vacation. He was wrong. When they swapped out the T/R paddle and it balanced out, they removed the boots from the bad T/R component and found it had failed. The only symptom that I remember was variable ips readings and changing phase angles of successive readings. Linc Steve R wrote: Hi Stuart & Kathryn, What kind of helicopter are you talking about here? Please excuse a wild guess from someone who has "very" little experience in the experimental world but......... since you're not finding anything overtly loose in the drive system or tail blades, I have to wonder about something like a bearing going south on you? It might not be anything you'll feel just moving a static system round but could start causing problems when under load. Is there any kind of preload put on the system during assembly? If so, is it even? As I said, I'm just guessing here so if I'm totally out of line, please excuse the reply! ;-) Best of luck & fly safe, Steve R. "Stuart & Kathryn Fields" wrote in message .. . Here's one for the pros: I was balancing my tail rotor and had it down to 0.27 ips and still had just a touch too much weight where I had added it. So still needing to safety wire a bolt that is located in the center of the tail rotor output shaft, I chose to safety it to a hole 180 degrees from the weight. The safety wire was small, 0.025, so I didn't expect to see the ips go to zero, but I hoped they would decrease maybe to 0.20. Well it didn't. All of a sudden I had 0.9ips, so I shut down and removed the wire and ran again. This time I got 0.5 ips. The balancer reading did not even come close to repeating. The phase angle was also different. In an experiment, I would run up from idle to full chat and take 4 averaged readings, come back to idle and go up to full chat again for another 4 readings. Never repeats. Can't find anything loose in the drive or on the blades. If I pull a set of readings at 2500, 2600 and 2700, all the readings pretty much agree with the exception of ips increasing a bit with rpm. However if I take it to idle and come back up, I get a different set. Any ideas? -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell |
![]() claude lescure wrote: Stu , I was just thinking: maybe the problem is comming from your balancer. Along those lines, Chadwick-Helmuth makes (or used to make) a calibrator for the purpose of check the balancing equipment. It was a fairly simple device and probably could be duplicated (as the Chadwick version was pricey). After chasing the T/R balance on my 269, it turned out the problem was indeed the CH balancer. It was not an obvous problem. I looked online and noticed that CH had been purchased by Honeywell and I wasn't able to find any further info. Gary |
Stu,
If I understand, the figures in term of IPS and angle does not repeat each time you decrease to idle and start again.I may be incorrect but each time you are passing though idle the engine crankwheel can take a different place due to freewheel. And the vibrations from engine(same speed than tail rotor) could mix, interfer or be added and amplified with the tail rotor assembly.The different place taken by the engine crankwheel and slip between engine and rotor shaft each time you reduce the throtle could be the answer for non repeatable reading . Have you tried to put a velocimeter on the engine itself to see the level of vibrations at 2700RPM? Where did you disconnect the tail rotor drive? is it on the mainrotor side or on the tail rotor side? First try to check your DSS on a bench.I am almost sure that it is ok as the figures are constant as you go from 2500 to 2700 except IPS slight increasing. You could as well make a try with the second velocemeter. About tracking influence on vibration I can assure that on main rotor track adjustment has mainly effect on vertical vibration but have as well a great effect on lateral vibration. And it should be the same on tail rotor. Last time I balanced my tail rotor I had difficulties to get below 0.2 IPS. I am sure you will succeed. Claude "Gary Knutson" a écrit dans le message de news: Tv6fg.98088$iU2.89247@fed1read01... claude lescure wrote: Stu , I was just thinking: maybe the problem is comming from your balancer. Along those lines, Chadwick-Helmuth makes (or used to make) a calibrator for the purpose of check the balancing equipment. It was a fairly simple device and probably could be duplicated (as the Chadwick version was pricey). After chasing the T/R balance on my 269, it turned out the problem was indeed the CH balancer. It was not an obvous problem. I looked online and noticed that CH had been purchased by Honeywell and I wasn't able to find any further info. Gary |
Real time continuous Prop balancing | abripl | Home Built | 20 | January 15th 06 03:32 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Tracking and Balancing | Frederik Coppens | Rotorcraft | 1 | June 29th 04 02:39 PM |
Prop balancing and assorted observations - long | Dave Hyde | Home Built | 10 | June 27th 04 01:08 AM |
Balancing act | Big John | Home Built | 1 | November 28th 03 04:33 PM |
