FAA fuel waivers
Old June 10th 06, 03:28 AM posted to rec.aviation.piloting
Default FAA fuel waivers
Can anyone back up this claim? It sounds convincing, but I want to
have a second opinion:
----Start quote-----
Apparently, the FAA (the same FAA who was going against our contract
and has cut out budget, cut trainees to replace all the people
retiring, and is attempting to speed up training by rushing through
important steps) is giving airlines a waver on gas. This waver states
that they don't have to fill up the plane all the way so they can save
on fuel costs. This means, they have exactly the amount of fuel they
need to get to their destination +45 minutes. Anything under that +45
minutes means an emergency. So that means these aircraft were getting
close to that emergency point. It's dangerous for the pilot, the
controller, and the passengers espicially.
-----End quote-----
I would appreciate any information anyone has about this. At least if
it's true or not.
Thanks!
Old June 10th 06, 03:41 AM posted to rec.aviation.piloting
ups.com
FAA regulations are on the web. Check it out and let us know.
John T
http://sage1solutions.com/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://spf.pobox.com
____________________
Old June 10th 06, 03:44 AM posted to rec.aviation.piloting
§ 91.167 Fuel requirements for flight in IFR conditions.
(a) No person may operate a civil aircraft in IFR conditions unless it
carries enough fuel (considering weather reports and forecasts and
weather conditions) to-
(1) Complete the flight to the first airport of intended landing;
(2) Except as provided in paragraph (b) of this section, fly from that
airport to the alternate airport; and
(3) Fly after that for 45 minutes at normal cruising speed or, for
helicopters, fly after that for 30 minutes at normal cruising speed.
so i guess this kind of fueling behavior is normal based on these
regulations. this is probably what airlines have been doing all along.
i'm just a little confused about this said "waiver" (which, i noticed
was spelled wrong in the quote which i think hinders its credibility)
John T wrote:
ups.com
John T
Old June 10th 06, 04:03 AM posted to rec.aviation.piloting
It's not a waiver, its a rule and it's nothing new. An airliner has to
carry enough fuel to get to it's destination, divert to it's alternate
plus 45 minutes. You can't have a rule that "you have to fill up".
Filling up might not be ENOUGH fuel. Don't worry about THIS one, almost
all captains, being cautious, add a little extra fuel over the required
fuel so they have some cushion. Fuel exhaustion with airliners is very
rare, it has happened, but it's not likely. They watch their fuel very
carefully.
Old June 10th 06, 06:53 AM posted to rec.aviation.piloting
On 9 Jun 2006 19:03:34 -0700, "Doug"
And filling up might also mean TOO MUCH fuel. The airplane must be
loaded less than its maximum takeoff weight. Satisfying that
requirement may entail leaving the tanks partially empty. For a short
trip, an airplane taking off with full tanks could still have so much
fuel aboard on arrival that it would above its maximum landing weight.
In that case, the aircraft must depart with less fuel.
Operating with reduced fuel loads has always been a part of safe and
legal operation of the aircraft. Filling the tanks completely could be
illegal and unsafe in some circumstances.
RK Henry
Old June 10th 06, 04:17 AM posted to rec.aviation.piloting
Who are you?!?!
Are you any kin to ?
===== did someone leave the Troll Gate open??==========
Old June 10th 06, 04:37 AM posted to rec.aviation.piloting
Hmm... I don't /think/ I know that person. Maybe. Where do they live?
Casey Wilson wrote:
Who are you?!?!
Old June 10th 06, 05:45 AM posted to rec.aviation.piloting
This waver states
on fuel costs.
"Filling up" the plane is not a requirment. "Having enough gas" is
(where "enough" is defined in the regs and includes reserves). You
don't have to have "more than enough", otherwise that amount would be
what "enough" would be, and we're back where we started.
Now, "enough" means "enough to get to your destination, fly the
approach, go to the alternate, fly the approach, and fly 45 minutes at
full cruise". Depending on what you pick for an alternate, you may need
more or less gas. Depending on what you pick for a destination, the
same is true.
The "destination" doesn't have to be "where you want to go". What I
have heard some pilots do is to make the place they want to go the
alternate, and pick a "destination" that is short of that. This
requires less gas. If they manage to get a better tailwind, then by the
time they get to their destination (not where they wanted to go), they
may still have enough gas to get to the alternate (which is where they
wanted to go), AND fly to another legal alternate, AND still fly for 45
minutes. IF this happens, they re-file with the new plan and keep
flying. The risk is that if this does NOT happen, they will need to
land short of where they wanted to go.
It sounds like cheating, but safety is NOT compromised, because they
always have a place to land in the plan, and sufficient reserves.
Jose
The price of freedom is... well... freedom.
Old June 14th 06, 03:00 PM posted to rec.aviation.piloting
Jose
I'll use your posting to add my 2 cents worth to thread.
My Mark 20C Mooney had a built in fuselage tank (bird had about 7
hours with all tanks full).
If I needed the range and loaded the fuselage tank, it made the bird
into a two seater due to max weight limits. Normal flights only
carried slosh fuel in tank and could use all four seats. This is not
to say we didn't push the max gross on occasions.
I never loaded fuselage tank for a leg, unless needed for range and
any expected holding.
Configuration gave lots of options of range vs cabin loading.
Big John
On Sat, 10 Jun 2006 03:45:00 GMT, Jose
This waver states
on fuel costs.
same is true.
Jose
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 07:13 PM
