Well... it is stripped, sanded, polished..
Now, how do we keep it that way? What do you guys use? How often? Dave |
![]() "Dave" wrote: Well... it is stripped, sanded, polished.. Now, how do we keep it that way? Weekly labor. What do you guys use? How often? Paint. Once. Now I never have to polish the g-d thing again. -- Dan C172RG at BFM |
Paint. Once. Now I never have to polish the g-d thing again. How about a clearcoat paint, applied quickly after a polishing and cleaning? -- Jim in NC |
Find out what alloy was used to make the spinner, different
alloys have different corrosion prevention needs. If you want the bright aluminum polish, a good clear coat may keep it bright. But paint doesn't like high polish surfaces, it needs some tooth to bite into, a good paint job inside and out, on properly etched and primed metal will do wonders. You can even paint the spinner with a pattern that looks better than bright metal. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Morgans" wrote in message ... | What do you guys use? How often? | | Paint. Once. | | Now I never have to polish the g-d thing again. | | How about a clearcoat paint, applied quickly after a polishing and cleaning? | -- | Jim in NC | | |
![]() "Morgans" wrote: What do you guys use? How often? Paint. Once. Now I never have to polish the g-d thing again. How about a clearcoat paint, applied quickly after a polishing and cleaning? It doesn't look nearly as nice as bare, polished aluminum. Powder coated clear is supposed to look better, but I haven't seen it. -- Dan C172RG at BFM |
"Dave" wrote in message
... Well... it is stripped, sanded, polished.. Now, how do we keep it that way? What do you guys use? How often? The other folks are probably right, painting is the easiest. That said, I've been very happy with Flitz metal polish. I first found it in the hardware store, but since then have run into sales booths at airshows. It does work great. As far as how often, well...I don't use it nearly often enough. I suppose weekly would be optimal, but it really comes down to how much you care about keeping the thing shiny. I have limited time with respect to flying these days, so frequently the choice is between keeping the plane clean and flying it. Guess what...the plane doesn't get cleaned very often. ![]() Pete |
I use Mothers Mag & Aluminum Polish when the spinners on the 310 start
looking like they need polishing. Then Mothers Carnuba wax on spinners and the leading edges to make bug removal easier. In between I use AeroShell Touch & Go to wipe the bugs off. Mark N28409 WC5I "Dave" wrote in message ... Well... it is stripped, sanded, polished.. Now, how do we keep it that way? What do you guys use? How often? Dave |
Us, too. We have a polished spinner and prop, and Mothers has turned out to be the best compromise on price and results. We probably polish the prop every other week, ditto the spinner. It only takes a few minutes, and it looks SO much better than paint. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 2006-06-11, Dave wrote:
Well... it is stripped, sanded, polished.. Now, how do we keep it that way? Nuvite. It comes in several grades. We used it on our (half polished, half painted) Cessna 140 and the polished surfaces looked like a mirror afterwards. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
![]() "Dave" wrote in message ... Well... it is stripped, sanded, polished.. Now, how do we keep it that way? What do you guys use? How often? Some of the more experienced pilots might advise otherwise, but... A trick with RVers in the south is to spray the front surface of their RV with a very thin coat of PAM so that they can just wipe off the bugs without chipping the paint. I don't know if it's an option for a spinner, but you get the idea, and maybe a similar solution would work. (Wiping it down with an oilcloth before a summer flight, for example.) -c |
Question about Alodine 1201 | Andrew Sarangan | Home Built | 20 | April 11th 06 01:31 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
