Hi all, does anyone know if the PA28-235 platform can handle a backup
alternator? If so, how would one be mounted? If not, what is the substitute alternative? Any suggestion on how many hours in labor & costs would be appreciated. Thank you. USA |
a backup alternator? If so, how would one be mounted? If not, what is the substitute alternative? Any suggestion on how many hours in labor & costs would be appreciated. I've never heard of one, but you might try asking this over on the Cherokee 235/236 Owner's Group website. See it at http://www.pa28.com/cherokee235/home.htm -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() USA wrote: Hi all, does anyone know if the PA28-235 platform can handle a backup alternator? If so, how would one be mounted? If not, what is the substitute alternative? Any suggestion on how many hours in labor & costs would be appreciated. Thank you. USA I have a friend with a PA-28-161, although that's not relevant to the solution. He made himself a portable pack with a couple of gel-cell batteries and a cigaret lighter type plug. Gives him an hour or so of backup power for the radio and GPS if the plane's system goes down. Easy to carry, charges externally and compatable with any 12V system, with a plug. I don't know what the FAA would say, but if I lost power in the clouds, I'd call it an emergency and take PIC responsibility. John Stevens PP-ASEL |
![]() wrote I have a friend with a PA-28-161, although that's not relevant to the solution. He made himself a portable pack with a couple of gel-cell batteries and a cigaret lighter type plug. Gives him an hour or so of backup power for the radio and GPS if the plane's system goes down. Easy to carry, charges externally and compatable with any 12V system, with a plug. I don't know what the FAA would say, but if I lost power in the clouds, I'd call it an emergency and take PIC responsibility. I assume he charges it at home, and not from the plane's electrical system? The voltage put out by a plane or car's electrical system is too high, and will reduce the capacity and life of gel cells. A schottie diode put in a charging line will reduce the voltage from an alternator, to make it safe for charging the gel cells. -- Jim in NC |
USA wrote:
Hi all, does anyone know if the PA28-235 platform can handle a backup alternator? If so, how would one be mounted? If not, what is the substitute alternative? Any suggestion on how many hours in labor & costs would be appreciated. First off, I don't doubt a method could be devised to install a backup alternator. However, this would be considered a major alteration requiring either an STC or field approval. In this day and age, I doubt you would get a field approval (even if someone previously got one for the same thing - the pracice of accepting prior field approvals as data for new ones has gone away, unfortunately) and AFAIK there is no STC. You can search all the existing STC's for a particular make and model on www.airweb.faa.gov/stc - be sure to check PA28-235 and PA28 series. It's not terribly searchable but you can always cut the text from your favorite browser and paste it into a text editor with search capability if you so wish. If there is no STC (and I suspect there is not) you're looking at tens of thousands to make it happen. I suggest that a much better approach would be to carry a handheld radio and GPS. Depending on what you choose, cost can vary from $500 to $3000. Also, you might consider adding a BNC connector allowing your handheld com to use an external antenna in case power goes out. Total cost for that should not exceed $200. Michael |
I lost my alternator 3 times in my 180 before I figured out why is was going
bad. I flew for more than an hour and when I landed it stilled cranked like it was charged. Why would you need an extra one. Wouldn't you just land at the nearest airport if you where IMC. "Michael" wrote in message oups.com... USA wrote: Hi all, does anyone know if the PA28-235 platform can handle a backup alternator? If so, how would one be mounted? If not, what is the substitute alternative? Any suggestion on how many hours in labor & costs would be appreciated. First off, I don't doubt a method could be devised to install a backup alternator. However, this would be considered a major alteration requiring either an STC or field approval. In this day and age, I doubt you would get a field approval (even if someone previously got one for the same thing - the pracice of accepting prior field approvals as data for new ones has gone away, unfortunately) and AFAIK there is no STC. You can search all the existing STC's for a particular make and model on www.airweb.faa.gov/stc - be sure to check PA28-235 and PA28 series. It's not terribly searchable but you can always cut the text from your favorite browser and paste it into a text editor with search capability if you so wish. If there is no STC (and I suspect there is not) you're looking at tens of thousands to make it happen. I suggest that a much better approach would be to carry a handheld radio and GPS. Depending on what you choose, cost can vary from $500 to $3000. Also, you might consider adding a BNC connector allowing your handheld com to use an external antenna in case power goes out. Total cost for that should not exceed $200. Michael |
Aluckyguess wrote:
Why would you need an extra one. Wouldn't you just land at the nearest airport if you where IMC. Aren't you the optomist. I've lost the alternator on a single engine solid IFR flight over the mountains one night and it ain't much fun. I got down OK before the battery went dead but it was definitely nerve wracking. That's why I like twins. It's not the extra engine so much as the extra alternator and vacuum pump. I've only had a very few engine failures over the years but I've had several alternators and vacuum pumps go TU. When you fly crap as a freight dog you learn to appreciate redundancy. -- Mortimer Schnerd, RN VE |
Point taken, but the original poster sounded like he owned his own plane. He
could probably spend the same amount of money on getting a new alternator every year for ten years and still come out ahead. Or he could get a new alternator and fix other problems that are more likely to cause a problem. I will take a well maintained single of a bucket of bolts twin any day. "Mortimer Schnerd, RN" wrote in message ... Aluckyguess wrote: Why would you need an extra one. Wouldn't you just land at the nearest airport if you where IMC. Aren't you the optomist. I've lost the alternator on a single engine solid IFR flight over the mountains one night and it ain't much fun. I got down OK before the battery went dead but it was definitely nerve wracking. That's why I like twins. It's not the extra engine so much as the extra alternator and vacuum pump. I've only had a very few engine failures over the years but I've had several alternators and vacuum pumps go TU. When you fly crap as a freight dog you learn to appreciate redundancy. -- Mortimer Schnerd, RN VE |
A set of relays and diodes would allow the installation of a
second battery and a great deal of redundancy at fairly low cost and weight. The standard alternator would charge both batteries, only the second battery would be connected to the essential bus of lights and avionics. A battery failure kills the alternator on most aircraft and thus kills the entire system. Having two isolated batteries give redundancy as long as the bus is able to shed load. Beech uses self-exciting alternators [and a generator will produce power w/o a battery (but it isn't well filtered)]. On a Beech you can turn the battery OFF and still operate. But in most Cessna and Piper aircraft the battery must be ON for the alternator to function. A second battery and modified bus can give redundancy. Load shedding can be automatic or manual. You need to have diodes to control current flow. -- James H. Macklin ATP,CFI,A&P "soxinbox" wrote in message ... | Point taken, but the original poster sounded like he owned his own plane. He | could probably spend the same amount of money on getting a new alternator | every year for ten years and still come out ahead. Or he could get a new | alternator and fix other problems that are more likely to cause a problem. I | will take a well maintained single of a bucket of bolts twin any day. | | "Mortimer Schnerd, RN" wrote in message | ... | Aluckyguess wrote: | Why would you need an extra one. Wouldn't you just land at the nearest | airport if you where IMC. | | | Aren't you the optomist. | | I've lost the alternator on a single engine solid IFR flight over the | mountains one night and it ain't much fun. I got down OK before the | battery went dead but it was definitely nerve wracking. That's why I like | twins. It's not the extra engine so much as the extra alternator and | vacuum pump. I've only had a very few engine failures over the years but | I've had several alternators and vacuum pumps go TU. | | When you fly crap as a freight dog you learn to appreciate redundancy. | | | | -- | Mortimer Schnerd, RN | | VE | | | | | | | | |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Fllight Recorder Wars, Part II: What Backup to Use? | Chip Bearden | Soaring | 13 | March 31st 04 10:10 PM |
Good AI backup, wish me luck | Robert M. Gary | Instrument Flight Rules | 29 | March 1st 04 05:36 PM |
Solid State Backup AI | Dan Truesdell | Instrument Flight Rules | 20 | January 15th 04 09:53 PM |
Backup gyros - which do you trust? | Dan Luke | Owning | 46 | July 17th 03 08:06 PM |
